#211 |
Drives: 2013 Scion FRS Whiteout
#212 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Tiny gap for me. Not noticeable. Regular torque widget.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#213 |
Drives: BRZ-L
What do you connect the Brown Factory Amp Turn On wire (From the 10 pin connector) to?
- I think this is how it goes, let me know if this is correct; Brown wire from the car harness goes to the blue wire on the metra harness, then that blue wire connects to the blue/white remote amp turn on wire from the JVC harness along with the blue wire from the antenna adapter. ? Last edited by CIAGDDS; 01-02-2015 at 05:58 AM. |
#214 | |
Not sure about the brown wire. Only 1 wire wasn't used for me. As for the antenna power on the metra antenna harness there's a blue wire that needs to be connected to the other harness (with a lot of wires) power antenna line.
#215 |
When I turn on the car, for first five seconds I get a small whine/white noise sound when using the aux. After that everything is clear, is this normal?
#216 | |
Another Nexus 7 install: Clean and Easy
Same setup as me? If so no.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 01-02-2015 at 09:01 PM. |
#217 |
Drives: BRZ-L
Got it all setup today. The DAC is definitely worth it, couldn't believe the sound difference. Last question, is there a way to have the Nexus automatically start playing music when it wakes from deep sleep?
#218 | |
Use a program called tasker. Should help you set that up.
The Following User Says Thank You to Sojhinn For This Useful Post: | CIAGDDS (01-03-2015) |
#219 |
@CIAGDDS how's it working? How's auto droid?
#220 | |
Drives: BRZ-L
The Following User Says Thank You to CIAGDDS For This Useful Post: | Sojhinn (01-05-2015) |
#221 | |
Thanks for the heads up. Keep us informed. Sounds like the 310bt may be a better unit now.
#222 |
Drives: BRZ-L
I got Tasker up and running. I have it set to open my music player (DoubleTwist) as soon as the screen turns on, it then selects the now playing tab and starts the music. Pretty sweet.
The Following User Says Thank You to CIAGDDS For This Useful Post: | Sojhinn (01-08-2015) |
#223 | |
Nice! Im glad I could help. Do you mind running down your purchase list? I think I will update the first post.
#224 | |
Drives: BRZ-L
(1) Nexus 7 (2012) with 4G Cellular (Craigslist) - $150.00 unopened (2) JVC KDX310BT (Best Buy) - $90 (3) Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker (Ebay) - $3.75 (4) Metra 40-LX11 Antenna Adaptor (Amazon) - $11.50 (5) Sabrent USB 2.0 Virtual External 7.1 Surround Sound Adapter (Amazon) - $5.99 (6) Micro USB Host OTG cable (Ebay) - $3.69 (7) BAFX Products - Bluetooth OBD2 scan tool (Amazon) - $23.99 (8) AX-ToyUSB Adapter (Ebay) - Didn’t use because I ended up using the JVC USB port to power the Nexus - $8.99 Android Apps: Autodroid 1.2 Rom - Free Media Utilities - Free Nova Launcher - Free DoubleTwist Music - Free Tasker - $2.99 Torque - $4.95 Total - 305.85 |
Well that was easy... | FRyeS | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 10-15-2013 11:04 AM |
Nexus 7 in FR-S/BRZ | DjDATZ | Electronics | Audio | NAV | Infotainment | 4 | 06-09-2013 08:10 PM |
Nexus 7 Car Audio DIY | thejevans | Electronics | Audio | NAV | Infotainment | 32 | 05-10-2013 03:55 PM |
How easy/difficult is it to keep WRB "clean"? | ayau | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 32 | 06-17-2012 10:17 PM |
