Old 03-29-2016, 07:11 AM   #43
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
It's cut off boost just fine. It cuts it off about 3.5 psi above the set alarm. I had mine set to 20 psi and that's why you saw the 23.5 psi on my gauge.
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 03-29-2016, 04:28 PM   #44
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
So are you supposed to wire it to your ecu? Heard you needed to.
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 03-29-2016, 08:18 PM   #45
texasbound972
USMC
That's the first I've heard of that lol.
Old 03-29-2016, 08:28 PM   #46
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Really can you take pics of how yours is wired? Trying to figure this shit out ahah
The Following User Says Thank You to SoCal80six For This Useful Post:
texasbound972 (03-29-2016)
Old 03-29-2016, 08:54 PM   #47
texasbound972
USMC
Give me a sec 👍
Old 03-29-2016, 08:58 PM   #48
texasbound972
USMC
The Following User Says Thank You to texasbound972 For This Useful Post:
p1l0t (03-29-2016)
Old 03-30-2016, 03:48 AM   #49
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Thanks so much bro so your just running a relay into fuse? And all the failsafe features work?
Old 03-30-2016, 07:08 AM   #50
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
The AEM failsafe uses a lowside ground to enable the failsafe measure. It can be wired to a number of things. Many select to use it on the EBCS to cut boost in a lean event. It CAN be sent to the ECU as a means to pull timing out or cut fuel but a good tune is already going to have those counter measures.
Heres a shot of my wiring harness from Jacob at TuckTech. Its just a relay in line with the EBCS/EVAP harness. As soon as the gauge alarms, it kills power to the EBCS and drops you to wastegate pressure. TuckTech even offers the AEM Failsafe with this harness as a plug and play. No splicing required. Shoot him an email if you are so inclined. He will just need to know what kind of EBCS you are running for the connector type. tucktechjacob@gmail.com
xkalelx is offline   Reply With Quote
The Following User Says Thank You to xkalelx For This Useful Post:
p1l0t (03-30-2016)
Old 03-30-2016, 07:28 AM   #51
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Perfect will do thank you so much for the help really appreciate it!!
The Following 2 Users Say Thank You to SoCal80six For This Useful Post:
p1l0t (03-30-2016), xkalelx (03-30-2016)
Old 04-02-2016, 03:15 PM   #52
nickw14
Drives: Built FA20
Originally Posted by empower-auto View Post
351 @ 11psi
k . what? how?
What do you mean how? 12.5:1 compression, moderate boost, and a good tune is how. Considering people regularly see ~300 on 9psi, 350 on 11 isn't unreasonable.
nickw14 is offline   Reply With Quote
Old 04-04-2016, 10:51 AM   #53
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
350 whp on 93 octane at 11 psi is far from reasonable. Congrats. You played yourself. I would love to have seen some logs from that tune.
Old 04-04-2016, 10:56 AM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Looking at some of your past OFT tuning posts, I am going to assume you were on E85 when you made the 350 on 11 psi which is more reasonable.
Old 04-05-2016, 02:11 PM   #55
nickw14
Drives: Built FA20
This was on 93, no "playing myself" here. But, does it really matter? The engine blew up anyway. Next stop: 500+ on pump. Tell me it won't happen, and I'll be glad to post the dyno sheet when it's done in a month or so
Old 04-05-2016, 04:16 PM   #56
protpibe
protpibe's Avatar
Originally Posted by nickw14 View Post
March 20th, 2016 at around 4pm EST my FRS blew a "grape sized" hole through the top of the block. It was running 11 pounds of boost.
This was the scene when I popped the hood:
And here is the hole better revealed after pulling the intake manifold:
Loaded up on the trailer on the side of the highway:
Initially we thought this was a piece of the block, the machining texture said otherwise. It is a piece of piston.
This engine is crazy easy to remove. We had the thing out and on a stand in only a couple of hours start to finish. Turns out if you leave the engine upside down on a stand overnight, it won't fix itself and all be okay in the morning
Scroll down for a TLDR...
3/11/16: Dyno tuning
I had my car on the dyno at Accelerated Performance in Toledo, OH retuning for larger fuel injectors and a new clutch/flywheel. I was looking to put down 350-400, hit my target at 351@11psi Happy day, the car felt amazing. A friend of mine said it felt like it pulled harder than his tuned WRX (it did make 60 more horsepower, but you can't beat that AWD!).
There was one minor (and by minor, I mean major) issue... During the dyno pulls the plumbing on the wastegates heated up, the rubber expanded, and one of the wastegates ended up blowing a line off. I never had this issue since I added a boost controller after my initial tune, re-plumbed, and had always been moving and getting cool air in there to keep everything connected. Luckily Don is a very smart man and caught a boost spike as soon as it hit 20psi. But yes, it spiked to 20psi.
My original plan was to run 12-14psi and hit closer to 370 or 400whp. After the boost spike, Don said it would be much wiser to stick around 11psi. I was surprised, as I'm sure he was too, that it hadn't blown up then and there.
3/13/16: "Injector Tick"
It was the weekend after tuning that I noticed a faint ticking (no, knocking) sound. Anyone I called in to get an opinion on the sound said "it's probably fine, don't the injectors on this car make a lot of noise?". Well yes, they do make a considerable amount of noise. However, this was reminiscent of when a good friend of mine spun a bearing in his IS300, an eerily similar sound. I brushed it off as injector tick.
3/20/16: Judgement Day
I was heading back home via the highway with a friend of mine in the car, and two more of my friends following in a Chevy Cruze. We took off in 5th gear, got to the top of 5th, and then it happened. I was at maybe 6500rpm, not really sure, but it felt like I hit the rev limiter. It was similar to the load limiter for boost that was implemented so I glanced over at my gauge which now read "0" (not accurate for a car that is running, but it was no longer running at this point). Looked back to the tach, revs had already dropped. Check engine light. Oil light. Looked in the rear view, and a MASSIVE cloud of smoke is trailing from the back of the car. It covered both lanes of the highway and all of both berms on either side. Pulled off to the side, popped the hood, met with the chilling sight of oil everywhere.
Don had me crank it to try and diagnose the problem. One of the guys with me was then able to identify the hole due to smoke pouring out of it. Trailered the car home (thanks AAA!) and started tearing it down. There is a high possibility that one of the rods actually bent on the dyno when it spiked. 2 rods were visibly bent, bad. One was not easily visible in general so we couldn't tell for sure, and then the last one just shattered. Not sure if there is any head damage, I'll be tearing the rest of it down today.
Let me just say though that Accelerated has been nothing but amazing through this whole build process. Don personally came out to my house to help me straighten out the cluster fuck of intercooler piping when I first installed the kit. Then last night he came out at like 9pm to take a look at the engine. No doubt I will be returning to them for the engine rebuild, providing we are able to work around a similar price range.
TLDR:
Spiked 20psi on the dyno a week and a half ago, PROBABLY bent a rod then. Just this past weekend the engine decided to give out during a top of 5th gear pull. Sucks.
Damn, I just saw this now. Sorry to see it grenaded.
A boost spike to 20ish psi last spring bent a rod in my original motor, so I feel your pain lol. I totally agree about how easy it is to pull theses motors. Mine died on a friday but was up and running again by Sunday afternoon.
The Following 2 Users Say Thank You to protpibe For This Useful Post:
nickw14 (04-12-2016), p1l0t (04-05-2016)
Another One Bites the dust jph11 BRZ First-Gen (2012+) -- General Topics 19 02-23-2016 06:30 PM
Another one bites the dust joergasm CANADA 2 06-24-2014 11:44 AM
And another one bites the dust.... Rinn310 Scion FR-S / Toyota 86 GT86 General Forum 58 05-20-2014 11:04 AM
Another car bites the dust? RaceR Other Vehicles & General Automotive Discussions 10 12-17-2012 12:20 PM
Another One Bites the Dust kanundrum Scion FR-S / Toyota 86 GT86 General Forum 68 08-17-2012 02:30 AM
