Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-12-2021, 01:59 PM | #57 | |
Drives: 2017 86 860 Special Edition
Weathers warming up so Im hoping I can get the Ohlins on with the hotchkiss endlinks. Still on oem bars so fingers crossed I don't run into any issues. |
04-16-2021, 02:42 PM | #58 | |
Drives: 2013 frs
The Following User Says Thank You to Adamf220 For This Useful Post: | RayRay88 (04-16-2021) |
04-18-2021, 05:25 PM | #59 | |
2013 Series 10 FRS #553
04-19-2021, 09:44 AM | #60 |
Drives: 2013 frs
So the new sway bar mounting worked great for me. Zero issues and drove great. I would suggest everyone with ohlins or any other coilovers that have clearance issues to do the same as I did.
04-19-2021, 10:37 AM | #61 |
Just be advised that solution does change the motion ratio and effectiveness of the front swaybar, which may be okay with a bigger aftermarket front bar. With a stock front swaybar it might not be okay for everyone.
- Andrew |
04-22-2021, 12:25 PM | #62 | |
Sleep Chomper
The Following User Says Thank You to rixter145 For This Useful Post: | RayRay88 (04-22-2021) |
04-22-2021, 01:34 PM | #63 |
04-23-2021, 03:50 PM | #64 | |
Sleep Chomper
I had a very aggressive alignment but wasn't tracking enough so I dialed it down a bit. But regardless, no issues at all Alignment: |
The Following User Says Thank You to rixter145 For This Useful Post: | RayRay88 (04-24-2021) |
04-30-2021, 06:55 AM | #65 | |
Drives: Subaru BRZ
I mean, it should be cause the arm is steel but, i don't know, couldn't be better to weld a small bracket on top of the arm? |
04-30-2021, 10:05 AM | #66 |
Drives: 2013 frs
Well I put a full track day on it and am about to do another. Checked everything and its all good. I cant imagine that the forces put on the end link in the control arm are great enough to distort the metal. The WRX is mounted the same way but with a bracket but the steel used for the bracket isnt any thicker than the stamped steel control arm.
05-01-2021, 04:02 PM | #67 |
Drives: Subaru BRZ
The wrx arm is fully boxed and the bracket support the link with 2 arms that yes, looks thin, but not from the perspective of the force applied by the sway bar
Ours lca is open at the bottom so if you apply a load to the side the metal can flex cause it's not "supported" at the bottom. Maybe that much stiffness isn't needed, time will tell (eventually you could put a camera in the wheel well and watch), but it's possible that Subaru used a different construction for a reason |
05-03-2021, 09:43 AM | #68 | |
Drives: 2013 frs
on our car because they could. They didnt have to deal with an axle and a huge transmission so they were able to mount it behind the engine which from my understanding is a better mounting location. Also I highly doubt that the sway bar is able to flex the entire control arm, and the hole has not rounded out or anything so I think its safe to say that it is fine. |
Similar Threads | ||||
Eibach front and rear sway bars | MST Engineer | Brakes, Suspension, Chassis | 3 | 05-23-2017 12:22 PM |
Eibach 29/19mm sway bars | Whitel | Brakes, Suspension, Chassis | 5 | 01-19-2017 06:17 AM |
WTB: Eibach Front and Rear Sway Bars | RavioliG | Want-To-Buy Requests | 2 | 11-11-2014 01:44 AM |
Eibach Front and rear sway bars Review | *KID* | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-29-2013 04:14 PM |
Eibach Sway bars ON SALE NOW!!! | Accurate Race Shop | Brakes, Suspension, Chassis | 27 | 11-12-2013 09:51 PM |
