05-02-2022, 03:55 PM | #407 |
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
How much camber? Been trying to build some wheels and have held off for the past 6 months to figure out fitment I want to go 18X9 ET35 up front and ET38-40 in rear. I like the way your fitment looks just hardly anyone posts how much camber they are running.
The Following User Says Thank You to NikolaiCherepanov For This Useful Post: | timurrrr (05-02-2022) |
05-02-2022, 04:18 PM | #408 | |
Drives: '22 GR86
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD |
05-02-2022, 05:23 PM | #409 |
05-04-2022, 11:05 AM | #410 |
Drives: 2018 brz
05-04-2022, 08:29 PM | #411 |
Drives: '22 GR86
Yes. Little less than 1 inch drop. About the same effect as on my last gen.
05-05-2022, 10:23 AM | #412 | |
Drives: '23 BRZ Limited
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | timurrrr (05-05-2022) |
05-05-2022, 11:04 PM | #413 | |
Drives: It has 4 wheels
It looks great by the way! |
05-06-2022, 09:00 AM | #414 |
Drives: 2022 Subaru BRZ
Thanks, I've driven it decently hard. I did finally hear what sounded like some rubbing hitting a pretty large bump I didn't see to avoid yesterday. But haven't gone to a canyon since install to really test, planning to do that this weekend. I'm just not seeing any evidence yet of wear on tires or fenders to suggest there is consistent rubbing. I have driven about 700 miles so far with the new wheels and tires.
The Following User Says Thank You to mlarz41 For This Useful Post: | bradsm87 (05-06-2022) |
05-06-2022, 06:38 PM | #415 | |
I plan to lower it about an inch, -2.2 front and -1.5 rear camber. I think I'll go 17x9 ET43 or ET42 with 245/40 all round and 6-7mm spacers up front. |
05-14-2022, 03:50 PM | #416 | |
Drives: '22 GR86
The Following 2 Users Say Thank You to staples323 For This Useful Post: | Pat (07-19-2022), PrayForRain (05-15-2022) |
05-14-2022, 07:42 PM | #417 | |
Drives: 2022 BRZ sport-tech
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
05-15-2022, 05:29 AM | #418 |
Drives: '22 GR86
Unsure, It's very close looking. Would have to pull spring from coilover to fully compress and see and I'm far too lazy for that
05-15-2022, 09:53 AM | #419 |
Drives: 2022 Subaru BRZ Limited MT
I've had this car for almost three months and have had a great time doing some small mods (PowerStop brake pads, Castrol SRF brake fluid, K&N Air Filter, TRD Duckbill Spoiler) and taking it to the track for a couple of HPDE1 events. I live in the Northeast and want to get a separate set of wheels / tires for non-Winter daily driver and track day duty and could really use some advice as I've read through this entire thread and am still not confident about fitment.
I'd like to get flush fitment and avoid replacing the stock suspension or rolling / pulling fenders if possible. I like the Aodhan AH09 (and its price) which comes in 18", 8.5", ET35, but I'm not sure if the offset is too aggressive on a 8.5" wide wheel (I know it would be on a 9.5" wheel). In this post from Panda Grahams it looks like he was able to achieve flush fitment with a 0.5" thinner wheel and I'd be using the same 225 tire size. With that being said I don't see any Gen2 BRZs or 86s with the AH09 wheels online, which doesn't make me hopeful. To throw another variable into the mix I'll also be installing these fender flares which say they "add another 8mm" (inspiration here). The installation guide for the fender flares requires minimal drilling inside the wheel well so I think this is something I could do on my own without any invasive cutting / welding. I guess it's fairly obvious the tires will looks more 'tucked' with the additional 8mm added to fender? Ultimately, I'm looking for a flush fitment without any rubbing. If anyone sees any obvious mistakes with AH09 / 225 + 40R / fender flare setup, please let me know. |
05-15-2022, 08:47 PM | #420 | |
I think 225s on 8.5s with +35 offset would probably be OK with the above mod, presuming you'll be running no camber adjustment (exact camber depends on how lowered it is). |
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
