Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-05-2019, 02:01 PM | #1 |
Drives: 2017 Toyota 86 860 SE
2017 Toyota 86 front pipe to mid pipe donut gasket
Hello friends,
Last night put a cat back on my car, when I took the stock exhaust off no donut gasket. So when I put my hks cat back on there is also no donut gasket now. Is this a problem? Should I pick one up and slap it on? |
05-05-2019, 09:00 PM | #2 |
Wheels for Brains
If the HKS exhaust has a donut gasket type flange (instead of a flat 2.5" flange), you'll need it or else you'll have exhaust leaks
05-05-2019, 10:33 PM | #3 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
You sure it wasn't wedged into the oem catback? maybe check there and see if it some how slipped off and was stuck in the catback piping. If not, you'll need a new donut gasket to prevent leaks.
05-11-2019, 03:49 AM | #4 |
I didn't see it, any chance it is like melted on to the front pipe? front pipe to mid pipe looks like it has a little bit poking out with a black tip that looks like the pictures of the donut gaskets and I haven't noticed any leaks yet so I think that's the case
05-11-2019, 09:07 PM | #5 |
Drives: 17 Asphalt 86
The a used donut gasket will probably look like it's part of the pipe when you look directly at it. The front pipe flange mating surface should be flat, if it isn't then there is a donut gasket attached.
I took mine off at 20k KM when I did mine and I had to pry it off with a flat nose. |
05-11-2019, 10:01 PM | #6 |
Cool then it was stuck to the front pipe and I have one! Thanks for the help
Similar Threads | ||||
Front Pipe Gasket | Ashleususs | Engine, Exhaust, Transmission | 5 | 05-24-2018 08:51 PM |
no flange for donut gasket on J2 front pipe | k0tkmnd | Engine, Exhaust, Transmission | 1 | 06-05-2015 02:04 PM |
Front Pipe donut gasket | EightSix93 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-02-2015 09:02 PM |
Front pipe to mid pipe gasket? | ryoma | Engine, Exhaust, Transmission | 6 | 04-30-2015 12:27 AM |
front pipe use donut gasket or not | garfull | Engine, Exhaust, Transmission | 2 | 12-09-2013 03:20 PM |
