Old 07-04-2019, 03:20 PM   #1
guanqi89
guanqi89's Avatar
Drives: 2015 Scion FR-S
Major engine failure 45km before warranty expires
Hey guys, I made a post last year about getting my short block replaced under warranty (78k kms back then). And asked if my car would be reliable, and if I should sell since I probably can't afford to pay for an engine replacement out of warranty and out of pocket. You can see the old thread linked below:
http://www.ft86club.com/forums/showt...59#post3108659
Well, it happened again. Car broke down, with mechanical knocking noise coming from the engine. It's currently sitting at the dealer awaiting diagnoses with 99955km on the odometer (barely within the 100k power train warranty)
I don't know if the failure is identical to the last time. But the question remains. Should I sell? Should I keep?
  • Obviously a car like mine that needed to get engine replaced twice (potentially) will definitely take a hit on the used car market.
  • I however probably can't afford to pay for a repair like this out of pocket (dealer mentioned the work will cost around 12k without warranty)
  • How much does an engine replacement cost if it's done at an independent shop?
  • How much is a non-running FRS worth? Can I get any money back if engine breaks shortly after this replacement?
Comments to these above points can really help me decide. Looking forward to your comments. Thanks guys!
guanqi89 is offline   Reply With Quote
Old 07-04-2019, 03:36 PM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
I would find a used engine and have that installed, which should be possible for a few grand... nobody on here can give you an exact price though, youíll just need to contact a few shops and get a labor quote for installing a used engine. Your car wonít be worth much in non-running condition. Again, we canít tell you what you are entitled to if the replacement engine breaks... that is up to whatever warranty is provided by the supplier of the engine.
Itís up to you if you choose to keep the car after this 3rd engine has been installed... I would be inclined to sell it on at that point since something about you and this car does not seem to mesh well
NCtoBRZ is offline   Reply With Quote
Old 07-04-2019, 03:50 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
Unfortunately these cars don’t hold their value well. A 2015 frs with 65k miles is only worth around 14k. Not sure how being on a third shortblock would effect that price either. So factor that in if you sell and buy a new car.
Dealers always way overcharge. A 2015 FA20 crate engine with 50k miles is under 3k$ and a shop should be able to do an engine swap for about 2k$. You can even buy a built short block for under 3k$ install would probably be closer to 3k$ though. Or buy a built head and short block same time have them assemble it so basically a built long block for about 6k$ and then install should be around 2.5k$ Or learn to do the work yourself and really save money.
Old 07-04-2019, 04:00 PM   #4
guanqi89
guanqi89's Avatar
Originally Posted by 86TOYO2k17 View Post
Unfortunately these cars donít hold their value well. A 2015 frs with 65k miles is only worth around 14k. Not sure how being on a third shortblock would effect that price either. So factor that in if you sell and buy a new car.
I'm mentally prepared to dump the car for 10k lol. Any less, I would probably risk it and keep driving. Think it could fetch 7-8k in non-running condition? It would be a decent base for a project car I assume
Old 07-04-2019, 07:20 PM   #5
maslin
Benz Tech
Drives: 2017 BRZ Premium
A car without an engine is like $2500 tops. Dead cars aren’t worth money.
Get it fixed and trade it in. Dealers don’t care how many engines it’s had. Trade and move on. 10-12k is probably all it’s worth on trade. You can buy a low low miles used 18 for under 20k, a 2015 with relatively high miles isn’t going to be anywhere near that.
2017 PP series.yellow with 10k miles for 18.5. Sadly, our cars don’t hold value. Gotta have fun while they last, they aren’t an investment.
https://www.cars.com/vehicledetail/d...1141/overview/
maslin is offline   Reply With Quote
Old 07-04-2019, 07:42 PM   #6
CoolHandMoss
Drives: 2013 FRS
If you do get it replaced under warranty, ask for an extended warranty for the new engine whether you intend to keep it or not. If you can get one out of them it would help resale.
CoolHandMoss is offline   Reply With Quote
Old 07-04-2019, 09:53 PM   #7
86MLR
86MLR's Avatar
Why are your engines dying?
Poor fuel
Not warming it up
Lots of limiter
Every effect does have a cause, find the cause to stop the effect
The Following User Says Thank You to 86MLR For This Useful Post:
Lowe1978 (07-05-2019)
Old 07-05-2019, 09:38 AM   #8
guanqi89
guanqi89's Avatar
Poor fuel
Not warming it up
Lots of limiter
On my old engine (from new to first replacement). I have driven it enthusiastically with 4 or 5 track days. Otherwise, the car is maintained on schedule, good fuel (shell V power stuff).
But I more or less babied the thing since the last short block replacement. Really not sure what it could be...
Old 07-05-2019, 09:45 AM   #9
evoto86
Drives: manual Toyota 86
Did you get it re-tuned or reflashed when you changed the short block ?
evoto86 is offline   Reply With Quote
Old 07-05-2019, 12:02 PM   #10
Lantanafrs2
Drives: 2013 frs red
See if they warranty it again before making any decisions. In my case they replaced long block after their short block failed.
Lantanafrs2 is online now   Reply With Quote
Old 07-05-2019, 06:22 PM   #11
86MLR
86MLR's Avatar
This, long block, but.....
If you lunch a engine bits of metal can end up eveywhere.
If you don't strip, clean, and resemble the whole engine and replace some of the auxiliaries you can be in for a world of hurt.
Replacing oil lines/coolers, radiators may/will be necessary depending on initial damage.
Lantanafrs2 (07-05-2019)
Old 07-05-2019, 07:13 PM   #12
Impureclient
Drives: 2015 FR-S
If it ends up $3k engine+ $2k labor then compare that to what will you lose when trading it in.
If the are really close then it seems a safer bet that you won't go through a 3rd engine and I'd just keep it.
I kind of went through a similar situation with my prior car but all 3, yes on 4th engine now, were outside warranty.
I have had the car for more than 20 years now(son now drives it) so even after all those engines in and out,
I still was better off keeping it since adding it all up it works out to be only a little over $1k each year I spent for over
20 years of it in service.
It was also a $1k engine and no more than $1k labor each time though. The second one I installed myself
and when that one went, I was just lazy and didn't want to do it on #3 and #4.
If my FRS started doing the same, I would probably just replace engines until I am done with the car and
basing that off of the other one, will be a while. If you take care of the car and it's just the engine popping,
keeping it seems to make more financial sense unless it gets out of hand. If the inconvenience of not having the
car while it's being repaired can't be endured due to lost time/work/stress, then set it free into the wild where it
can find a new owner.
Old 07-05-2019, 08:15 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
OP needs to clarify what currency to use.
OP is from Canada. Half the responses are probably in USD. There's quite a gap in value...
Old 07-05-2019, 09:14 PM   #14
Impureclient
Drives: 2015 FR-S
I was quoting using schmeckles.
Reliability concerns after major warranty engine repair? guanqi89 Engine, Exhaust, Transmission 10 07-10-2018 09:40 PM
Warranty expires soon, anything needs attention? qqzj BRZ First-Gen (2012+) -- General Topics 8 08-29-2016 12:49 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 03:05 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
