07-09-2015, 01:50 PM | #2801 | |
Drives: FR-S Firestorm 6MT
+42 offset is okay but a bit on the high side and will limit the width of tires you can run unless you add spacers (which effectively changes offset). I recently mounted a set of 18x9 +42 BremmerKraft wheels with 245/35R18 tires for a customer. We had enough clearance to the inside strut to even add crash bolts but was still very tight and he has some light rubbing during autox. Should be fine for daily driving and everything translates to 17" the same with a 245/40R17 tire. |
07-09-2015, 07:15 PM | #2802 | ||
07-16-2015, 05:13 PM | #2803 |
Drives: gray 2015 scion frs
07-16-2015, 05:48 PM | #2804 | |
Look at the meaty tire thread. Then look at the aggressive wheel thread. I would suggest 245/35-18. |
07-16-2015, 07:47 PM | #2805 |
Drives: A work in progress.
Would 18x9.5 +38 wheels with 245/40/18 tires work on stock struts and Eibach Pro kit springs.
I know it'll poke a bit, but would the tires this size cause any rubbing on the spring perch or anything? Want to make sure before I make the purchase. |
07-21-2015, 08:51 AM | #2806 |
Drives: 09' 335i / Soon to be FRS Owner
About to pull the trigger on some CCW Lm20's for my street set-up and would like some solid information from the experts on here. I'm lowered about 1.5" on ST Coils and thinking about going with 18x9.5 square set-up running 255/35/18. What offset will I want to get? I don't want to dial in a large amount of camber and have it look ridiculous. Should I be looking at a different size wheel or can this be done and look clean? I haven't seen many people with the CCW set-up.
Thanks. |
07-26-2015, 06:23 PM | #2807 | |
Drives: 2013 BRZ Limited WRB
On stock suspension, how will 245/35/18 look on 18x9.5+40 ?
07-26-2015, 09:03 PM | #2808 |
Hi, I just recently bought wheels (MB Battles).
Size: 18 X 8, 30 offset. 5 X 114.3 lug pattern I have conversion adapters 15mm to make them fit my 5 X 100. so that would cancel it out to 15 offset. I'm lowered 3 inches on BC Racing coilovers that have front adjustable camber plates. & I also have PBM rear lower control arms. Front camber: -2.5 (Stock Wheel Setup) Rear camber: -2.0 (Stock Wheel Setup) I plan to either get tire sizes of: 225/35 or 235/35 I was wondering if I would have to add more camber to make these fit or possibly pull the fenders for more clearance? Also debating on raising the car 1" all around if it doesn't fit. PICTURES FOR REFERENCE: Last edited by FRZ-BRS; 07-26-2015 at 10:19 PM. |
07-27-2015, 04:49 PM | #2809 |
Drives: GT-86
I need help with my tire set up on for the LRS 1.0. I want these rims and know they will fit but am not sure if the front will rub against the stock TRD suspension which is 1 inch lower than the stock FR-S. They are ADVID 1 - 18x9.5+38 offset. I want to buy 235/40/18 tires for it but am uncertain if I will run into problems with the TRD stock setup up front. Anyone have these wheels already installed? Or a wheel with the same dimensions? I don't want to resort to adding wheel spacers up front just to clear the suspension. I really need some one with the TRD springs installed to answer this question I guess.
2015 FR-S 1.0 RS - TRD # 297
07-28-2015, 12:49 PM | #2810 | |
Drives: 2013 Scion FR-S Whiteout 6MT
If you have eibach springs and stock otherwise, and are going to 18x9.5 +38 you dont need to dry fit, that is exactly what i and others have run, it fits w no rubbing. The issues are they poke outside the fenders and they are close on the inside so you cannot really camber at all. Sent from my iPhone using Tapatalk |
07-28-2015, 12:49 PM | #2811 | |
See my other recent replies on this exact setup Sent from my iPhone using Tapatalk |
08-01-2015, 04:17 PM | #2812 |
Drives: frs
You guys think I'll run into any issues running 18x8.5 +33 with 245 40?
08-11-2015, 12:33 AM | #2813 |
Drives: Lava scion Fr-S
I was planning on putting new wheels and tires on soon.
i was looking at Avant Garde M310's 18X9 +30, TSW NURBURGRING 17X8 +35MM, or ENKEI RAIJIN 18X8 +48MM. I wanted to go with a 235/45 would there be any rubbing issues with these?? really wanted to make sure before i buy. i also plan on lowering 1inch. Thanks |
08-14-2015, 12:17 AM | #2814 |
Drives: Toyota 86
Appreciate thoughts on:
Front: 18x7 et35 with 225/40/18 Rear: 18x7.5 et35 with 235/40/18 TRD wheels with either Michelin PS2 or Pirelli P-Zero Rosso with stock suspension. Can't run the TRD recommended 215/40 up front due to local load rating compliance rules. |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
