Old 11-08-2021, 05:14 PM   #29
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by 86league View Post
You don't happen to know off hand what the thread size and pitch for those are, do you?
I don't recall, it was a while ago and I believe it was just some nuts I had in my spare hardware bin.
Old 11-09-2021, 10:13 AM   #30
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
FWIW I installed the 25mm/19mm tubular Eibach sways in the Spring with new factory endlinks (originals were totally rusted/fused). 10 track days since installation and I haven't noted any loosening... I have them set to softer front and stiffer rear settings (~150% stiffer than stock front and rear IIRC).
Old 11-09-2021, 10:27 AM   #31
86league
Drives: '13 BRZ Limited
No worries. Turns out they are M12x1.25. Thought it looked familiar and a spare lug nut spun right on
86league is offline   Reply With Quote
Old 11-09-2021, 10:28 AM   #32
86league
Thanks - we'll see if the jam nut fixes my issue. If not, I'll look at getting some different endlinks or re-using the stock ones.
Old 11-10-2021, 01:24 PM   #33
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
First track weekend with the Whiteline front sway and endlinks. Driver side endlink attach to the swaybar came loose EVERY session. I had used blue locktite when installing and had really torqued them down.
Guess I'll try getting putting another nut on them as a jam-nut to see if that holds.
Diagnosing in the paddock is a PITA. Just lifting one side with my jack put enough force on the sway bar to make the end link feel tight. No amount of tugging would make it move or make noise. But I borrowed another drivers jack and raised the whole front end. Once the bar/endlinks were unloaded, it was really obvious the drivers side was loose and would rattle when tugged.
Thanks for the heads-up. Tried the loctite and it wasn't sufficient, but at least it gave me a good idea of what to check to find the suspension rattle.
Locitite advises to increase the torque applied to the nut based on their material specs. From top of my mind, a 10-20% increase, as the friction coefficient increases on the threads and this drives to lower clamp force (torque is the witness, what you want is clamp).
Stonehorsw is offline   Reply With Quote
Old 11-12-2021, 11:22 PM   #34
jflogerzi
jflogerzi's Avatar
I had the same issue with the 20mm Sway and endlinks by WL. We really had to tighten them down to get it from coming loose. But after this all good with 5+ Track days and DD miles as well.
2013 Series 10 FRS #553
RCE SS-1s, SPC LCAs -3/2.3 camber
ARC-8 17x9 SX2 GTs 245s/Koing 17x8 RE71rs 235s
FS: Whiteline 22mm front bar and 16mm rear bar justint5387 Brakes, Suspension, Chassis 7 08-12-2019 08:11 PM
STX handling.. Whiteline 22mm? Skurj Tracking / Autocross / HPDE / Drifting 6 08-22-2018 06:15 PM
FS: Whiteline 16mm Rear Swaybar smg1138 Brakes, Suspension, Chassis 0 04-30-2017 06:37 PM
FS: Strano 22mm Front Swaybar (SOLD) Gliderx Brakes, Suspension, Chassis 2 04-30-2016 12:15 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
