06-14-2024, 10:20 AM | #351 |
Drives: 2013 frs base
06-14-2024, 10:39 AM | #352 | |
Drives: Toyota GT86
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following User Says Thank You to autoracer86 For This Useful Post: | blsfrs (06-14-2024) |
06-14-2024, 11:59 AM | #353 | |
Drives: 2020 BRZ Sport Tech RS
06-14-2024, 02:11 PM | #355 | |
From what little bit that I have heard about the GR cup cars, they don't seemed overly concerned about it.. |
06-14-2024, 04:23 PM | #356 | |
Drives: Toyota GT86
There is hopefully a fix coming soon from verus
06-14-2024, 06:22 PM | #357 |
I think an Accusump does mitigate the problem to some degree but nobody seems to have blown up their engine because of temporary drops in pressure. Granted, any drop in pressure is not ideal, but is it really an engine killer?
06-15-2024, 01:51 AM | #358 | |
Drives: Toyota GT86
Btrgarge is also testing and did the accusump but I don’t think it helped much. I’m sure the damage from the pressure drops are very track dependent IE ones with long sweepers. The problem definitely exists as for how much damage it’s causing who knows. It’s oil temps/pressure all over again lol
The Following User Says Thank You to autoracer86 For This Useful Post: | blsfrs (06-16-2024) |
06-27-2024, 08:43 AM | #359 |
The FA24's seem to be getting cheaper all the time.
https://www.ebay.com/itm/15552164496...AABnH5W2aIOAvg |
The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
09-24-2024, 11:39 PM | #360 |
ASM is offering a Hybrid FA20 Heads with FA24 short block for pretty cheap when I asked price. For me Transport costs are a major hurdle.
2013 Series 10 FRS #553
09-25-2024, 09:38 PM | #361 | |
For RSM to ship my engine was around $550 (MN to Va). Liftgate service (Estes). The guy parked the truck in the street and wheeled the engine into my garage. The FA20/24 hybrid seems like a lot of extra work since doing the 24 swap is basically a bolt in and plug n play deal. I hope people aren't put off because of my code problem. My issue is a one off deal. RSM has done a bunch of these kit/swaps with out issue. And, it may be my ecu and not have anything to do with the kit. RSM has been in touch with me on almost a weekly basis helping me solve the problem. |
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (09-25-2024) |
09-26-2024, 03:12 AM | #362 | |
10-01-2024, 08:01 AM | #363 |
Drives: '23 BRZ
FA24 heads can breathe in 20% more displacement without choking at the same 7000rpm power-peak, and pull to the same 7400rpm rev-limiter as the FA20, I'd be very surprised the FA20 heads will give any performance benefits. Would bet the opposite. Even if there's a bump in compression ratio.
The Following 4 Users Say Thank You to ZDan For This Useful Post: |
10-02-2024, 11:20 AM | #364 |
Drives: None
Someone I talk with online put together a hybrid and it made a smidge more midrange between 5000-5800 but after that it lost 20whp over a complete FA24 on the same dyno by 6800.
Blue FA20 with boltons Red Hybrid FA20 head, FA24 block Green FA24
The Following 19 Users Say Thank You to RedReplicant For This Useful Post: | BatStig (10-02-2024), bcj (10-02-2024), beanswv17 (10-02-2024), blsfrs (10-04-2024), Code Monkey (10-02-2024), finch1750 (10-05-2024), jflogerzi (10-05-2024), kmbkk (10-02-2024), new2subaru (10-05-2024), NoHaveMSG (10-02-2024), PulsarBeeerz (10-02-2024), Racecomp Engineering (10-02-2024), redlined600 (10-02-2024), Spankopotomous (10-03-2024), T-Steve (10-02-2024), Tatsu333 (10-02-2024), Teseo (10-02-2024), ZC6_STi (10-02-2024), ZDan (10-03-2024) |
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
