BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
10-16-2020, 04:45 AM | #57 |
Drives: 2013 Subaru BRZ
Header and a good tune for sure.
I'm guilty of getting a CAI after a few years of owning my BRZ. Not sure why as I wasn't expecting gains in any way. A drop in K&N or something similar would have sufficed but I really just like the throaty sound of it. It would probably feel weird if I went back to stock so I'm keeping it =) |
10-16-2020, 09:44 AM | #58 |
The Following User Says Thank You to Ernest72 For This Useful Post: | spcmafia (10-16-2020) |
10-16-2020, 09:48 AM | #59 | |
Drives: 2018 Subaru BRZ
I recently added some good ole' Bayson R Skirts, FL, and rear aprons. 30mm Spacers on the rear and 25 on the front. The car looks amazing, Like it should've looked out of the showroom, in my opinion. Now I'm saving up for FI/SC in the future. I'm going to miss installing parts and what not. Now is all just maintenance from here on.
10-16-2020, 10:00 AM | #60 |
Drives: car
Skip all the NA horsepower mods, except for maybe a drop-in air filter and a header of choice.
Go instead for chassis / suspension / handling improvements. Whiteline transmission mount inserts, subframe mount inserts (positive traction kit), differential cradle inserts. Positive shift kit. And a good set of tires. |
The Following 3 Users Say Thank You to radroach For This Useful Post: |
10-16-2020, 10:50 AM | #61 |
Drives: '13 Whiteout
The NA engine mods are more about getting rid of the torque dip than anything. Header and great tune by Zach and the power is much better however with the torque dip gone the car came alive.
10-21-2020, 03:14 PM | #62 |
Drives: Red 2019 Subaru BRZ
If you are driving the car to the store, say 2,000 - 3500 RPM, you will never have a problem, with torque dip . If you are driving the car hard, say 5,000 - 7,000 RPM, again you will never have a problem with torque dip.
Its only when you are not quite decided it becomes a problem. As its actually a sports car, that's on you. |
The Following 5 Users Say Thank You to PenGun For This Useful Post: | AnalogMan (10-26-2020), JAS4 (10-22-2020), Jdmjunkie (10-21-2020), Ohio Enthusiast (10-24-2020), Windycitystig (10-21-2020) |
10-24-2020, 02:07 PM | #63 |
Drives: 2020 BRZ Limited PP
IF one feels inclined to spend money on an already great car, I would put it into reducing unsprung weight and making thoughtful handling improvements. Work with the car’s strengths, rather than try to turn it into something else.
10-24-2020, 07:21 PM | #64 |
Drives: 2013 FR-S Series 10
Anything that adds a bit of torque to the midrange makes this engine so much better.
Suspension mods are well and good but if i HAD TO i would do the supercharger instead.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
10-25-2020, 05:07 PM | #65 | |
I see this all through this forum. If I wanted to boost an engine that is already at 12.5/1 compression I would rebuild it and bring it in around 8/1, and then boost it. Outside of the rebuild I don't really understand how you can puff on a motor already at the limits, with any real success. Any computers involved are gonna try to keep the motor alive, and will pull boost to do so. Some one explain this to an old man. |
10-25-2020, 05:13 PM | #66 | |
Drives: 2017 86
I installed the full Nameless exhaust & e85 tuned by Zach, the car feels amazing. |
10-25-2020, 05:16 PM | #67 | |
Drives: Crapcan
10-25-2020, 06:23 PM | #68 |
Rust bucket enthusiast
I could see 9:1 if you wanted to run 30PSI on 91 octane, but on this platform, stock compression or 10:1 is plenty stout enough dual modality of injection is awesome
10-26-2020, 07:34 PM | #69 | |
Drives: 2019 BRZ Limited 6 speed Red
I don't see it so much as a 'torque dip' between 3000-3500 rpm, but a torque bump from 1500-3000 rpm. The engine could always be tuned to reduce the torque below 3500 rpm. Then there would be no 'dip', and it would be linear all the way up. But then people would howl about too little torque down low. No engine is perfect. No engine can deliver ideal power delivery throughout the rev range (at least not anywhere near this price). Every (reasonably priced) engine has compromises, peaks and valleys somewhere in the power or torque curves. Quite honestly, I think it's impressive what they were able to accomplish for the cost of this car. One can always want 'more powah' in any car, including this one, but then it wouldn't cost $25k new. |
The Following User Says Thank You to AnalogMan For This Useful Post: | Windycitystig (10-27-2020) |
Similar Threads | ||||
Slim down for ..car gains? | Lakitu | Off-Topic Lounge [WARNING: NO POLITICS] | 33 | 04-27-2018 12:16 PM |
OFT Gains | trev616 | Software Tuning | 14 | 02-07-2018 11:23 AM |
Possible whp gains | kjdd787 | Engine, Exhaust, Transmission | 59 | 01-02-2014 11:59 AM |
Possible whp gains | kjdd787 | Engine, Exhaust, Transmission | 0 | 12-26-2013 05:51 PM |
ECU HP gains? | ender2664 | Engine, Exhaust, Transmission | 45 | 03-31-2013 03:33 PM |
