03-20-2020, 02:13 PM | #5363 | |
Check out your local track population for evidence; you have a great resource in 86CUP. |
The Following User Says Thank You to CSG Mike For This Useful Post: | jacjac3 (03-20-2020) |
03-20-2020, 04:48 PM | #5364 |
Drives: 2017 BRZ (Sold), 2023 GR86
Well everyone, it was (mostly) fun while it lasted. Back to NA + A350. I'll be putting up a lightly used JRSC C30 kit shortly if there's any interest.
03-21-2020, 02:34 PM | #5365 |
pessimistic skeptic
It is your decision and good luck to you. But I can never imagine my car without JRSC. I would keep JRSC and use the factory tune, throw everything else away.
The Following User Says Thank You to mrg666 For This Useful Post: | CSG Mike (03-22-2020) |
03-21-2020, 07:22 PM | #5366 |
pessimistic skeptic
Has anybody replaced the mass air flow extension cable? Are there any recommendations?
Edit: Found here https://www.bmotorsports.com/shop/pr...d/3307%7B2%7D5 Last edited by mrg666; 03-21-2020 at 08:13 PM. |
The Following User Says Thank You to mrg666 For This Useful Post: | sroby (03-22-2020) |
03-22-2020, 11:48 AM | #5367 | |
Drives: 2013 FRS
Like mistople my car is primarily for the track and as a track car if you can only get in a few hot laps before you hit north of 260F oil temps the entire purpose of the JRSC is moot. I'm about a half step behind mistople, except I won't be keeping the car if it happens - the tracks I frequent are too large to be running a car with 200 hp so I'll be getting rid of it. |
The Following User Says Thank You to steved For This Useful Post: | mistople (03-22-2020) |
03-22-2020, 03:45 PM | #5368 | |
pessimistic skeptic
The Following 2 Users Say Thank You to mrg666 For This Useful Post: | CSG Mike (03-22-2020), new2subaru (03-22-2020) |
03-23-2020, 02:05 AM | #5369 | |
Drives: 2013 FRS
-The speed academy guys were sponsored by JR, which ties their hands in making honest assessments (I enjoy their content, but they're a business) - If I remember correctly their temp reading was inaccurate because they placed their sensor in a non optimal place, I'm picking up from obd2 and oil filter sandwich plate - the speed academy guys run time attack-like sessions on a small track, sub 1:30 ( I used to live in Ontario and ran TMP many times) which doesn't correlate to temps on big momentum tracks or long sessions (20-30 min). - the JR products are titled in a very misleading way which makes it easy to misunderstood their intended usage. ie: Track oil cooler, JRSC = insufficient cooling for most non-race track duty. I was also going to add comments about some vendors who post in this thread for inaccurate and misleading information but it seems of little value to get into a flame war. My only real contribution I can make to this forum is to let others know how greatly this kit will let you down if you drive on track. You can read through the last 3-5 pages and see anyone who tracks this car with a JRSC and an oil cooler built to JR spec and mounting location is having overheating issues and has to make some considerable changes to their bumper, air flow, and cooler mounting locations to get more then a few hot laps in, and most is fingers crossed best guess if there will be an improvement. Go read JR documentation and see if that's listed anywhere. |
03-23-2020, 11:54 AM | #5370 | |
pessimistic skeptic
03-23-2020, 12:29 PM | #5371 |
03-23-2020, 09:21 PM | #5372 | |
Drives: 2013 FRS
1. Track prep in the context of lapping is pads, fluid, and tires, not cutting a bumper. Im prepared to, and have, been deeper into it, but track prep is not what it is. 2. I'm not racing, I attend lapping events 3. I never said it should be easy or quick, and it's definitely not cheap 4. It's a kit.. with one way to mount it. As in I paid JR for their engineering just like I paid KW for my coilovers.. and my suspension works as advertised. |
03-23-2020, 11:17 PM | #5373 |
I’m a little surprised at the recent spike of overheating issues after this kit has been available for so many years. I was under the impression this was one of the only FI options that doesn’t overheat on track without extensive heat mitigation effort. What gives? Conspiracy theories aside, who here is *actually* pushing this kit under high stress for 20-30 minute sessions and achieving manageable temps?
03-24-2020, 03:37 PM | #5374 | |
Drives: Crapcan
03-25-2020, 01:47 PM | #5375 |
pessimistic skeptic
I would do the followings if I were trying to reduce the temperature on track.
- Check Oil pump working fine, are oil channels open, oil pressure okay - Check coolant circulation, thermostat opening properly - Sufficient air flowing through the radiator. Air guides behind the bumper cover installed properly - Radiator upgrade and racing thermostat - Install Oil cooler - Install hood vents - Get a proper tune. This does not mean the tune for highest power. The system can be too rich. - Upgrade short block with better oil pump and widened oil channels I know the last option is expensive and buying a different car can be considered instead. I might just buy a C7 Grand Sport instead. |
03-26-2020, 11:26 AM | #5376 |
Drives: Fast track beast
I'll say this. I posted a few times over the last few years asking if anyone was having cooling issues running the JR kit for track use. Crickets.
Now, all of a sudden the data is coming out confirming my own experiences, which are probably finally now resolved but with extensive reworking to front end airflow, but unfortunately causing HG issues with both my engines before solved. I've raced and chatted with Dave and Pete at Speed Academy and they have not had any overheating such as I have, but as mentioned they're also not running 30+ min races at full pin like I am. So yes, extensive reworking is necessary to gain proper airflow through all cooling components and eliminate heat soak with the way the kit is set up. I've now rebuilt my first engine, so maybe after all this Corona shit is done I can track test and confirm all overheating is behind me. I also have no plans to remove the JRSC unless I convert to an LS swap. Food for thought. |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
