Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
11-02-2021, 04:22 PM | #15 |
Custom Title
Drives: GT86
stripped bolt head
stripped the bolt head... That's broken enough for me. ...granted, I wasn't wearing rubber gloves so that was probably the real issue I thought I knew how to fix cars until I learned about finer things called torque wrenches. After rotating the tires on my (then) '87 MR2, I tested the grip by driving ...mph down a freeway only to have 3 bolts snap off all at the same time. The one bolt that hung on saved my life. Torque wrenches are the beginning of tools you'll need if you repair your vehicle yourself. Agreed.
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
The Following User Says Thank You to CockpitCruiser For This Useful Post: | 7 skulls (11-02-2021) |
11-02-2021, 04:46 PM | #16 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Didn't break mine, but I did replace it. It started to get rounded off and had the painted crush washer corroded on causing leaks even with a fresh one stacked on, so $2 later at Subaru I got a new one. When I bought a fresh oil pan from Toyota, it came with a drain plug bolt... and a painted on washer .
11-02-2021, 11:40 PM | #17 |
The Following User Says Thank You to humfrz For This Useful Post: | Opie (11-03-2021) |
11-03-2021, 01:39 PM | #19 | |
Well, it is a "plug" is it not?! - |
11-03-2021, 01:52 PM | #20 |
Drives: 2014 scion frs
Reminded me of this old meme...
The Following 4 Users Say Thank You to 7 skulls For This Useful Post: |
11-03-2021, 09:40 PM | #21 |
Custom Title
Drives: GT86
11-04-2021, 03:46 AM | #22 |
LMGTFY
Drives: 13 FRS, 91 Miata
The Following User Says Thank You to x808drifter For This Useful Post: | CockpitCruiser (11-04-2021) |
11-04-2021, 01:19 PM | #23 |
Custom Title
Drives: GT86
No more bolt
No more drop No more oily fingers Just easy peasy...
The Following User Says Thank You to CockpitCruiser For This Useful Post: | soundman98 (11-05-2021) |
11-05-2021, 02:09 PM | #24 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Nothing against fumoto, but never had an issue with an oil pan bolt on numerous cars and 100s of oil changes.
With a fumoto valve you are at risk of a gang of anarchists that go around with a special tool opening fumoto valves on parked cars, just because. |
11-05-2021, 02:18 PM | #25 | |
TRACKBREAD
lol ok, cause my car totally looks like it has one on there. This is as crackpot crazy as the people who think someone will hand out drugs on Halloween |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | CockpitCruiser (11-11-2021) |
11-05-2021, 02:28 PM | #26 | |
Drives: 22 BRZ limited
The Following User Says Thank You to dragoontwo For This Useful Post: | CockpitCruiser (11-14-2021) |
11-05-2021, 08:57 PM | #27 | |
ProCrastinationConsultant
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | CockpitCruiser (11-14-2021), x808drifter (11-05-2021) |
11-06-2021, 11:52 AM | #28 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Only special tool needed with the FuMoto is a low deck height trolley jack.
That'd be a bit noisy and conspicuous. Don't park with one side up on the curb?
"I gotta rock." -- Charley Brown |
Similar Threads | ||||
Subaru or Toyota drain plug? | yayforaddison | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 05-06-2020 10:59 PM |
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
Magnetic oil drain plug, effective? | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 02-16-2013 11:59 PM |
Greedy Magnetic Drain Plug | USMC -FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 02-10-2013 06:04 PM |
Engine oil drain plug washer | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-28-2012 11:28 AM |
