Old 11-15-2022, 05:02 PM   #1429
redlined600
redlined600's Avatar
Drives: Fr-s
Let's talk coolant necks. I thought maybe you guys could lend some insight since you've already been there.
Here is the TSX coolant neck
Here is the head
Finally here is the Kpower miata neck. To me, due to the design this is ripe for trapping air bubbles in the back of the head. I don't think there is a way to solve that with this neck but I'm thinking it's at least worth smoothing out to flow better. Does the 86 specific neck look different in this area?
redlined600 is online now   Reply With Quote
Old 11-15-2022, 05:17 PM   #1430
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
86 water neck has the same size and location opening. Only thing I could think of to modify for air entrapment is a bleed valve drilled/tapped into that same cavity. I believe there is already a tapped hole above that cavity with the Miata neck. Maybe there is an off the shelf threaded bleed valve that can be placed there and solve the problem.
I will say that once I added the second heater line bleeding became less of an issue.
captain awesome is offline   Reply With Quote
Old 11-15-2022, 05:58 PM   #1431
RedReplicant
Drives: None
Agreed, I have not had any issue with bleeding mine but I have had the second line the entire time.
RedReplicant is offline   Reply With Quote
Old 11-15-2022, 11:10 PM   #1432
Ebush
Drives: 2017 Hot Lava 86
Can't believe kpower wants us to purchase that relay. It should have been there in the beginning.
Ebush is offline   Reply With Quote
The Following 5 Users Say Thank You to Ebush For This Useful Post:
DocWalt (11-16-2022), endless_pain (11-18-2022), Irace86.2.0 (11-16-2022), Jdmjunkie (11-16-2022), Pat (11-16-2022)
Old 11-16-2022, 12:10 AM   #1433
RedReplicant
Drives: None
There are a number of things that I feel that way about, I think it is kinda weird how quiet the FB group is in terms of issues / post-release updates / extremely suggested deviations from the base kit / etc.
The Following 7 Users Say Thank You to RedReplicant For This Useful Post:
B T (11-16-2022), captain awesome (11-16-2022), endless_pain (11-18-2022), funkjaw (11-16-2022), Irace86.2.0 (11-16-2022), Jdmjunkie (11-16-2022), ML (11-16-2022)
Old 11-16-2022, 09:40 AM   #1434
funkjaw
Drives: 16' WWB
Anyone have a shifter extension with this kit? Does it retain reverse lockout? Does it add any NVH? Drove a porsche for a few days loved how high the shift knob was.....
funkjaw is offline   Reply With Quote
Old 11-16-2022, 09:43 AM   #1435
captain awesome
Wears Pants
I'm running a Shifter Solutions 1" extension. It does add a smidge of NVH but I like it considerably more than without.
LINK to the one I bought HERE
The Following User Says Thank You to captain awesome For This Useful Post:
RedReplicant (11-16-2022)
Old 11-16-2022, 11:32 AM   #1436
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I think a few people are reusing IRP shifters too with the kit right?
On a separate note, does anybody know of anyone running the TF Header? I've been tempted by it even though its pricey, only thing I can find so far is that they test fit it on one 86. But no users that I can find of it yet, maybe I need to look at other chassis they sell to?
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 11-16-2022, 11:56 AM   #1437
RedReplicant
Drives: None
Are you talking about this one?
https://www.tf-works.com/tf-k-series...ise-na-header/
If you can ask for a dimension that it extends out from the valve cover one of us could measure for interference issues / how far it is from the radiator hose and frame rail to give you an idea for heat management.
Old 11-16-2022, 12:53 PM   #1438
Kelse92
At the track
Yup, that one, I'll have to check and see if they have any dimensions, thanks for the tip!
Old 11-16-2022, 02:18 PM   #1439
ML
ML's Avatar
Drives: 13 White MT FR-S
just run the water line to the rad THROUGH the loops
The Following User Says Thank You to ML For This Useful Post:
Old 11-16-2022, 04:20 PM   #1440
Evil Rocky
Drives: FRS
I been looking at that one and hoping to try to test it since I am local to them.
Evil Rocky is offline   Reply With Quote
The Following 2 Users Say Thank You to Evil Rocky For This Useful Post:
Jdmjunkie (11-16-2022), Kelse92 (11-16-2022)
Old 11-16-2022, 04:40 PM   #1441
Kelse92
At the track
Awesome please do, I know they fit it to this car with a ZF5 (but lot more clearance with that trans I imagine), and that owner went turbo and never actually ran this part on the car they just took photos so I'm trying to investigate as much as I can before I buy, but I like the idea of it. https://www.instagram.com/p/CZJywnIu..._web_copy_link
Old 11-18-2022, 10:50 AM   #1442
captain awesome
Wears Pants
Pics of the fuel pump relay as requested:
CLICK ME
The Following 4 Users Say Thank You to captain awesome For This Useful Post:
funkjaw (11-18-2022), Irace86.2.0 (11-18-2022), Jdmjunkie (11-18-2022), RedReplicant (11-18-2022)
Search this Thread:
Advanced Search
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
