BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
04-09-2023, 06:43 PM | #1 |
Drives: 22 BRZ
DIY B pillar seatbelt trim protector
I got tired of looking at the plastic protective film that comes on the interior b pillar so I started looking into a solution.
Stickerfab sells carbon fiber wrap but I've heard that they can be tricky to install and maybe the adhesion isn't the best. https://www.stickerfab.com/collectio...40800268648559 I also saw these which look better but are expensive. https://www.86worx.com/axis-parts-se...kle-guard.html Instead of shelling out for these two options, I went to Amazon and bought this 3 pack of 8x10 leather repair patch. I figured if this shit is tough and sticky enough to work on a leather couch you sit on, they should have no issue sticking to the plastic trim in the car. This is the set I bought. You get 3 x810 sheets for $14. https://www.amazon.com/dp/B09WKD2M9M...t_details&th=1 I peeled off the plastic that came with the car and measured it. 6 x 10. So, I chopped 2 inches off one of the sheets. I cleaned the b pillar for max adhesion and applied the leather patch. Pull back the weather stripping and there's even a very convenient clip that you can use to line up the patch. Put the edge you cut under the weather stripping and smooth it on. Here's a look at the clip that I lined up the bottom of the leather with. And here's what the leather looks like stuck on Another angle... The leather seems quite sticky and it laid nice and flat. $14 and 20 minutes of work. Maybe not the most necessary thing but I don't like seeing interior trim get dinged up so this works. |
The Following 3 Users Say Thank You to AK2112 For This Useful Post: |
04-09-2023, 07:38 PM | #2 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Big improvement. Nice job!
The Following User Says Thank You to gkubed For This Useful Post: | AK2112 (04-09-2023) |
04-09-2023, 10:29 PM | #3 |
Drives: '22 BRZ
Only once have I ever had an issue with that plastic getting marked from the seatbelt, and that was mainly due to having a cg lock in place.
04-09-2023, 11:45 PM | #4 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
I Thought that was for protection when people are going in/out of the back seat?
04-17-2023, 02:57 PM | #5 |
Drives: 22 BRZ
04-17-2023, 11:44 PM | #6 |
Drives: White Limited '23 6MT
Same. Ripped it off as soon as I saw this thread. It came off pretty easily, which tells me it was meant to be removed.
Similar Threads | ||||
WTB: oem shifter trim, steering wheel trim, and door handle trim | frs_caskey | Want-To-Buy Requests | 3 | 03-28-2017 05:38 PM |
▀▄▀▄ Vivid Racing | Cusco 86/BRZ C pillar brace + NEW trim | vividracing | Interior Parts (Incl. Lighting) | 2 | 07-21-2016 07:55 PM |
B pillar trim removal | lmabee | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 03-21-2015 11:36 PM |
How to remove rear seat cushion, quarter panel trim, and B pillar trim | zombieite | DIY (Do-It-Yourself) Guides | 0 | 03-21-2015 11:32 PM |
A pillar trim popping off | Stratoside | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 07-02-2014 08:23 PM |
