Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
#15 |
Drives: 2022 GR86 Neptune, 2017 BRZ with PP
To a future reader who's just starting to explore non-OEM alignment for these cars: -2.3º camber in is not a lot.
It's certainly better than zero, and might be just enough for the street, but if you care about camber (HPDE, AutoX, etc.) you might want to target 3º or even more camber. As another data point, with SPC camber bolts alone (SPC 81305, available on Amazon) I got ~1.75º camber in the front. Combined with "about a full degree of camber" from these top hats, looks like we're getting into the ~2.75º territory. As correctly mentioned in the first post, you probably won't be able to effectively use camber bolts with wheels like 17x9 +40 though. |
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | norcalpb (03-24-2021), strat61caster (03-24-2021) |
#16 | |
Just FYI, going back to back with stock top mounts on the same exact suspension set up...0 change in ride height (as expected, but just wanted to be super sure). Also I feel like the stock mounts are a tiny tiny bit more compliant but it's not that noticeable. The added camber and caster are very noticeable and the stock alignment is no fun.
I think that's the real target for these tops...for more dedicated track use you'll want adjustable camber plates. You could get just over -3 degrees with these on RCE Tarmac 2s or KWs with the OEM 14mm upper bolt though. - Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post: | Cephas (03-24-2021), RToyo86 (05-19-2022), timurrrr (03-24-2021), Ultramaroon (03-24-2021), wparsons (04-23-2022) |
#17 |
not slacking
Thanks, Andrew. I was going to ask about that. All other things equal, moving the bearing off center in the isolator, I was wondering how much more of the high frequency stuff would get through.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Racecomp Engineering (03-24-2021) |
#18 | |
Drives: White Toyota 86
The other way to look at these is the price per performance aspect. Camber bolts win here if all you care about is camber, but camber + caster these come in at half the cost of the cheapest adjustable top hats, and around 1/4 cheaper then the higher end top hats. For those drivers that just like to get a modest upgrade maybe for a spirited daily or light auto x / track (as RCE mentioned) that arent trying to max their camber out and have full adjustability, for the price these are a solid upgrade imo. |
The Following 3 Users Say Thank You to Anthonyc777 For This Useful Post: |
#19 | |
Just wanted to give a reference point for people who actually do plan to do AutoX/track that these hats, even with camber bolts, might not be enough. That's a great data point! |
The Following User Says Thank You to timurrrr For This Useful Post: | Racecomp Engineering (03-24-2021) |
#20 |
Here are my alignment specs. I plan to use these for a season and as I get better as a driver some T2's, KWv3, similar quality coils are in my future.
2013 Series 10 FRS #553
RCE SS-1s, SPC LCAs -3/2.3 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 RE71rs 235s |
The Following User Says Thank You to jflogerzi For This Useful Post: | Racecomp Engineering (03-24-2021) |
#21 | |
not slacking
#22 |
Drives: 17 Asphalt 86
I looked into getting a set of these as they're backordered.
I sent pedders an email and got a response today that their shipment won't be in til the end of May. Last edited by RToyo86; 03-30-2021 at 08:40 AM. |
#23 | |
Drives: 2013 BRZ Limited
![]() I haven't thrown them on yet. With the eibach pro-kit lowering springs, bottom strut bolt to top bolt, and SPC 14mm new bottom bolt, I was able to get to -2.4* camber. I am hoping this puts me at -3* or more, I'll report back once I get them in. My car is 99% DD but I do take it to the track and autocross from time to time. There is no question with RS4s I am currently under-cambered. I don't have the need to go full adjustability and coils and spend $2500 on decent stuff. My goal was to do a mild, budget build to see what the car could do. At NJMP Lighting, I was running high 1:17s, about on par with spec miata front runner lap times, so I'm pretty happy with that. Since then I've added a header, tune, and will be bolting these on, and hoping to find some more time. I think over adjustability is an unneeded and not-well-understood issue for many people, and I liked that these keep NVH at bay too. I'll report back in May when I get back on track.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
The Following 3 Users Say Thank You to dasting For This Useful Post: |
#24 |
Try ebay sellers, I emailed ftspeed, pedders and an ebay seller. Surprisingly the ebay seller said their supplier had some in stock and I was able to get them despite the backorder.
#25 | |
its become a big marketing push with coilovers as well having "32 adjustments" when in reality there's only like 5-10 clicks that actually do something. |
The Following 2 Users Say Thank You to Anthonyc777 For This Useful Post: | BlueWhelan (03-26-2021), Ultramaroon (03-25-2021) |
#26 | |
![]() $130 shipped per. Damn you CAD. |
#27 | |
Anyway, threw these in today. Super easy install, took about 30 minutes all in. And they got me basically exactly as advertised - I went from -2.4* to -3.2*. With my allseasons on and an easy drive to home cheapot, there wasn't a huge difference in feel, but should get me where I need to be on track.
The Following User Says Thank You to dasting For This Useful Post: | jflogerzi (03-30-2021) |
#28 |
Drives: 2017 Toyota 86
Installed Pedders, along with B6 & Yellow springs. Front camber is L -1.34°, R -1.78°, without crash or camber bolts. Preloaded everything to maximum camber direction before tightening, to take advantage of normal clearances.
Pedders top hats and subaru camber bolts... results. | 7 skulls | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 58 | 02-01-2021 06:24 PM |
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? | Jamestl | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 11-16-2018 04:35 PM |
FS: RCE T2 Coilovers w/RCE Camber Plates and MSI Top Hats | jprice130 | Brakes, Suspension, Chassis | 4 | 09-23-2016 09:36 PM |
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder | MyRx | Brakes, Suspension, Chassis | 5 | 10-12-2014 02:14 PM |
