Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
08-14-2017, 08:31 PM | #1 |
OBD plug not working... Kinda
So I have a cheap OBD Bluetooth transmitter that works with my gf's 350z and her f250. It previously worked with my FRS. Now it refuses to work with my FRS. When plugged in to the other 2 vehicles a light on the Bluetooth unit comes on with the key OFF. In the FRS, no lights come on ever. I thought my plug was bad but my ECUtek dongle works fine. So why does my ECUtek dongle work but the Bluetooth doesn't? I already tried bending pins and I tried the Bluetooth with and without an extender
08-14-2017, 11:10 PM | #2 |
Drives: 2013 WRB Subaru BRZ
Mine gets lights but doesn't show up on my phone, determined it was an incompatible device with my phone :/
08-14-2017, 11:22 PM | #3 |
08-15-2017, 12:09 PM | #4 |
Definitely strange, could be a bad connection. Make sure it's seated correctly and then trace the wires / check the fuse.
08-15-2017, 01:55 PM | #5 |
Ohne Titel
Drives: 2017 BRZ PP ISM
The OBD2 port on the FR-S and BRZ is very finicky. It's easy to bend the pins if your OBD2 dongle isn't a perfect fit.
If you install and remove the dongle a bunch of times, it's pretty common to bend the pins. As a first troubleshooting step, try using an OBD2 extension cable between the Bluetooth dongle and your car. $8 on Amazon: http://amzn.to/2vY3sU4 |
The Following User Says Thank You to TofuJoe For This Useful Post: | STV3 (08-15-2017) |
08-15-2017, 03:03 PM | #6 | |
08-15-2017, 04:11 PM | #8 | |
08-15-2017, 04:19 PM | #9 |
The Gunshine State
Drives: '14 BRZ Limited
BT adapters don't last forever, luckily, they're cheap. Just get another one off Amazon.
Current DD: M235i |
08-15-2017, 06:14 PM | #10 |
TechNINJA
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
I've noticed the harness is wound REALLY tight, and I need to adjust mine sometimes to get my ecutek cable to link properly. Removing the tape and freeing up some slack may help. It's likely just one pin is being pulled back some or losing the crimp from the tension.
08-15-2017, 08:29 PM | #11 |
Ohne Titel
08-16-2017, 08:44 AM | #12 | |
Drives: FT86
Fuse is blow The obd port power is supplied by fuse The Bluetooth dongle requires power from obd port check for 12v on pin 16 of obd port The Ecutek cable gets it power from laptop |
08-16-2017, 08:02 PM | #13 |
08-17-2017, 05:28 AM | #14 |
Drives: FT86
https://www.google.com.au/url?sa=t&r...wTIabWl0Jc6WWw Lnk to brz wiring diagram above Search for OBD. Their is a specific OBD fuse 7.5 A pull it and check with multimeter Its possible it broken wire but unlikely |
Similar Threads | ||||
What kinda bulbs? | LordTaikun | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-16-2015 01:33 PM |
Getting OLD kinda sucks... | blackhawkdown | Off-Topic Lounge [WARNING: NO POLITICS] | 44 | 06-13-2014 10:41 AM |
Grammar help? (kinda random) | DBacon1052 | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 12-14-2013 05:26 AM |
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug | sikest | Electronics | Audio | NAV | Infotainment | 7 | 01-21-2013 09:38 PM |
