Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
08-27-2020, 04:00 PM | #15 |
Drives: GT86
Very nice install of the hood vent, I don’t suppose you have any photos of the underside and how you mounted it? Is it 3M taped?
08-28-2020, 01:31 AM | #16 | |
Drives: 2016 Subaru BRZ
The opening in the hood is about 3/4" smaller than the edge of the vent. The front lip of the vent has a slot running almost the full length that slides over the sheetmetal of the hood and captures it. The rear edge of the vent has two clips that pop over the edge of the sheetmetal and catch under it. Plus there is a built in screw in the center on the underside of the vent that you drill a hole for and put a nut under the sheetmetal of the hood too. Ther is a factory applied strip of double sided tape (maybe 3M?) on the entire back edge of the vent. So you put the front edge of the vent in first and push it forwards onto the front opening edge till it's on all the way. Then you push the back edge down until the clips spring into lock and the adhesive grabs. I put some weight on the back edge overnight so there was good force to make sure the adhesive had good contact and bonded well (clean any wax off the paint first!) If you go to YouTube and search "installing a gt500 hood vent" there are several videos of guys of differing skill doing this install on their hoods
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
The Following User Says Thank You to BuffDriver For This Useful Post: | bobel (08-28-2020) |
08-29-2020, 03:30 PM | #17 |
Drives: 2017 Toyota 86
It might actually be cheaper to go with some UEL headers that stay clear of the oil pan. I noticed a lot of EL headers really wrap around the oil pan and surround it. One even advertised that it gets the oil up to temp faster, which is great in a cold climate. It was 107 here yesterday, so I don't really have trouble getting the oil up to temp. I'm not even boosted and that worried me.
09-02-2020, 07:16 PM | #18 | |
Drives: RX-7 / BRZ
Harrop sells an oil cooler setup w/ducting that lays down horizontal in front of the cooling stack so you aren't cutting off flow to the ic/rad. Kraftwerks/Skunk2 Sell a smaller capacity Washer Reservoir (originally with their s/c kit.) Takes up half the space if you want to entertain the idea of fitting a core on the RH side in front of it. I'd pull the header off and find another. If not at least heat wrap it. before installation. A couple smacks with a rubber mallet ought to move the pan out of the way enough it it gives you trouble.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
09-03-2020, 01:37 PM | #19 |
my JDL 4-2-1 EL and JR Dual Rad fits just fine with OEM fans and all
2013 Series 10 FRS #553
09-09-2020, 12:40 PM | #20 |
You still had to cut the underside didn't you? From the looks of it those underside hood supports are in the way of it fitting flush correct?
Similar Threads | ||||
Trouble installing Intec fender vent turn signals | mynameismyles657 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-22-2017 07:33 PM |
CF hood to vent turbo heat | drz400dude | Forced Induction | 1 | 07-24-2017 05:38 AM |
heat management, CF hood alternative | Reaper | Forced Induction | 70 | 07-05-2017 01:22 AM |
Seibon TS hood heat shield | texasbound972 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-09-2014 11:08 AM |
raising the hood to combat the heat? | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-03-2014 12:41 AM |
