Old 09-28-2021, 12:18 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by 949 Racing View Post
Mac struts don't have a camber curve. It's so small that you can consider it zero.
I know, "camber curve" is just a term to explain camber change during travel, as evident by you knowing what I am talking about.
Old 09-28-2021, 12:40 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS
+1 moderately stiffer front bar does not add understeer, just helps control the roll since like 500# of the cars mass is right between the front struts it needs all the help it can get. Yeah the textbooks say it shouldn't work but
A. Any good textbook caveats with real world data trumping theory
B. You're assuming the factory is making choices for 10/10ths competition driving. They aren't.
Still on OE rear bar with a stiffer front for several years now. I only plan on going back to oe front if I sell the car.
Edit: if you're happy with your cars balance with stock sways, great! Save yourself a couple hundred bucks and dealing with the crappy endlinks that most Swaybars come with. If you feel like it needs a tweak, come on in, the waters fine.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
86league (09-28-2021), Calum (10-01-2021)
Old 09-28-2021, 12:58 PM   #17
Racecomp Engineering
Let's talk about what happens when you add a bigger front swaybar and keep the rear the same size (and no other changes).
For a given corner at a given speed:
  • A larger proportion of the weight transfer now happens at the front, meaning more evenly loaded rear tires and potentially increased understeer.
  • Less body roll, meaning you're less likely to be on the bumpstops as well as making the most of the front camber you do have dialed in (especially with a mac strut car with crap/no camber curve).
The argument is that the change in lateral load distribution in a steady state corner is more than negated by the second part. Sort of like you get -1 front grip point from the first part but +2 front grip points from the 2nd part, resulting in a net +1 front grip points.
That's the argument at least, and it has been somewhat popular approach on Subarus (maybe even more so wtih the AWD ones).
It's an oversimplification (grip points aren't a thing), but yes sometimes a larger front bar does things that don't feel like they fit the textbook expectation. It depends on the rest of the car's set up but can definitely be helpful. I don't like saying it always works and is always good 100% of the time, but can be useful and is worth considering.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
86league (09-28-2021), 949 Racing (09-28-2021), nathand (09-28-2021), NoHaveMSG (09-28-2021)
Old 09-28-2021, 01:18 PM   #18
marco_mc22
Drives: Toyota 86
I’ve made tons of different experiments with both coilovers and stock suspensions (2017 base Showa): for me best one for max grip with 180Tw tires is 22mm front and OEM 15mm rear. For low grip on the road (no track) and medium rates (350/400lbs) I prefer stock bars and even no rear bar for the winter.
My ride height is around -30mm front and -22 to -27 rear, I also have Kw Clubsport camber plates like yours and these help a lot with bump travel.
Keep the front stiff is critical on these cars, as for other strut cars, Team Shirmer Bmw’s are another example, recipe is the same, tons of camber probably around -4 to -5 and huge front bar…same for MR Gt3rs.
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
Old 09-28-2021, 08:08 PM   #19
86league
Drives: '13 BRZ Limited
Was looking at the whiteline 22/16 kit with endlinks and bracing. What are the quality of the whiteline endlinks?
86league is offline   Reply With Quote
Old 09-28-2021, 09:00 PM   #20
strat61caster
Drives: '13 FRS
They're ok, make sure you get a good torque on the nuts that attach to the Swaybar and strut/arm, it might be worth locktiting them, I had issues with them staying torqued but if those nuts stay tight and you don't have camber plates they're good. If you do have camber plates you may have rubbing between the end link and inner fender well at the strut, the ball joint is pretty beefy.
ineedyourdiddly
Old 09-29-2021, 06:19 AM   #21
cueball89
Drives: 16 BRZ 15 impreza
What are your shock settings?
cueball89 is offline   Reply With Quote
Old 09-29-2021, 03:52 PM   #22
86league
I've tried various settings - ended up a little on the "stiffer" side than the initial track recommendation. Depending on the track I vary a click or two.
I'm trying to tune out some understeer in long, steady-state cornering. Shock settings don't seem to change that, but I didn't expect them to.
The Following User Says Thank You to 86league For This Useful Post:
cueball89 (09-29-2021)
Old 09-29-2021, 07:07 PM   #23
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Rake. Easiest to try and typically the last thing we use for fine tuning. In your case, raise rear.
949 Racing is offline   Reply With Quote
Old 09-30-2021, 09:06 AM   #24
86league
Understood. Was just answering cueball89's question about my shock settings.
Thanks for the input/help everyone.
Old 11-08-2021, 12:15 PM   #25
86league
First track weekend with the Whiteline front sway and endlinks. Driver side endlink attach to the swaybar came loose EVERY session. I had used blue locktite when installing and had really torqued them down.
Guess I'll try getting putting another nut on them as a jam-nut to see if that holds.
Diagnosing in the paddock is a PITA. Just lifting one side with my jack put enough force on the sway bar to make the end link feel tight. No amount of tugging would make it move or make noise. But I borrowed another drivers jack and raised the whole front end. Once the bar/endlinks were unloaded, it was really obvious the drivers side was loose and would rattle when tugged.
Thanks for the heads-up. Tried the loctite and it wasn't sufficient, but at least it gave me a good idea of what to check to find the suspension rattle.
strat61caster (11-08-2021)
Old 11-08-2021, 12:22 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is what I do and it works pretty well.
Old 11-08-2021, 01:27 PM   #27
steverife
Drives: 2016 Scion FRS
You definitely want to tighten your end links with the suspension loaded.
steverife is offline   Reply With Quote
Old 11-08-2021, 04:38 PM   #28
86league
You don't happen to know off hand what the thread size and pitch for those are, do you?
FS: Whiteline 22mm front bar and 16mm rear bar justint5387 Brakes, Suspension, Chassis 7 08-12-2019 08:11 PM
STX handling.. Whiteline 22mm? Skurj Tracking / Autocross / HPDE / Drifting 6 08-22-2018 06:15 PM
FS: Whiteline 16mm Rear Swaybar smg1138 Brakes, Suspension, Chassis 0 04-30-2017 06:37 PM
FS: Strano 22mm Front Swaybar (SOLD) Gliderx Brakes, Suspension, Chassis 2 04-30-2016 12:15 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
