Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-12-2013, 01:41 AM | #1 |
Drives: BRZ, STI, 535, Tiffin Allegro
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I'm getting this CEL while running hard on the track.
I've cleared it several times and it keeps coming back. Anyone else seeing it? Any known fixes? |
03-12-2013, 01:54 AM | #2 |
You running a unichip?
The Following User Says Thank You to Visconti For This Useful Post: | Tim_Asphalt_FRS (03-12-2013) |
03-12-2013, 02:01 AM | #3 |
I've gotten this CEL both with and without my tune.
The engine seems to be running fine otherwise. Using a prior "older tune" I did get some misfires and the CEL in question. |
03-12-2013, 08:17 AM | #4 |
Drives: 2013 Asphalt FR-S
remove the unichip and see if it goes away... interceptors can make sensitive monitors very unhappy. If you put it back to stock and still have the issue then you can at least rule out the unichip and start looking at replacing the coilpack etc.
~Namaste~ |
03-12-2013, 09:06 AM | #5 |
Driving Coach
Were you tracking with a unichip or ecutek tune?
03-12-2013, 10:38 AM | #6 |
I don't use or have a Unichip.
My car does have an EcuTek tune and the CEL first showed up while the tune was installed. I have since removed the tune, back to stock, and was able to reproduce the CEL but only on the track running hard. |
03-12-2013, 10:41 AM | #7 |
Site Moderator
Drives: Stuff
Mine gets it also, completely stock ECU. At the dealership for a coil pack replacement right now actually. I'll see in a few weeks if it fixes it when I'm at the track again.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
03-12-2013, 10:58 AM | #8 |
Driving Coach
hmm are we uncovering a coil pack weakness or defect?
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | kombatlion (02-20-2014), sato (08-19-2014) |
03-12-2013, 11:23 AM | #9 |
Did the dealer jump straight to the coils or did they check the plugs first? I'm wondering if we should be running a cooler plug on the track.
03-12-2013, 11:43 AM | #10 | |
From a quick look at the manual it may be an overheating problem with no. 1 coil pack:
~Namaste~ |
The Following User Says Thank You to mad_sb For This Useful Post: | heeltoe86 (11-09-2013) |
03-12-2013, 12:27 PM | #11 |
Drives: Perrin/VORTECH Supercharger TestBRZ
tuned in to this thread..this sorta thing, potential for warranty replacement can worry the FI consumer..my audi went thru a coil pack recall, but no aftermarket FI stuff there
what is the intelligent way to see if a colder plug works better(whatever that is to a coil pack)or provided 'benefits' short of my paying a tuner to run dyno and some exh gas analysis? is this cause we're boosting and tuning? I doubt its the plugs so early on, but ya never know, if its happening with OE tuning, then there maybe something there in the way of breakage potential we have uncovered, is it a call to carry a spare? I'm curious to know what the dealership finds/replaces |
03-12-2013, 12:45 PM | #12 |
Curious cat.
Drives: 86 GT base M/T - Red
Stumbled on this thread while searching...
Just picked up my car from the dealer after throwing a CEL. Dealer said the car was throwing an ignition related code. Coil pack on one bank replaced + dealer ECU reflash = problem solved so far.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
The Following User Says Thank You to ultra For This Useful Post: | Teknian_Culprate13 (10-09-2014) |
03-12-2013, 01:13 PM | #13 |
Site Moderator
Drives: Stuff
Well technically they started the warranty claim off my picture of the code scanner, so they didn't see the car until this morning after the parts already arrived. I'm not sure what they are specifically checking first today.
-Dave
03-12-2013, 04:44 PM | #14 |
Site Moderator
Drives: Stuff
OK so they replaced the Cyl 1 coil pack.. I'll see if it happens again.
-Dave
Similar Threads | ||||
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
