Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-05-2021, 10:45 AM | #1 |
Drives: 2K19 GT86
E85 Conversion
So I have a half tank of fuel left and I seem to see a fair bit of stations around me with the "may contain 10% ethanol" disclaimer and Im thinking its throwing my fuel trims out of whack, the picture is yesterday after warming up and driving for about 25 min.
I have a catless EL header, catless overpipe/frontpipe/exhaust I'm thinking about converting permanently to E85, but I'm wondering if there's any drawbacks, especially since its not a daily driver for me? |
01-05-2021, 11:31 AM | #2 |
Drives: 2017 Toyota 86
I'm a big fan of the FlexFuel. E85 is fairly available where I live, but I've gone to stations and they've been out, or on a road trip and can't find an option. It's nice to know I can run a tank of 91 if I need to and the system will adapt.
The Following 3 Users Say Thank You to pallen For This Useful Post: |
01-05-2021, 11:42 AM | #3 |
Wheels for Brains
10% ethanol isn't enough to do that to fuel trims. Check your intake and exhaust for leaks
Drawbacks?
The Following User Says Thank You to EndlessAzure For This Useful Post: | czellers (01-05-2021) |
01-05-2021, 11:49 AM | #4 | |
Drives: 2K19 GT86
i'd be using the OFTv2 to flash the e85 tune and back (if needed). |
01-05-2021, 12:00 PM | #5 | |
Drives: 2K19 GT86
01-05-2021, 12:16 PM | #6 |
01-05-2021, 12:49 PM | #7 |
24 percent LTFT is definitely odd. Something is going on with your tune or hardware. Would definitely fix that before moving to E85. I found the easiest way to check for exhaust leaks was to pull the gaskets and see where the soot is collecting or feel around the flanges.
These days I’ve only been using my e85 frs on weekends. Because OFT’s e85 tune will take a few cranks to start in colder weather, you should make sure your battery is strong. Also top off your tank before parking it for long periods of time (to minimize the air in the tank from which it can draw moisture).
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | czellers (01-05-2021) |
01-05-2021, 01:05 PM | #8 | |
Drives: 2K19 GT86
01-05-2021, 01:07 PM | #9 | |
Drives: Crapcan
01-05-2021, 02:09 PM | #10 |
Drives: Q5 + BRZ + M796
^^^ This. I have seen around 6-10% ethanol from pump gas. It shouldn't be an issue at all, as most aftermarket and all factory tunes/components are designed around this fact.
Run flex fuel and not a static tune. E85 can vary a lot depending on the station/source and time of year and geography, and like others have said, you may need to add pump gas to a tank if you find yourself away from an E85 station.
01-05-2021, 03:15 PM | #11 |
Señor Member
Drives: '17 BRZ PP
I would never run e85 without a flex fuel kit installed. just the peace of mind is worth every last penny, not to mention you will get the most of the ethanol with a custom tune for it.
01-05-2021, 06:09 PM | #12 |
Señor Member
Do you have an intake installed?
1974 TA22 Celica
2013 86 GT |
01-05-2021, 11:51 PM | #13 |
Agree with others. Get your fuel trims in line first. And I would rather ditch oft for ecutek and a flex fuel setup. Well worth it IMO.
2013 Series 10 FRS #553
01-06-2021, 09:36 AM | #14 |
Drives: 2K19 GT86
Similar Threads | ||||
Anyone here used this Hub conversion? | jay1989 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 12-19-2014 10:33 PM |
HID Conversion DIY | loong | DIY (Do-It-Yourself) Guides | 55 | 06-27-2014 06:27 PM |
E85 conversion | ender2664 | Engine, Exhaust, Transmission | 6 | 09-15-2013 10:58 PM |
jdm conversion here it is | jdmboss86 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-28-2012 02:26 AM |
LED Conversion | [M] | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 06-18-2012 08:44 PM |
