Old 11-19-2021, 01:48 PM   #71
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by timurrrr View Post
Is my understanding correct that you've never directly measured heat/temperature of the brakes,
but only visually estimated the heat based on wear patterns and overall wear over time?
Temp paint measured on mine, visual only for mine to my friends car comparison.
Icecreamtruk is offline   Reply With Quote
Old 11-19-2021, 01:50 PM   #72
timurrrr
timurrrr's Avatar
Drives: 2022 GR86 Neptune, 2017 BRZ with PP
So no hard data to support the theory that your friend generated more heat rather than simply more wear?
The Following User Says Thank You to timurrrr For This Useful Post:
Goingnowherefast (11-19-2021)
Old 11-19-2021, 03:09 PM   #73
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
So, @Goingnowherefast, I would like to know why is there more heat on his car, or why was there more heat in mine before I got better (and ultimately went much faster) at managing ABS. Im always up for learning something.
The problem is that's just simply not how you conduct testing. There's too many variables. That's why legitimate brake manufactures run tests on brake dynos dictated by the SAE where you can control all the variables in question. It's not really worth comparing anecdotal evidence from two completely different cars, with two completely different powertrains, from two completely different drivers etc. That's what we call in the engineering world "garbage data" and we throw it in the trash.
Example: Me and my buddy both have BRZ's. I go through pads faster then him. Simple conclusion based on anecdotes? Oh well I must be harder on the brakes or be misdriving them. Conclusion after looking at the data? I'm like 5 seconds faster than him everywhere on track including a way higher V max before each braking zone etc.
This. Anecdotal claims are pretty meaningless. Especially with so many variables at play.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
timurrrr (11-19-2021)
Old 11-19-2021, 07:38 PM   #74
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Dude, if you’re going to quote the procedure, at least use the right one. Tokico would run JASO testing.
Stonehorsw is offline   Reply With Quote
Old 11-19-2021, 08:21 PM   #75
Goingnowherefast
What are you talking about? Tokico? The shock company? Lol
Old 11-19-2021, 09:37 PM   #76
Stonehorsw
Stonehorsw's Avatar
Tokico is a long term partner for Subaru on Brakes. They did develop Legacy, Impreza amongst other brakes.
It is not well known in the west, but it is a fairly good brake supplier in Japan.
Do you have a different information for the BRZ? I thought that the corner was carry over from Wrx (front) and Legacy (rear), and assumed that was Tokico due to that (did not check)
But I see that you’re making pretty bold statements from an area that is not your expertise. You are a powertrain engineer, right? How many yrs of experience?
PS: doesn’t matter if it was Tokico (yes makes brakes!), Sumitomo, Akebono or Nissin. They would still run JASO, not SAE.
And you could ask you friend about the differences on how oems deals with the balance between dyno and vehicle testing.
Ask about K2xx vs K2xx PPV, being both from a major manufacturer in Us
Old 11-19-2021, 09:39 PM   #77
Stonehorsw
Stonehorsw's Avatar
Some pics of Tokico Subaru brakes (Legacy)
Old 11-19-2021, 10:27 PM   #78
Icecreamtruk
I know anecdotal "data" is pretty meaningless. But I stumble across a lot of garbage on the internet, and I tend to rely on my experiences more than "internet data". I didnt do back to back tests, otherwise I woudlnt even be asking for more info here. But I did notice less heat and wear on my own car, the less I was getting into ABS territory. Same car, same driver (albeit with more experience every time), same power train, same brakes, same track, different day. So yeah there are a lot of variables, but never have I personnally seen a case of someone is overheating the brakes while driving properly but I see people (including myself previously) overheating the shit of brakes while being deep into ABS.
The theory should dictate that its the same heat, and ABS or not does not matter, why would I observe such a bias towards ABS generating more heat? Im not bashing for the sake of bashing, just curious as to why and is there some extra energy that is introduced in the system that is not accounted for here (aside from vehicle speed and mass).
Old 11-20-2021, 12:58 AM   #79
timurrrr
timurrrr's Avatar
Now that I think about it... the pulsation of the pads due to operation of ABS involves massive force and some movement.
Force over displacement is work, and that work can only go into heat.
That's where the additional heat might come from?
The absolute amounts of displacement should be minimal (how much do the pads compress?),
but given the high frequency (modern ABS operate at 10+ Hz, IIRC?) and massive overall force, this can be a non-trivial total amount.
Icecreamtruk (11-21-2021)
Old 11-20-2021, 10:06 AM   #80
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
The op is going through brake pads much quicker that we would expect. Decent track pads (almost any brand) are designed for track related braking forces. Many of us are running stock calipers and abs without excessive pad wear. Another way to look at this problem might be to ask, hypothetically, what would you have to do to intentionally ruin a set of pads? Too much left foot braking?
blsfrs is online now   Reply With Quote
The Following User Says Thank You to blsfrs For This Useful Post:
RT-BRZ (11-20-2021)
Old 11-20-2021, 02:38 PM   #81
downshiftxlr8
downshiftxlr8's Avatar
Drives: 2020 86 Hakone
Well this escalated quickly....
downshiftxlr8 is offline   Reply With Quote
Old 11-25-2021, 02:05 PM   #82
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I don't think it's been covered in the 6 pages here but.. Sometimes being slow can be harder on pads.
Before I was "fast", I had braking issues because I braked early and spent too much time on the brake pedal. As I got faster, even though I was converting more speed into the heat, I was spending much less time on the pedal. Less time on the pedal = less heat soak into the system and pad material and more time dissipating heat.
SCCA T4 - FRS
The Following 9 Users Say Thank You to rice_classic For This Useful Post:
blsfrs (11-26-2021), BRZ Hachi (04-14-2022), downshiftxlr8 (11-29-2021), femaledog (11-28-2021), Goingnowherefast (11-25-2021), RToyo86 (11-26-2021), strat61caster (11-26-2021), villainous_frx (11-25-2021), ZDan (11-26-2021)
Old 11-26-2021, 10:15 AM   #83
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Exactly. Anybody who thinks going faster is harder on the brakes, isn't done developing as a driver. Learning how to set up for corners and get more OFF of the brakes sooner will yield faster lap times while putting less heat in the brakes and giving longer pad life.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
CSG Mike (11-28-2021), Icecreamtruk (11-29-2021), RT-BRZ (11-26-2021)
Old 11-26-2021, 10:49 AM   #84
TommyW
TommyW's Avatar
Drives: '13 Whiteout
When my car understeered more I was trail braking more and pads didn't last as long.
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
Original brake pads lasting forever B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 09-07-2019 09:30 PM
Interior Red Stitched Knee Pads Door Pads 2016 brz limited Rear View Mirror sokol Interior Parts (Incl. Lighting) 11 12-25-2018 09:37 PM
Oem shock absorber lasting? Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 04-11-2017 12:21 PM
How long is your winter tires lasting oppiee CANADA 12 04-30-2016 04:22 PM
Tail light condensation lasting weeks sometimes months. jasonojordan Issues | Warranty | Recalls / TSB 4 05-13-2015 05:45 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
