Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-29-2020, 12:25 PM | #1 |
Drives: 2013 Subaru BRZ
Bushing replacement in high mileage cars
Are there any bushings that are worth replacing in a car that has some mileage on it? I'm approaching 125k miles and curious if there's anything I should bother replacing as far as bushings go since I feel like it's an overlooked component.
I haven't found any information on this and I've been curious. |
07-29-2020, 01:06 PM | #2 |
I'm working on a post about this kind of thing.
Short version is to check anything that's rubber and anything that moves. Definitely look at: front control arm bushings (especially the bigger one) front top mounts transmission mount rear endlinks tie rods and ball joints - Andrew |
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | DarkPira7e (07-29-2020), Grady (07-30-2020), grumpysnapper (07-30-2020), norcalpb (07-29-2020), Pat (08-01-2020), Thefalls (08-01-2020) |
07-29-2020, 01:22 PM | #3 |
Rust bucket enthusiast
Don't forget that your suspension itself takes a lot of abuse! Even after about 60k miles, my stock suspension had about had it ( granted, I've thrashed my car) I'm replacing it with new performance pack dampers, but anything OE would be awesome and give the car new life.
The Following User Says Thank You to DarkPira7e For This Useful Post: | Racecomp Engineering (07-29-2020) |
07-29-2020, 01:36 PM | #4 | |
07-30-2020, 11:07 AM | #5 |
Suspension bushes do a lot of hard work and my car does rough roads often, so I renewed all of my (standard) rubber bushes at 30000km when I installed new dampers.
Its not that difficult or expensive, and it is a small price to pay to get the suspension back to near factory fresh. Its also a good excuse to have a good look/inspection at what's happening down there, and to get your alignments into shape |
07-30-2020, 11:29 AM | #6 | |
Drives: Crapcan
That being said the front control arm bushing is a pain in the ass to swap. No easy way to hold it level.
07-30-2020, 12:23 PM | #7 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Can always just buy the whole control arm assembly from the dealer
The Following User Says Thank You to skylinekin For This Useful Post: | Grady (07-30-2020) |
07-30-2020, 12:38 PM | #8 | |
Drives: Crapcan
J/K I decided to give the Whiteline antidive kit a try. So I had to swap them with stock.
07-30-2020, 01:10 PM | #9 | |
For the original question. Shocks and bushings degrade slow you wont notice anything is wrong. After 100k miles if you replace all bushing and shocks you can make you car feel like it is new again. |
08-01-2020, 08:39 AM | #10 |
Drives: 13 White MT FR-S
this is what you want: https://energysuspension.com/product/catalog
I have changed every bushing on the car with their kits and I'm at 120k miles.
08-02-2020, 01:07 AM | #11 |
[insert cool phrase here]
Drives: BRZ Premium
Oem or aftermarket as long as it gets replaced it will feel brand new.
Depending on how much abuse or even driving hard on the track or even bad roads will ware out the suspension quickly. If I had the money to spend I would get that done.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Similar Threads | ||||
Is there a high mileage thread for BRZ? | qqzj | BRZ First-Gen (2012+) -- General Topics | 33 | 03-01-2020 09:42 PM |
Buying high mileage | nutnu | Issues | Warranty | Recalls / TSB | 10 | 07-26-2018 02:14 PM |
Scion relatively high mileage new car? | GhostGo | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-11-2014 06:25 AM |
Will these cars hold up to high mileage? | wbradley | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 04-02-2013 02:05 PM |
DIY bushing replacement method | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 03-01-2013 04:11 PM |
