Old 05-09-2018, 07:13 PM   #659
DSOmegaX
DSOmegaX's Avatar
Originally Posted by gpvecchi View Post
Do you know if STi aftermarket spring kit (with 15mm lowering) is the same that is fitted as stock on STi?
Thanks!
Are you asking if the springs the same as a stock spring set from a WRX STi or a BRZ tS?
@dsomegax.cars
Old 05-10-2018, 01:16 AM   #660
gpvecchi
gpvecchi's Avatar
I mean the BRZ STi JDM model. They are the same as tS version. But I don’t know anything about the STi aftermarket, they have different part number...
Old 05-10-2018, 10:12 AM   #661
Vital
Drives: 2015 BRZ
I mean the BRZ STi JDM model. They are the same as tS version. But I donít know anything about the STi aftermarket, they have different part number...
No, they are not the same. The JDM STI Springs lower 15mm and the USDM tS springs lower the 10mm. They are completely different parts so they will have different part numbers.
Old 05-10-2018, 03:48 PM   #662
DSOmegaX
DSOmegaX's Avatar
As mentioned above the JDM versions are 15mm down vs. 10mm down. My springs are specific to the showa dampers on the JDM tS from 2013. Other iterations were revised to pair with the bilstein dampers for 2015 and another for the new JDM STi sport. If you want a set that pairs to the USDM tS for the additional 5mm you can look at the JDM STI sport version as it uses the same dampers as the US car.
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Tristor (05-10-2018)
Old 05-10-2018, 04:51 PM   #663
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Regular GT model goes with this set. for all models from normal to the sachs on GT/PP.
https://www.sti.jp/parts/subarubrz_z.../ST20330AS000/
Sti Sport/Showa/Bilstein had their own.
Old 05-10-2018, 05:29 PM   #664
gpvecchi
gpvecchi's Avatar
Latest BRZ STi JDM has Sachs with same (apparently) springs of Ts Bilstein.
Old 06-19-2018, 09:48 PM   #665
HKSBRZ14
Drives: 14' BRZ supercharged
Any tips on applying the STi pinstripes? I have them, I am just nervous about them not looking even and the instructions are in Japanese haha. Love your car by the way.
HKSBRZ14 is offline   Reply With Quote
Old 06-19-2018, 09:53 PM   #666
HKSBRZ14
Originally Posted by DSOmegaX View Post
I finally did something to my car this year lol
These look great. Where did you get them?
Old 06-20-2018, 12:02 AM   #667
DSOmegaX
DSOmegaX's Avatar
The pictures should help you position the templates. Take your time, make sure you clean off any dust and dirt in the area. Helps to have another person to make sure itís aligned. Itís not too bad once you get started!
@dsomegax.cars
Old 06-20-2018, 12:02 AM   #668
DSOmegaX
DSOmegaX's Avatar
Dealerships will have them. Itís off the USDM tS
@dsomegax.cars
Old 06-20-2018, 08:23 PM   #669
HKSBRZ14
Dealerships will have them. It’s off the USDM tS
Thank you! Any chance you have the part number?
Old 06-21-2018, 01:46 AM   #670
norcalpb
norcalpb's Avatar
94060CA150
94060CA160
Old 06-23-2018, 12:04 PM   #671
DSOmegaX
DSOmegaX's Avatar
Iím happy to announce that the BRZ will be having a baby sister!
Iíve been looking into an M2 since almost two years ago and was close to pulling the trigger back then, but when I started hearing rumblings of the competition model, I decided to wait it out to see if the rumors would be true; and sure enough it does not disappoint! Delivery should be around end of September/early October.
@dsomegax.cars
The Following 3 Users Say Thank You to DSOmegaX For This Useful Post:
botbs (06-23-2018), Clipdat (06-23-2018), rcm47 (06-23-2018)
Old 06-27-2018, 01:20 AM   #672
HKSBRZ14
So sick! Just don't sell the brz ��
Completed build JK21 Member's Car Journals 46 12-11-2014 09:48 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 01:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-30-2013 11:10 PM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 10:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 09:18 AM
