05-17-2019, 08:26 PM | #2381 |
Drives: 2013 FR-S Series 10
I wouldn't mind ripping mine out and replacing it with the newer leather (vinyl?) dash.
The Following User Says Thank You to Decep For This Useful Post: | roosahorn (05-17-2019) |
05-17-2019, 08:48 PM | #2382 |
Drives: 2013 FRS 10 Series
05-18-2019, 12:29 AM | #2383 | |
Drives: FRS 10 Series
Damn shame. If it’s already a lost cause I might see if I can wire it into something else, or maybe just rig up my own solution to replace the lighting? I’ll have to take a look this weekend Sent from my iPhone using Tapatalk |
05-18-2019, 08:47 AM | #2384 |
Drives: 2013 FR-S 10 series [755]
I once heard that if you prove the ownership of the car such as VIN and Registration, they can help you order the parts.
IG: @rearwheelclub
The Following User Says Thank You to FR-Sky For This Useful Post: | SC10N (03-24-2020) |
05-19-2019, 01:43 PM | #2385 |
Drives: FRS 10 Series MT
Still loving mine at 55k. Though my EL stopped working too.
Sent from my SM-G955U using Tapatalk |
05-19-2019, 02:00 PM | #2386 | |
FR-S 10 Series Registry
I took a look at mine, looks like the controller might be done and the EL strip is burned out. I can’t find any info on replacing it, and something tells me that the OEM parts would be hella expensive. Upon pulling my dash apart it looks to be a plain EL strip behind the panel, I picked one up that’s the same size off eBay. I think I’ll make a vinyl overlay to have it say series 10 + my number or something and wire it into my cabin accent lighting. If it works out I think it’ll look cool Edit: also I love the purple! |
05-20-2019, 01:05 PM | #2387 | |
Drives: Scion FR-S Series 10 #2462
05-21-2019, 11:01 AM | #2389 |
Drives: 10 Series FRS
Over 100k on mine... daily it (2nd owner).
My back Emblem stopped working... at the beginning of ownership I was slightly embarassed that it would light up so bright at night. Now I miss it... |
05-22-2019, 01:23 PM | #2390 | |
05-22-2019, 01:52 PM | #2391 |
Mine still works!!!! @70k
IG: @rearwheelclub
The Following User Says Thank You to FR-Sky For This Useful Post: | Cheeky (05-22-2019) |
05-22-2019, 08:04 PM | #2392 |
Same, all emblems working @ 50k.
For you guys whose are not working, did you do any electrical mods like stereo, headlight etc? Wonder if its a fuse or wiring thing. |
05-22-2019, 08:40 PM | #2393 | |
My emblems still work after stereo and headlight mods, it’s just the EL that’s gone. From what I can tell they’re on a pretty separate system from the rest of the wiring, the emblems and the EL each have their own controllers. |
05-24-2019, 09:01 PM | #2394 |
Ladies and gents I fixed it! Ignore my plastic wrap on the ground. Like I suspected the burned out EL panel had a film over it with the scion logo and lettering, so I peeled that off and applied it to my eBay EL strip. I wanted to leave the stock EL wiring alone in case I run into OEM parts someday so I ran an inverter off a tap from the drivers side fusebox, and routed a connector up to the hole behind the dashboard. That way if it ever burns out again it should be a super easy fix, simple disconnect and swap. It is now on all the time, but personally I like it that way, since it’s very unobtrusive, matches my accent lighting, and you can’t see it at all in the daytime. It’s also a ~20$ repair instead of a 400$+ repair if you can even find the parts. If anyone wants a more detailed list of what I did feel free to reach out. |
Similar Threads | ||||
**Tennessee Registry** | Xryn | Southeast | 140 | 11-02-2022 12:31 PM |
Mid-Atlantic Owners Registry. | IloveBaldEagles | Mid-Atlantic | 366 | 10-24-2022 08:55 PM |
86 Owners of New England - Registry | MannyO | New England | 251 | 06-06-2022 01:04 PM |
Issue updating Registry. | IloveBaldEagles | Site Announcements / Questions / Issues | 1 | 03-18-2013 07:19 PM |
First 86 Registry: 2013 Scion FR-S | Flipside909 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-18-2012 05:54 PM |
