Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-14-2018, 07:36 PM | #15 |
Drives: 2015 FR-S
02-16-2018, 03:46 PM | #16 | |
Drives: 2015 FR-S
I realized that it was possible that the threads from the fitting were the source of the leak and the oil was running into the crack around the sandwich plate/ spacer O-ring. When I did the original install my local auto parts shop was out of the "recommended" high temp thread sealant: So I went to a hardware store and used another: Both are oil resistant and rated for high psi and temps of 400 degrees+ so I figured I was fine. But now I'm thinking that the thread seal was the problem. So I found a shop that had the recommended thread sealant and took everything the thing apart to redo the fittings. When I talked to FBM they said some some customers over tightened the fittings and cracked the sandwich plate. I was relieved to see my sandwich plate looked alright I cleaned all the threads with a wire bristle brush and cloth and reinstalled with the Peratex thread sealant. I'm going to give it a day or two to set, then I come back with results. (The oil you can see on the sandwich plate came from the inside the filter when I screwed it back on) |
The Following User Says Thank You to Sachmet43 For This Useful Post: | Zentec (02-18-2018) |
02-17-2018, 02:58 PM | #17 |
義理チョコ
The Mocal plate is tapped with a half inch BSPP (British Standard Pipe Parallel) thread. Looks like Full Blown cheaped out on their kit. Also, that pattern seen on the mating surface is the result of a final finishing process called 'tumbling.' It's done after the final cut to microscopically deburr the surface.
http://www.batinc.net/mocal.htm Oil Cooler Take-Off & Sandwich Plates
The Following User Says Thank You to Ultramaroon For This Useful Post: | Zentec (02-18-2018) |
02-18-2018, 08:22 AM | #18 | |
Drives: 2013 FRS
I'm curious to see the next update to this thread to find out what the cause of this leak ended up being. |
02-18-2018, 03:14 PM | #19 | |
義理チョコ
02-18-2018, 05:07 PM | #20 |
02-18-2018, 05:15 PM | #21 |
Drives: 2013 FRS
Ohhhh I see. Full Blown supplied their own male fittings instead of using the fittings that mocal offers with the plate. I knew that the Mocal was tapped to BSPP but I didn't realize those fittings were npt. Thanks for the clarification. And good observation.
02-21-2018, 06:56 PM | #22 |
Drives: 2015 FR-S
Sorry for the delay.
So after giving the new thread sealent lots of time to set, I started the car up today to check the leak. [ame="https://www.youtube.com/watch?v=AiwQZk0yovA"]Startup[/ame] Now rather than seeping oil, it is pissing oil and from a new spot. I am extremely frustrated. The original problem was oil leaking from the threaded point where the fittings screw into the sandwich plate. This leak seems to be gone, at least at idle. Now there is a huge leak coming from the FAR SIDE OF THE HOSE FITTING. WTF. The oil seems to be coming from the back side of the female end of the hose (which was already installed when the kit was shipped.) [ame="https://www.youtube.com/watch?v=5X9vhmK5cAs"]VID 20180221 152155859 - YouTube[/ame] |
02-22-2018, 12:16 PM | #23 |
Drives: Scion FRS
Hi, sorry you are having issues with the kit. The leak you are experiencing looks like the AN compression connection is not tight enough. To get a good seal, you want to hold the 45 degree fitting with a wrench and tighten the -10 hose end.
I see you have high temp thread sealant on the flare ends. You should't have to put any thread sealants at this joint. Regarding the other issue where it leaks on the o-ring. Mocal had a design flaw on their spacer. The spacer would bottom out on the oil filter adapter before the o-rings gets a good crush on it. They have since redesigned it and replaced the defective adapters. If you have any questions or concerns, please give us a call and ask for LJ 952-431-1399 Thanks. |
02-24-2018, 06:56 PM | #24 |
Drives: 2013 FRS
I just installed my mocal sandwich plate today. Everything looks good, I even had clearance on that DI fuel line. Though after some hard driving it does look like there is somewhat of a leak coming from one of the Mocal supplied BSPP fittings. I don't doubt that a little extra torque will fix this issue. Overall I'm quite happy. Though I would have been more happy if there was space around the bolt to fit a typical socket. I could hardly find anything to get on there.
05-08-2018, 02:49 PM | #25 | |
Drives: 2015 FR-S
05-08-2018, 03:00 PM | #26 |
Drives: 2015 FR-S
All leaks 98% solved. See solutions above.
With the help of Full Blown Motorsports I was able to get all the of leaks 98% taken care of. There is still a tiny smudge of oil around the o-rings occasionally, but it has not gotten any worse after a couple months of daily driving, spirited track driving and a good hard track day. Review after a couple months At the end of the day I would give this cooler 7/10 The position of the cooler pushes up against the wheel well liner a bit, so the fit is not perfect IMO, but it gets the job done. I found the instructions that came with the cooler to be light on the details for someone like me who was never done this kind of install. But in the end I like the mounting location, because it's out of the way, but the cooler was not optimally effective until I installed a vent in the fog light space (http://www.ft86speedfactory.com/oem-...2013-ft86.html). With the vent the cooler is doing very well. Here's some data I took over the course of three track days: 12/10/17 at Thunderhill East(no cooler) - 120, 128,131 (70 ambient temps) 1/27/18 at Laguna Seca (cooler)- 116 118 116 116 118 (62 ambient) 4/27/18 at Thunderhill West (cooler and vent) - 105 110 (72 ambient) Ill be watching oil temps and may put together some ducting and to force more air through the cooler in the future. Full Blown Motorsport did a good job sending me a replacement spacer when they thought that was the problem, and was eventually able to help me find the solution. I would do business with them again. Thank you to everyone who posted helping me out. Sorry for the delay. Last edited by Sachmet43; 05-04-2021 at 12:12 PM. |
The Following User Says Thank You to Sachmet43 For This Useful Post: | Sgtfluffy16 (01-22-2019) |
07-15-2018, 12:51 PM | #27 |
Drives: 10-Series Turbo FR-S #2483
I'm going to kind of bump an old thread here, I just recently went through and dremmelled out my vents, was surprisingly easy and the vent material was kind of fun to work with.
I didn't have temp numbers beforehand but can report that I have noticed my temps were sitting around 110C, after numerous hard pulls and heavy driving for a solid 30 minutes, after getting to operating temp on an 87F day. This is with an SBD400 turbo on the car as well. Great temps, but unfortunately I have fallen victim to the same leak. Looks to only be at the base of the sandwich plate, and fortunately only under really heavy loads. (High temps, hard driving and high pressure) Going to be doing an oil change today, and am looking to see if we can fix up the leak. I'll post later some results. |
05-04-2021, 12:21 PM | #28 |
Drives: 2015 FR-S
Final Review After 2 years of daily driving and track driving
At the end of the day this oil cooler had a number of issues: -The position of the cooler pushes the wheel liner into the wheel. The rubbing isn't terrible, but it causes a burning smell during regular driving and especially when doing tight turns like in a parking garage. -After 2 years of tinkering I was never able to get the oil leak problem 100% solved, but it never got worse. (Dribbles of oil at most). -Even with adding the fog light vent, the position of the oil cooler did not allow enough air flow to keep my oil temps in the safe range under heavy track use. On hot days I would have oil temps as high as 120 deg C, which is into the danger zone for our oil. Bottom Line For these issues I am switching to another oil cooler. In the end I give this cooler a 3/10, because it just didn't get the job done. |
The Following 3 Users Say Thank You to Sachmet43 For This Useful Post: |
Similar Threads | ||||
Full blown oil cooler kit | Bigbell224 | Engine, Exhaust, Bolt-Ons | 5 | 05-04-2016 03:48 PM |
Full Blown Oil Cooler | willharp360 | Engine, Exhaust, Bolt-Ons | 2 | 03-13-2016 02:05 PM |
Fs: Full Blown Motorsports oil cooler | protpibe | Engine, Exhaust, Bolt-Ons | 1 | 03-25-2015 06:36 PM |
Full Blown Motorsports Vs Beatrush catch can | JordanWho | Engine, Exhaust, Transmission | 20 | 02-13-2014 11:08 AM |
FS: Full Blown Oil Cooler Kit | darthwong1138 | Engine, Exhaust, Bolt-Ons | 0 | 12-16-2013 01:00 PM |
