10-23-2012, 01:11 AM | #29 |
10-23-2012, 02:43 AM | #30 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
0.94L blower does seem a little small, but I assume we are talking less than 8psi in this application.
I used a 1.2L whipple on my 4AGZE, back in the day (on a mk1 mr2), and stock was also ~1.2L. This was on a 1.6L engine, but running around 14-16psi. They are most likely using this blower: http://www.sprintex.com.au/sprintex/...gers/#tabs-0-1 At the max speed of 15000 (~2x engine speed), this SC could make around 1 bar (nearly 15psi) of boost, depending on the VE of the engine and some other factors. Seems like a good size to me. My main question.. what about CARB? Any plans?? |
10-23-2012, 03:21 AM | #31 |
Drives: really slow...
I hope you're using a kenne bell unit . I'm a big fan of the twin screw. I run a comptech unit in my other car. However, my laminova leaked and darn near blew my engine. How can you guys make sure the laminova doesn't leak? Also, why not use a traditional tube/fin type ic? They cost less too.
Totally subscribed for updates. Need msrp pls! |
10-23-2012, 09:39 AM | #32 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Ohh kids, When did Innovate start building forced induction kits?
10-23-2012, 10:23 AM | #33 |
Drives: BRZ WRB
Does twin screw make that goosebumps whine scream sound ?
10-23-2012, 12:06 PM | #34 |
Drives: 86 (FR-S)
Come on... surely you can give us a teaser pic
10-23-2012, 12:15 PM | #35 |
Saving them pennies...
In for pics and specs!
+1 for teaser! |
10-23-2012, 12:19 PM | #36 |
Drives: 86 (FR-S)
10-23-2012, 01:41 PM | #37 |
Drives: Silver AT Limited
subd! Cant wait to see. if it is truly easy to install i might do it might self
10-23-2012, 02:09 PM | #38 |
Drives: 2013 FR-S Ultramarine
As a Californian, I'm interested in a good supercharger for the potential ease of removing it to smog every two years if it's not CARB legal. Not having to get under the car and mess with the exhaust would be awesome.
Any plans for a clutch system for improved cruise economy? Nathan |
10-23-2012, 02:49 PM | #39 |
Drives: Firestorm Red FR-S
Maybe I'm a sucker for good verbiage but now I'm torn. AVO turbo or this???
The Following User Says Thank You to RedRocket For This Useful Post: | Mo707 (10-24-2012) |
10-23-2012, 03:12 PM | #40 | |
KCCO From Canada
Drives: Asphalt FRS
but i'm down to see what the manifold looks like and if they can keep weight to a minimum i may just be looking into this kit. |
10-23-2012, 04:26 PM | #41 |
Drives: subatoy
10-23-2012, 04:29 PM | #42 |
Will water/meth be needed if you're running 91 pump gas with the intercooler?
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | EN2_Squirrel (10-28-2012) |
Similar Threads | ||||
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** | Touge Factory | Interior Parts (Incl. Lighting) | 9 | 11-29-2012 02:13 PM |
lost screw for sensor intake | Mr.Jay | Engine, Exhaust, Transmission | 5 | 10-21-2012 09:26 PM |
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More | Rev Works | Audio/Visual, Electronics, Infotainment, NAV | 28 | 10-09-2012 05:04 PM |
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
Missing rubber piece for intake screw | ngabdala | Engine, Exhaust, Transmission | 1 | 08-31-2012 06:10 AM |
