Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
11-03-2019, 09:35 PM | #1 |
Drives: 2014 BRZ Limited A/T
Installed: TWS T66F in 17x8, Stock Tire Size
Oem+ build, used lightweight hankook ventus v12 in stock size to retain nimbleness.
Lost 7lbs per corner Because of the lightness, car feels more “floaty” which takes getting used to, but the grip and nimbleness is definitely better. Loving that it aint a stretch at all, and im sticking with OEM suspension. Sent from my iPhone using Tapatalk |
The Following 10 Users Say Thank You to leevanf For This Useful Post: | beltax90 (11-18-2019), Iceman (11-13-2019), new2subaru (11-04-2019), Racecomp Engineering (11-04-2019), RToyo86 (11-06-2019), SuperTom (01-03-2020), Tristor (11-04-2019), why? (11-06-2019), Will BRZ (11-04-2019), Yoniyama (11-19-2019) |
11-04-2019, 09:51 PM | #2 |
Weight Weenie
Drives: 15 FR-S
Nice wheels! Would you consider a lip or splitter for a bit of downforce?
11-04-2019, 09:59 PM | #3 |
Damn that's crazy...
Drives: 2015 BRZ
Looks really good. 7 pounds is a lot!
11-04-2019, 10:03 PM | #4 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
These look amazing
11-05-2019, 04:25 PM | #6 |
Try dropping the pressure a little bit at a time and see if the floaty feel goes away.
The Following User Says Thank You to gravitylover For This Useful Post: | new2subaru (11-05-2019) |
11-05-2019, 05:36 PM | #7 |
Drives: 2017 BRZ (Sold), 2023 GR86
I really want these in 18x9.5. So cool.
11-06-2019, 07:15 AM | #8 |
11-06-2019, 07:15 AM | #9 |
11-06-2019, 07:42 AM | #10 | |
Weight Weenie
Drives: 15 FR-S
https://www.86worx.com/trd-front-lip.html More pics https://www.evasivemotorsports.com/mm5/merchant.mvc?Screen=PROD&Product_Code=TRD-MS341-18002 Modellista kit https://www.86worx.com/modellista-front-lip.html |
11-06-2019, 04:46 PM | #11 |
Things like sidewall stiffness and rubber compound will play a big part of how a car this light feels. Most of these tires are intended for cars that are 500 pounds, or more, heavier than these cars so the recommended pressure will be different due to them having a beefier casing to support the heavier car. I'd try by dropping it a 1/2 psi at each corner (when cold), the rear will probably need to go down more than the front.
11-17-2019, 11:25 PM | #12 | |
Thats brilliant. I notice the car feels less floaty after a few weeks without air (at about 33 psi) Sent from my iPhone using Tapatalk |
The Following User Says Thank You to leevanf For This Useful Post: | gravitylover (11-18-2019) |
11-18-2019, 12:39 AM | #13 |
Drives: Car
Wow. Those look great. What are the offsets?
11-18-2019, 12:43 AM | #14 |
Similar Threads | ||||
17x8.25 tire size 225/45, 235/45 or 245/40? | tracerit | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-24-2022 01:03 PM |
WTB: Stock size tire - a set of 4 | FMJ | Canada Classifieds | 3 | 06-22-2018 02:25 PM |
Recommend tire size for 17x8.5 +20? | yutinggao | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-21-2016 10:21 AM |
Tire size for 17x8.5 +32 +42 | giraffee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-06-2013 08:17 PM |
Which tire size for 17x8.5? | giraffee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-11-2013 07:26 PM |
