#57 | ||
Proud of BOXER
Drives: Subaru Boxer
"quick blips at any rpm" - that's the weird thing about this is that I can rev from 1k to 2,500 or 3,000 over and over and no pop/clunk/knock/whatever. It only does it when it's at the resting ~650rpm idle. Even if I feather slightly to get over the resting idle and then do a throttle stab, no weird noise.
#58 | |
Proud of BOXER
Maybe make a video as well and we can compare noises? I'll do one this weekend and datalogging if I have time.
| The Following User Says Thank You to Clipdat For This Useful Post: | tomm.brz (04-07-2023) |
#59 |
Drives: Crapcan
@tomm.brz can the poor transient ignition timings cause this type of running issue even without blowing a seal?
I guess it is possible that @Clipdat has a seal in the process of failing and not completely gone and is only producing the issue at higher engine loads. Just throwing idea's out there.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Clipdat (04-07-2023) |
#60 |
Rust bucket enthusiast
Curious if this has anything to do with the change made in the A01C / B01C map compared to A00C. There was a pretty strong change made in the transient ignition retard to address tip in knock.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Ultramaroon (04-08-2023) |
#61 |
Drives: brz 2017 hksv2
yes that s exactly the main change they did
From 2017 they changed it again and made it a lot more retarded, to the point that any restyling car has lagging throttle blips because of the huge retard |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Ultramaroon (04-07-2023) |
#62 | |
but happens to casually destroy the oring of DI injectors, people learnt this the hard way and Subaru/toyota too so then they issued the bulletin explaining why Orings failed and released the update of the tune I have no idea if it can be possibile to damage the oring only lightly that loose the seal only at higher rpm, or if the sound of knocking can be heard in the cabin while driving but i d doubt it |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | NoHaveMSG (04-07-2023), Ultramaroon (04-07-2023) |
#63 | |
Drives: 2013 WR blue sport tech BRZ
#64 |
not playing cards
I've never heard the sound of a failed DI seal but I've always assumed that once it pops, it burns quickly and would be heard constantly. Am I wrong?
#65 |
well it misfires and loose compression the more damaged the seal is so it could throw some codes too(like too lean or misfiring) together with harsh sound during acceleration and popping sound like this:
| The Following User Says Thank You to tomm.brz For This Useful Post: | Ultramaroon (04-08-2023) |
#66 |
not playing cards
My google fu was weak. Thanks. Sounds exactly like the culprit here.
Guys, don't let this discourage you. It's a serious job but it doesn't involve tearing apart the engine.
#67 | |
Proud of BOXER
I just looked at the video Tomm posted. I don't identify that as the exact same sound, or reproduced at the same time during the rev stab as what need for speed and I are experiencing. Close, but no cigar. Also, if you notice in the video, he's not letting the revs fall back to the resting idle before revving again, and it still makes the noise. Not the case for us. More investigation is needed.
And if it DOES turn out to be DI seals, the only way I'm doing this job in my driveway is if I fly you down and we do it together lol.
| The Following User Says Thank You to Clipdat For This Useful Post: | Ultramaroon (04-08-2023) |
#68 | |
Proud of BOXER
We need more open hood videos. It honestly sounds like it could be something belt tensioner related. Just an uneducated guess.
I mean I can rev it like crazy, from 1k to 4k or above. Zero popping/knocking or strange noises. Even let it fall from 4k to 3k and rev back to 4k over and over and over. Nothing. Plus the fact that @fredzy's 23 does it is an interesting data point. Hopefully he can make a video for us when he has time.
#69 |
well the video of loud popping surely relates to OP's car
for you we wait a video of yours |
#70 |
Actually I agree with ClipDat, the only issue I have is with it resting at Idle, no other issues anywhere else in the RPMs. It sounds similar but I've never been able to replicate the noise other than at resting Idle. Gonna get a log in a bit of spirited driving for more data. I'd assume it would be noticeable in those logs if the injector is acting up.
| Rough idle leads to stall, runs well under load, no engine response on throttle blip | gensch | Issues | Warranty | Recalls / TSB | 8 | 09-01-2021 08:26 AM |
| Abnormal noise when throttle blip or WOT shifting | evo4g63 | Issues | Warranty | Recalls / TSB | 48 | 10-16-2014 08:42 AM |
| Throttle Blip Hiss | Wepeel | Issues | Warranty | Recalls / TSB | 29 | 05-30-2014 11:56 PM |
| Metal Grind Sound when throttle blip | JDM-dono | Issues | Warranty | Recalls / TSB | 0 | 11-17-2013 04:37 AM |
| Throttle Blip, and other features? | ashtray | BRZ First-Gen (2012+) — General Topics | 39 | 03-07-2012 10:52 AM |
