Forced Induction Turbo, Supercharger, Methanol, Nitrous |
02-01-2021, 11:53 PM | #1 |
Drives: Crystal White BRZ
JDL turbo down pipe bolts seized
So, JDL turbo (gt28r) 2 of the 4 bolts on down pipe to turbo are seized.. tried to tighten & loses them & they are not budging ! what are my options before I cut them & re-tap the holes
02-02-2021, 06:41 AM | #2 |
Rust bucket enthusiast
Soak them in PB Blaster. Spray liberally and let sit for a half hour. Do it again.
See if they loosen at all. If they do a little and stop, re-tighten and then loosen again. Get a small torch and heat those suckers up. Be mindful of the heat and don't melt anything. Are they bolts, or nuts on turbo studs? If they are nuts, you can buy a nut splitter. Don't be afraid to remove the turbo hotside and downpipe so that it's out of the car and you have more freedom to get at it- everything advantage you can get yourself is one you should take
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
02-02-2021, 02:11 PM | #3 |
That Guy
Drives: 2013 asphalt FRS MT
Impact gun set to a very low setting and a metric fuck ton of patience. Just let it hammer away. They'll come out. Most likely
02-02-2021, 10:32 PM | #4 | |
02-02-2021, 11:23 PM | #5 |
Done, removed. Of course previous owner had a small cross thread
The Following User Says Thank You to Limitless_BRZ For This Useful Post: | DarkPira7e (02-03-2021) |
02-03-2021, 06:35 AM | #6 |
So what got them out?!
02-03-2021, 10:26 AM | #7 |
The Following 2 Users Say Thank You to Limitless_BRZ For This Useful Post: | CSG Mike (02-04-2021), DarkPira7e (02-03-2021) |
02-07-2021, 09:41 PM | #8 |
This is the where the bolts are going to be re-treaded.
02-08-2021, 05:23 PM | #9 |
That Guy
Wow, all five of them‽
Yeah, I'd retread them for now, but I'd take the turbo out and disassemble it / inspect it. I'd guess there's a tolerance for axial shaft play. I'd measure that if at all possible as well as inspect the blades for cracking and chips. And a rebuild kit might be in order either way. If someone was that careless you never know what else will be wrong. |
02-09-2021, 07:50 PM | #10 | |
yeah i ended up stopping by JDL auto and picking up a whole new turbo to be safe. ill mess with the old one and rebuild it/sell it when im done |
The Following User Says Thank You to Limitless_BRZ For This Useful Post: | Calum (02-10-2021) |
Similar Threads | ||||
Camber bolts or crash bolts for max spring perch clearance? | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-29-2021 11:53 AM |
Rear toe cam bolt seized? | rmr | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-20-2019 08:44 PM |
WTB STOCK FRONT PIPE BOLTS | elgin63 | Want-To-Buy Requests | 0 | 12-03-2017 08:07 PM |
front pipe to over pipe bolts | Taydork | Hawaii | 0 | 07-07-2015 08:02 PM |
Seized Motor - Need options/help | GWiZ | Issues | Warranty | Recalls / TSB | 33 | 03-13-2015 05:36 PM |
