Old 06-28-2015, 06:45 PM   #15
aagun
Drives: 86
Originally Posted by Kodename47 View Post
Practically speaking, you would have to find the addresses for the data that controls AVCS at idle. The standard cam tables aren't in operation.
It shouldn't cause any issues though, but will likely use more fuel.
that's it only way .
aagun is offline   Reply With Quote
Old 06-29-2015, 12:31 AM   #16
wizzo
Drives: 2014 Toyota 86
Thanks for chiming in guys Well maybe someone on the forum that knows his way through the ECU could chime in. Thanks for the input.
wizzo is offline   Reply With Quote
Old 06-29-2015, 12:50 AM   #17
serialk11r
Drives: '06 AM V8V Coupe
Idle is not controlled by the AVCS tables you see in Romraider or whatever, like a bunch of people already said.
That said, you CAN introduce lope at low load by adding exhaust cam retard. About 10 degrees should do the trick. I got some pops with 5 degrees at 1600-2000rpm. Basically the overlap will be diluting your charge to the point where it has trouble burning. However your car will be shaking a bit, which may or may not be annoying.
The Following User Says Thank You to serialk11r For This Useful Post:
HoustonM (03-17-2016)
Old 08-03-2017, 03:53 PM   #18
Kodename47
Kodename47's Avatar
Drives: UK GT86
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-03-2017, 04:19 PM   #19
Teseo
Drives: frs
Page doesnt work
Teseo is online now   Reply With Quote
The Following User Says Thank You to Teseo For This Useful Post:
Kodename47 (08-03-2017)
Old 08-03-2017, 04:39 PM   #20
Dakines
http://www.ft86club.com/forums/showt...t=ghost&page=7
some on has did it, but he did not share it.
Dakines is offline   Reply With Quote
Old 08-03-2017, 05:58 PM   #21
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Teseo View Post
Page doesnt work
Fixed
.: Stealth 86 :.
Kodename 47 DJ:
Teseo (08-03-2017)
Old 08-03-2017, 06:56 PM   #22
nocoolname
So pretty much, possibly raise the target idle speed to 1000 RPM and then retard ignition timing for 1000 RPM in the first couple of low load cells?
My line of thinking is that if you have a higher idle, when it stumbles from the timing retard it won't drop low enough to kill the engine. The reason to change the ignition timing at the target idle speed is that's the only way to have the car hit that at idle, with doing it at 1000 RPM is all the OFT maps I've looked at have an 800 RPM row so as the idle drops, it will interpolate and the timing will pick back up to shoo the idle back up.
I think all of this though would just make the car sound like it had the "Honda cough" i.e. bad IAC valve and a hunting idle though.
Or I could be way off on all this.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 08-03-2017, 09:12 PM   #23
Teseo
Drives: frs
So thats the sound of the new fiesta? Besides cats getting damage, what others parts are involded too?
Old 08-04-2017, 01:23 PM   #24
Kodename47
Kodename47's Avatar
Drives: UK GT86
The main timing tables have no control over idle. What I'd imagine you could do is make the idle ignition timing tables negative/low values until just under your idle RPM and then make them nearer MBT so it suddenly makes power and increases RPM. I've now played with these tables to make the idle really steady so would think it could make this effect if you can get the timing low enough.
.: Stealth 86 :.
Kodename 47 DJ:
nocoolname (08-05-2017)
Old 08-05-2017, 10:10 AM   #25
nocoolname
Good point on the timing table not controlling idle. I'm still learning this car.
Old 08-07-2017, 12:04 AM   #26
Mr Nerd
Mr Nerd's Avatar
Trying this as we speak.
If my neighbors get mad that I disturbed their Mariachi Karaoke session I'm telling them that Kodename47 made me do it.
Sent from my Galaxy S8+ using Tapatalk
Mr Nerd is offline   Reply With Quote
Old 09-01-2021, 09:21 PM   #27
brzlegend
Drives: brz
Originally Posted by wizzo View Post
Hey everyone,
This is a wierd post, but if anyone has seen the ghost cam tune for the Mustang 5.0's its on the same thought train.
So the 86 has dual vvti like the 5.0 mustang, ive seen people doing wierd things with their tune like causing pops and bangs at a certain load. Has anyone ever looked into using overlap through retarding or advancing the cams or whatever it is that is done with the dual vvti to create the idle of an aggressively cammed boxer engine.
Would i have it on my car if it was possible? Probably for the laugh.
Would i get bored of it? Probably after a while.
Raise minimum low(idle) AVCS intake angle to around 30 or so, you also could retard the exhaust the same way.
When vvt is enabled avcs is always active, idle or not. I know that's not popular belief but ecutek shows it operating, watch the duty cycle and solinoid current. When vvt enabled the pin is unlocked and it's running off the oil chambers in the phasers.
brzlegend is offline   Reply With Quote
Ghost of Akina's 2013 Firestorm FRS Ghost of Akina Member's Car Journals 3 08-22-2015 01:51 AM
Ghost Car/Dad vividracing Off-Topic Lounge [WARNING: NO POLITICS] 4 07-23-2014 05:51 PM
Ghost Lights DuroSquad Cosmetic Modification (Interior/Exterior/Lighting) 7 07-04-2014 07:14 AM
Ghost's BRZ Build RurumariGhost NY / NJ / CT / PA 5 05-23-2013 09:31 PM
