Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-20-2023, 12:30 AM | #15 | ||
Proud of BOXER
Drives: Subaru Boxer
Absolutely revolting and abhorrent behavior by the dealership.
The Following 2 Users Say Thank You to Clipdat For This Useful Post: | blsfrs (05-20-2023), Ultramaroon (05-20-2023) |
05-20-2023, 09:32 AM | #16 |
Drives: 2013 frs base
Just for satisfaction, If I were you, I would post your experience with that dealer on every local forum available. Google, Yelp, BBB, etc. Don't rant, just be factual. You may save someone else a headache and there is a possibility someone higher up at the dealership may take notice.
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (05-21-2023), soundman98 (05-20-2023) |
05-20-2023, 07:10 PM | #17 |
Drives: raven frs
Definitely couldn't hurt, ill do that.
The Following User Says Thank You to booher For This Useful Post: | blsfrs (05-21-2023) |
05-20-2023, 08:24 PM | #18 |
The Following 2 Users Say Thank You to Grady For This Useful Post: | blsfrs (05-21-2023), soundman98 (05-20-2023) |
05-20-2023, 08:32 PM | #19 |
ProCrastinationConsultant
yep. sitting outside the dealership entrance on public property with a lawn chair, your cars hood up, and a sign saying "_____ screwed up my car", you don't need to say a word, but they start taking notice really fast.
05-21-2023, 08:16 AM | #20 |
We had a guy around here that did something like that. He stood at a busy intersection near the local Kia dealership with a sign that said they messed up his car. I'm pretty sure that he was retired and had the time.
The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
05-21-2023, 03:27 PM | #21 |
義理チョコ
Giving back to the community. I could think of worse ways to spend retirement.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | blsfrs (05-22-2023), soundman98 (05-21-2023) |
05-21-2023, 03:29 PM | #22 |
Drives: Crapcan
As a pillow? To rest his coffee on? Toilet paper?
The removal/installation procedure is pretty clear in the manual. I haven't looked at much in a while but I believe you are supposed to index crank and cams on timing marks, remove timing chain from bank one, then reindex to different timing marks and remove bank two timing chain. It sounds like he tried to remove bank 2's timing chain while on the first set of marks and it spun and hit the piston or it had valve on valve contact. I would call Toyota's customer service and explain the situation. It may put pressure on the dealer.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
05-21-2023, 07:55 PM | #23 |
Drives: 2017 BRZ w/PP
When I had to deal with SoA, it was a cluster fuck. Pissing into the wind would be more productive.
The Following User Says Thank You to Breadman For This Useful Post: | blsfrs (05-22-2023) |
05-21-2023, 08:47 PM | #24 | |
Drives: Crapcan
I’d rather try and fail then not try.
05-21-2023, 10:27 PM | #26 | |
Drives: Crapcan
You at least made the attempt and exhausted options.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (05-22-2023) |
Similar Threads | ||||
2014 FRS broken valve spring = new motor | whip | Issues | Warranty | Recalls / TSB | 12 | 05-28-2019 01:20 PM |
Is building a motor necessary for FI on this motor? | Irace86.2.0 | Forced Induction | 44 | 02-27-2018 01:19 PM |
Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
Still not broken in | Drftfan | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 06-13-2013 07:51 PM |
