Old 04-10-2023, 07:18 PM   #141
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
Yeah. That.
It's free to sign up for an account, and it makes reviewing the data really easy. You can even set up data streams (gauges) to view on the left hand side and then "play" back the data and get a great understanding for what was going on in real time. It's just way easier to read/view than a straight CSV file.
It's also just a cool way to extrapolate the data into something that makes more sense for the uninitiated (people like me).
https://datazap.me/u/nfsundrgrnd/v4-...g?log=0&data=1
Did I do it right? Lol
Nfsundrgrnd is offline   Reply With Quote
The Following User Says Thank You to Nfsundrgrnd For This Useful Post:
Ultramaroon (04-10-2023)
Old 04-10-2023, 07:24 PM   #142
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Yep, I can see the log/data!
Originally Posted by humfrz
I'm old and lazy
Nfsundrgrnd (04-10-2023)
Old 04-10-2023, 10:42 PM   #143
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Nfsundrgrnd View Post
Sure did! Thanks.
Now I have even more questions. Why is FLKC going positive under high load here? Is this real?
Old 04-10-2023, 11:07 PM   #144
tomm.brz
Drives: brz 2017 hksv2
yes
it is because his advance is lower than 1, and the engine is not knocking there so it slowly tries to climb back to 1, while adding positive flkc gradually
curious to see a full. throttle pull
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Clipdat (04-11-2023), Ultramaroon (04-10-2023)
Old 04-10-2023, 11:47 PM   #145
Ultramaroon
not playing cards
Originally Posted by tomm.brz View Post
yes
Thank you! I think I am beginning to understand.
Old 04-11-2023, 06:48 AM   #146
Nfsundrgrnd
yes
Should have another log by the end of the day today hopefully. If not tomorrow.
Old 04-11-2023, 05:46 PM   #147
Nfsundrgrnd
yes
I come bearing gifts! I got the 2k - redline in 3rd at WOT log. Was coming in fast to a turn so didn't exactly hit redline but it was close enough lol. Also a smidge of launch control later in the log just to see if that's fine.
https://datazap.me/u/nfsundrgrnd/2k-...r?log=0&data=1
I still need to check the filter though, should have an answer in a bit.
Old 04-11-2023, 10:08 PM   #148
tomm.brz
that s not bad at all
here a new release of it for your car with some adjustment:
Stg1 V4 91oct A00C Nfsundrgrnd-2
Clipdat (04-11-2023), Nfsundrgrnd (04-11-2023)
Old 04-11-2023, 10:52 PM   #149
Nfsundrgrnd
Thank you man, I appreciate the help! I'll try to get another log done tomorrow with the new tune.
Old 04-11-2023, 11:00 PM   #150
Clipdat
Proud of BOXER
Clipdat's Avatar
When you say do a "2k to redline in 3rd at WOT" pull do you mean literally let 3rd run into the rev limiter before then shifting into 4th?
I'm old and lazy
Old 04-12-2023, 02:46 AM   #151
tomm.brz
yes at 2000 or around it floor the accell and reach redline
similar to a pull in the dyno
The Following User Says Thank You to tomm.brz For This Useful Post:
Clipdat (04-12-2023)
Old 04-12-2023, 08:44 PM   #152
Nfsundrgrnd
Got a fresh Log with the new tune. Got a couple 2k to redline pulls with some spirited driving and blips at the end.
https://datazap.me/u/nfsundrgrnd/2k-...2?log=0&data=1
Car feels faster now as well.
Also why is the ignition advance dropping as the RPM's are climbing towards redline?
Old 04-12-2023, 09:52 PM   #153
tomm.brz
That is a question that should be made to an engineer that worked with Subaru in the fa20 to answer properly
For us normal human beings, you just have to know this is not a wrx, we have double injection and a very dynamic DI injection angle and the engine has its own flow that gives a particular ignition timing curve
When rpm start to rise past 5000, flame speed and burn rate start to change in a way (faster basically) that the engine requires less timing otherwise it knocks... for example PI injection is used more at high rpm also in stock rom, and more PI usually means faster combustion = less timing required
usually max tining is around 5200-5600rpm, then slowly dropping till redline
with a suoercharger the timing will go even lower of course
with e85 instead, you can rise up timing a lot so that you can almost flat out the timing from midrpm to redline
Anyway log is not bad, i ll make you just a quick adjustment more and then you re good to go
Car going faster might be a placebo, or because of higher advabce multiplier now, it has a bit more torque overall, but "peak" power should not be higher and somewhat the same as before, i m not rising timing i m actually lowering them in your tune
Keep in mind i m not really retuning you, i m just adjusting the ots tune quickly because of knocks
When i tune i use a completely different base
The Following 5 Users Say Thank You to tomm.brz For This Useful Post:
Clipdat (04-13-2023), fredzy (04-14-2023), Nfsundrgrnd (04-13-2023), NoHaveMSG (04-12-2023), Ultramaroon (04-13-2023)
Old 04-12-2023, 10:46 PM   #154
tomm.brz
Stg1 V4 91oct A00C Nfsundrgrnd-3
Clipdat (04-13-2023), Nfsundrgrnd (04-13-2023)
Search this Thread:
Advanced Search
Rough idle leads to stall, runs well under load, no engine response on throttle blip gensch Issues | Warranty | Recalls / TSB 8 09-01-2021 08:26 AM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 08:42 AM
Throttle Blip Hiss Wepeel Issues | Warranty | Recalls / TSB 29 05-30-2014 11:56 PM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 04:37 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 10:52 AM
