go_a_way1
Old 04-22-2020, 11:55 AM   #5433
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by peaches View Post
Next purchase on my list, wouldn't be surprised if there is some damage already so I'll change the internals at some point. Unless it blows first.
I just ordered the Jackson Racing dual radiator. I will install as soon as it arrives and remove the STI oil cooler. Can't wait to track my car
Old 04-22-2020, 12:54 PM   #5434
peaches
Drives: '14 BRZ Limited
Did you order the JR dual radiator oil cooler? Do you have other means to cool the oil? Because that's what I have and it's not enough. I have that, and now I need to add the dedicated track oil cooler (different than their oil cooler).
I should have ordered their radiator and track oil cooler from the beginning, but I'm not swapping radiators again until I have to pull the engine out.
peaches is offline   Reply With Quote
Old 04-22-2020, 01:26 PM   #5435
mrg666
pessimistic skeptic
mrg666's Avatar
Yes, it is JR dual radiator. Let me install and test, I will post the results after that. Are you using the stock header and factory tune?
Old 04-22-2020, 01:30 PM   #5436
peaches
No, I have a Nameless header (ceramic coated) + Nameless header back. C38 + HBP + E-85, tune from Delicious. 320whp last time I dynoed it, received updated for LSPI since.
Old 04-22-2020, 01:39 PM   #5437
mrg666
pessimistic skeptic
mrg666's Avatar
OK! I have just the stock header and factory JRSC with factory tune. Without that fire breathing setup of yours , JR dual radiator will be more than enough for me most probably.
Old 04-22-2020, 01:57 PM   #5438
peaches
I had all the other stuff prior to the SC, bought my kit used at a pretty good price. I know redoing the whole exhaust would give me more power, but I won't do that until my temp issues are resolved and the engine is built.
Old 04-22-2020, 02:03 PM   #5439
mrg666
pessimistic skeptic
mrg666's Avatar
I would recommend a built block with upgraded oil pump in addition to pistons and piston rods. Increased oil circulation can help with overheating. Without increased oil circulation, oil cooler upgrade may not help that much. And also valve springs, stock valve springs are not strong enough for increased boost. It will be much more expensive to replace them if you need to take the engine out again.
Old 04-22-2020, 02:34 PM   #5440
peaches
Oh I have a big wish list, never enough money. Just finished buying the small pieces to be able to do the dedicated cooler, still need to buy that kit.
track oil cooler
oil baffle
vented undertray
pistons
rods
bearings
studs
valvetrain
cams
oil pump
oil sump
cage
seats
belts
The Following 2 Users Say Thank You to peaches For This Useful Post:
CSG Mike (04-23-2020), mrg666 (04-29-2020)
Old 04-28-2020, 11:00 PM   #5441
Strife
Strife's Avatar
Drives: Hyperblue BRZ
Is it necessary to upgrade the MAP sensor running on 93 and the low boost pulley?
Strife is offline   Reply With Quote
Old 04-29-2020, 03:28 AM   #5442
Custom tune? yes.
Strife (04-29-2020)
Old 04-29-2020, 04:50 AM   #5443
tomm.brz
Drives: brz 2017 hksv2
Yeah most master tuners you ll find, they will use hybrid SD as standard, and so they want a good map signal... ergo a 3bar or 4 bar MAP and you need to modify tune to even let it crank
it would be not essential for entirely MAF based tunes only, you just don t know how much boost you re running
I run my supercharger for monthes with stock MAP
The Following User Says Thank You to tomm.brz For This Useful Post:
Strife (04-29-2020)
Old 04-29-2020, 07:12 AM   #5444
mrg666
pessimistic skeptic
mrg666's Avatar
JR factory tune works with stock MAP sensor; it even throws a CEL if you upgrade the MAP sensor. If the tune is not factory, you need to ask this question to your tuner. They will tell you which sensor is required since tune needs to be calibrated for the specific sensor.
The Following User Says Thank You to mrg666 For This Useful Post:
Strife (04-29-2020)
Old 04-29-2020, 01:17 PM   #5445
Strife
Strife's Avatar
Custom tune? yes.
Okay, thanks! I'm planning on doing the custom remote tune from you guys. In that case should I upgrade?
Old 04-29-2020, 05:38 PM   #5446
It would be mandatory, yes.
Strife (04-29-2020)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
