#211 |
Drives: 2017 Toyota 86
#212 | |
Drives: Q5 + BRZ + M796
#213 |
Drives: brz
#214 |
What does it typically make?
Here is more info: https://www.ft86club.com/forums/showthread.php?t=58935
#215 |
Drives: Whiteout FRS
#216 |
That is nuts! How many miles has it run at that power now?
#217 |
Now...that video is old like 2014 old, so the motor probably blew or the engine got built, but I'm curious as well. Obviously the car could be driven without ever using that power, so any years or mileage specified would need to come with specifics.
#218 |
Thats a good point. If you look at the curve, it mostly comes on fast at the high end. Its much more conservative down low. If you don't drive it to redline, you probably never see more than 300.
#219 |
Drives: frs
Blitz turbo kit uncatted
Tomei overripe and front pipe Buddy club spec 2 Deatshwerks fuel pump Grams 550 injectors tune is on high boost spring (10 psi) |
#220 |
Drives: JDL Turbo Twin
JDL Turbo Kit DynoGraph
JDL Turbo Kit
GT2860RS UEL Manifold Open Dump Turboback Exhaust 7psi wastegate spring 93 octane Tuned by Zach @ CSG Very impressed for the 7psi spring |
#221 |
I'm never disappointed when I see Zach's work, this time is no exception. Congrats on the tune, that looks fun as hell!
#222 |
Drives: Turbo GT86 - Fensport Performance
From the UK, graph is BHP, engine power not at the wheels.
- "Stage 4" Avo Turbo kit but with direct fit replacement GTX3076 by Fensport Performance - Stock pistons, machined Manley turbo tuff conrods, ton of oiling mods, 1.45mm head gaskets, Kelford valve springs. 11.6:1 compression, super simple build to test limits of stock pistons. Engine built by me at Fensport Performance - Shell Vpower 99 Ron pump fuel with direct port, pre throttle and turbo volute methanol injection, replacing roughly 20% of fueling with methanol. Pure methanol no water. - Tuned by me at Fensport Performance - www.fensport.co.uk - higher run is 1.4bar with meth. Lower run is 1.3bar no meth. The car is used daily, I'm now at 1.6bar with some more methanol so need to go back and see if we can crack 500bhp on the stock pistons but I am very happy with it so far. |
#223 | |
Drives: Black BRZ
#224 |
I have honestly never seen on a dynograph, someone crack 300whp on the 7psi wastegate spring. Air quality was good that day, air temp around 67F. The listed torque numbers seem to be around what most show on the 7psi spring, but the whp, I don't know if it was just the dyno, or what. Zach is an elite tuner. Very excited to have had the opportunity to be tuned by him.
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
