05-18-2020, 09:04 AM | #225 |
Drives: 2015 Subaru BRZ Limited DGM
on track testing?
Has anyone had the chance to do much on track testing with the trac box yet? Sadly our season got shut down before it even got started, and I didn't even get a snowy winter to go drifting around parking lots.
05-18-2020, 09:36 AM | #226 |
Drives: 13 White MT FR-S
Grip driving, works great! Drifting, still had to pull the ABS fuse.
05-18-2020, 09:42 AM | #227 |
Drives: 2013 BRZ Limited 6MT
That pedal dance button is great hahaha
05-18-2020, 10:37 AM | #228 |
Drives: Crapcan
It just puts the car in pedal dance mode. There is tons of info on pedal dance on track.
05-18-2020, 10:46 AM | #229 |
Yes, I had been running pedal dance on track. I was curious if anyone had noticed a difference between PD, Trac Box, and Beastronix, or if they were all the same. My testing was limited to "does it turn the TC light on"?
05-18-2020, 10:49 AM | #230 | |
Drives: Nevermorange FRS
Small push switch. Depending on what options you chose with the tracbox will determine whether you get a on/off switch or a momentary switch.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | churchx (05-18-2020) |
05-18-2020, 10:50 AM | #231 |
Drives: Crapcan
All the Trac Box and Beastronix box do is initiate PD mode without having to do it manually and heat soak the crap out of your engine bay while trying to get the coolant up to the required temp. You can initiate PD at anytime.
05-18-2020, 12:00 PM | #232 |
My VTEC fluid is full
Drives: EFF JAY
I think the question is that.. 'does the TracBox implementation actually work'? All we see at this point (because of lack of testing / track closed) is that the trac lights are on.
05-18-2020, 01:55 PM | #233 |
See posts #133-138.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | NoHaveMSG (05-18-2020) |
05-18-2020, 02:38 PM | #234 |
Drives: EFF JAY
05-18-2020, 03:30 PM | #235 | ||
I'm including Gerald's explanation from page 11 for the rest of the participating audience... This box uses the command over the Canbus and the TCLP isn't a CANBUS command but PD is. (Bold/emphasis below is mine) Quote:
SCCA T4 - FRS
05-19-2020, 08:49 AM | #236 | |
Drives: Black BRZ - STX
Just to re-iterate, the TCLP is a SWITCH hardwired to ABS. The Trac Box is hardwired to the CAN bus only. Therefore, it's not some elaborate trick he's playing on you...the trac box doesn't even connect to the TC switch... Also, these CAN commands for pedal dance are very basic. It's actually much easier to do it using the pedal dance commands over CAN than it would be to tie into the TC switch. Nice work Gerald! |
05-19-2020, 10:35 PM | #237 |
just noticed when I turn the fans on using the box it only turns the passenger side fan on. Is that by design or do I have an issue?
Similar Threads | ||||
WTB a Beastronix 86 Nanny unit | tonylop33 | Want-To-Buy Requests | 0 | 09-25-2018 07:14 PM |
FS: Beastronix 86 Nanny - SOLD | Agent_D | Engine, Exhaust, Bolt-Ons | 3 | 05-09-2018 01:57 PM |
Beastronix Install | HoonThis | Software Tuning | 4 | 06-08-2017 10:02 PM |
Flex Fuel Kit and Beastronix 86Nanny Trac/VSC | Juanito08 | Engine, Exhaust, Bolt-Ons | 7 | 05-10-2017 02:20 PM |
Beastronix - 86 Nanny , Speed Academy version | brzaapi | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 07-05-2016 11:17 AM |
