01-29-2014, 03:21 AM | #2101 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
as a square setup? No
Unless you plan to modify the car with a widebody kit, crazy camber or stuff like that
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
01-29-2014, 03:30 AM | #2102 | |
The Following User Says Thank You to Killerbee For This Useful Post: | bellison13 (01-29-2014) |
01-29-2014, 09:02 AM | #2103 |
Bellison
Drives: 2013 Whiteout FR-S
01-29-2014, 10:21 AM | #2104 |
You're welcome
Offset is +35, or 35mm as you noticed it, however since there is positiv and negativ offset +35 is the easier way to state it (as 35mm could be positiv or negativ)
The Following User Says Thank You to Killerbee For This Useful Post: | bellison13 (01-30-2014) |
01-29-2014, 09:15 PM | #2105 |
Drives: Raven FRS
Anyone know if a 19x10 50 offset will fit in the front
With 225/35 tires |
01-30-2014, 02:31 AM | #2106 | |
either you're making a bad joke or you do not understand what those sizes mean. Do you have a picture or something of what you want to achieve, this may help me understand what you're looking for and I may be more helpfull than this.
01-30-2014, 08:49 AM | #2107 |
Drives: 2014 Subaru BRZ
2007 Outback Sport Wheels
Hi all!
Quick question on fitment - looking at a set of 2007 Outback Sport wheels 16x6.5" +55 offset 205/55/16 These are just going to be my winters and wanted to make sure I wasn't going to have any clearance issues. I only saw one post with similar dimensions - the wheel in this post was from 97-04 Legacy GT wheels. http://www.ft86club.com/forums/showthread.php?t=56662 |
01-30-2014, 09:01 AM | #2108 | |
Drives: Raven FRS
This These are the wheels, 19x8.5 front 45 offset 19x10 back 50 offset On my wife's FRS I'm running 18x9.5 square 38 offset with 225/40, so I'm wondering if I can even fit a 10" on the front with that offset and still clear the coilover. |
01-30-2014, 11:11 AM | #2109 |
Drives: Raven Scion FR-S
Will a 235/40-18 front 265/35-18 rear +38 fit while lowered 1" on eibach pro kit springs?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
02-02-2014, 04:32 AM | #2110 | ||
I guess you know this, but 225 tires on 9.5" rims, or even 10" is anything else than save to drive. I just wanted to mention it.
02-02-2014, 08:42 AM | #2111 | |
Shit sorry I didn't say it's an 8.5 front and 9.5 rear lol do u know of anyone with this setup ? Maybe pics ? Thanks though for letting me know
02-04-2014, 01:42 PM | #2112 |
Drives: 2013 Ultramarine FR-S
Hey guys.. figured I would ask here to make sure before I pull the trigger on my new wheels.
Looking at getting a set of 17x8 +48 (square) Advan RSII, running stock suspension. I will probably go with michelin PSS.. I am thinking either 225/45r17 or 235/45r17, is that right? which would fit better? From what I can tell from the wheel directory, this setup is 10mm off from flush (38) in the front, which means it will be sucked in by 10mm.. will that be noticeable? I checked the wheel directory and the only people with this wheel are running 18s.. does anyone have any pictures of this spec? I would like to see the concavity. Also, with these wheels would I need a seperate set of lugs? is there a big difference with the aftermarket lugs? (other than looks) Part of the reason I chose this wheel was that it seemed to have some concavity even with an 8 or 8.5 inch wide wheel, but if you guys can recommend other wheels of the same style I would be interested. |
02-04-2014, 01:59 PM | #2113 | |
Drives: '13 BRZ Ltd WRB
225/45 is only slightly larger diameter than stock. 235/45 is noticeably taller, but I ran this size for a while (at stock height on 17x9) and it looked fine. This changes your effective gearing, but you may or may not even notice that. I'd say stick with the 225s on an 8" wheel. They are plenty sticky at that width and are a good fit for the sidewall. I have the exact same tires on the same size wheel, but I'm also using spacers (F: 22mm, R: 23mm) to flush it out a bit. We have acorn lug nuts (tapered) so check with the wheel manufacturer or vendor and confirm that they use the same (not rounded or flat). That said, go buy locking lug nuts anyway. No use getting some Advan$ just to have them stolen and find your car sitting on the rotors one morning. Before spacers: After spacers:
02-04-2014, 04:12 PM | #2114 | |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
