BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
01-30-2022, 08:57 PM | #15 |
Large Member
Drives: 2022 Subaru BRZ
My new BRZ shows a moving vertical bar (which grows wider as the temp climbs), with a temp readout below it. After about 15 minutes, it reads 90C. I have never seen it more than that, although I’m still breaking it in. It’s the first vehicle I’ve owned that shows oil temp. The water temp indicator is a single bar that moves left to right as temp increases.
I never drive hard for at least the first 15 minutes anyway - no matter the age or mileage of the vehicle. Maybe I’m old-school. |
01-31-2022, 12:33 AM | #16 |
Drives: 2022 BRZ WRB
This is a simple fix, cheap, effective.
More permanent options do exist as well, wired straight to your OBD2 port. I knew a guy who was tracking a Gen 3 Mazda3 and that's the route he went. He did a clean install and gained the readouts he was looking for. There is also a way to get it to display on your main screen but it's not necessarily a simple process thru android auto. |
01-31-2022, 12:44 AM | #17 |
Drives: 2022 GR86
That approach is decade+ old at this point.
On MY2018+ cars (or older with aftermarket head unit), you can project the screen on the head unit using Android Auto, like I do in this video: I also have a bunch of customized gauges one swipe away. |
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Midnightsky (01-31-2022), T-Steve (03-06-2022) |
01-31-2022, 01:00 AM | #18 |
Forsure that's the best option, I just haven't found an app that has worked for me yet. Old method yes, but still effective. Would I take that to a track day? No probably not, I would be building a custom bracket or case ect for that with a better mounting location.
03-11-2022, 09:59 PM | #19 |
Drives: 2022 BRZ Ltd, 2019 Ascent
Look again at page 153 of the BRZ manual. I assume it can toggle between Fahrenheit and Celsius. I will verify this for myself when my 2022 arrives next week.
12-18-2022, 06:51 AM | #20 |
Drives: White GTS then Black GTS
Can Subaru dealer use their software to enable the numeric oil temp display? I know they can deactivate the active noise from their software.
12-19-2022, 07:49 PM | #21 |
Drives: WR Blue Pearl 2022 Subaru BRZ
With the BRZ you can see your tire pressures while in track mode, I don't think that's possible with the GR86? (a complaint from throttle house iirc)
Can you actually change the display once your in track mode at all in a GR86? |
12-19-2022, 07:55 PM | #22 |
Drives: 2022 GR86
No
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post: | Blighty (12-20-2022) |
12-20-2022, 06:47 PM | #23 |
Kinda strange by toyota. I know they have a neat little combo info window that they want to show, but I'm sure people would like to have the option to see other stuff.
I would really be down for someone to hack the display control on these cars now that's its all digital. |
12-20-2022, 06:54 PM | #24 |
Drives: '23 BRZ Limited
You don't have to be in track mode to see tire pressures on the BRZ. At least not on my '23.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
12-21-2022, 08:32 AM | #25 |
12-29-2022, 02:59 PM | #26 | |
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
12-29-2022, 03:02 PM | #27 | |
12-29-2022, 10:28 PM | #28 |
Drives: 2018 Subaru BRZ Limited with PP
That light is in reference to the coolant. It basically encourages you to baby it more while that light is on. Has no reference to the oil temperature. But in any case, as you said, it takes a good 10 minutes total or so to get the oil up to temp before you want to start ripping the car up.
Similar Threads | ||||
Is there a difference between gauge clusters UDSM brz vs EU/AU brz? | wutangbrz | BRZ First-Gen (2012+) -- General Topics | 1 | 01-24-2019 06:21 AM |
Modded Gauge Clusters | CThomas | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-21-2015 08:45 PM |
