#253 | |
Howdy
Drives: 2020 BRZ PP
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#254 |
Finally got a decent tune and on a dyno.....
pmcoffee
2013 BRZ Limited AT - Perrin Vortech V3 SC Kit - 93 oct - 9 psi at 7500 rpm - Perrin oil cooler, JDL UEL header, Perrin 2.5" exhaust from header back, high flow cat in Perrin front pipe, 245/35x18 square - Tuner - Ed at Fast Performance Tuning using OFT/Rom Raider https://www.facebook.com/FastPerformanceTuning/ high temp in the test area - 99F SAE correction is 279 hp Tuner commented on the good lockup/low loss with the AT - tuned on Dynocom 5000 fx Last edited by pmcoffee; 09-10-2021 at 02:44 PM. |
#255 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#256 |
Drives: 2019 BRZ tS STi
HKS gt3rs kit on 98.
#257 |
Drives: 2015 midnight blue limited edition.
JRSC- Pump gas (93) on Mustang dyno.
- Jackson Racing C-30 supercharger kit.
- OEM headers and exhaust. - IAG Stage 2 10.5:1 Compression ratio - AEM 340 Fuel pump - ID1050x Fuel injectors - Conditions: Really hot - 85 C ambient. Fuel - 93 Octane pump gas - Tuner - Junior Barros- JRTuned using Mustang dyno Installed at ShiftFast automotive and performance, SC-29730 https://www.facebook.com/shiftfastau...andperformance |
#258 | |
Has anyone here measured an OEM header, exhaust setup on a mustang dyno ? Curious to know if these numbers are on the lower side...
I'm not nearly concerned about the absolute number but just a little concerned if there is potentially a problem... Never had the time to do a baseline without the kit on the car... Quote:
#259 | |
Wes
Instagram: @gt86ws
#260 | |
Drives: brz 2017 hksv2
buddy why dont you at least decat it and raise boost with a smaller pulley to take advantage of the reduced compression? You have at least a potential 350HP at the crank to be reached with your good quality 93 octane fuel, it s a shame to let the car be so underpowered Not saying you have to max it out and risk the engine, but you could easily have more ignition timings with some minor work |
#261 | |
This build has been a nightmare but that's a story for another time but yes that is something I would want to do in the future.. Sent from my Pixel 3 using Tapatalk |
#262 |
Harrop.
The latest power run, Motec, on E85, temp at around 15c on a Dynapack. 65mm pulley, IAG 2.5 10.5:1 comp. , ACE headers, no cat, custom 2.75 single exhaust, 4.66 diff. (motor with about 10,000km hard use) 418.85 Nm @ 5035 rpm 374.27 hp (279 KW) @ 7000 rpm |
#263 |
30 minute maintenance
Drives: My18 wrxsti
SME Spec S (Pulsar G25-550)
98ron E85 8/12psi 3"dump 2.75" Overpipe, High flow catted front pipe and Q300. ID 1050x injectors PVS Tuning ( Standard cars typically make from 100-110kw on this dyno) |
#264 |
Drives: 2014 FRS
2014 FRS MT
- HKS GT2 supercharger kit - 93 octane - ecutek tune - everything else on the car is 100% stock. Stock exhaust. Stock intake box. No idea what clutch is in it, I assume it was replaced at some point in the cars life but it holds ok so far. |
#265 |
Drives: 2015 BRZ WRB
2015 BRZ
JRSC C38 w/ HBP Walbro 450 pump ID1050x Delicious tuning e85 kit 68-70% ethanol JDL 4-2-1 EL headers w/ Nameless combo pipe and perrin 3" CBE
#266 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
2013 Limited JRSC
2013 car, JRSC kit installed 2016
Seven trouble free years so far! A few ponies have escaped but not too bad! Pump gas 92 Octane 290WHP/211 Tq. . I expect the E85 numbers will be +15-20HP |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
