Member's Car Journals Car journals by our members. |
01-08-2017, 04:41 PM | #57 |
Drives: White out FRS
DECEMBER 17 2015
Me and my brother went down to West Palm Beach to buy an engine and drove it back up to Orlando with my dad's Highlander to avoid shipping fees. Exciting to see the engine in the garage and in person after looking at pictures online for a while Yeah it's kinda dirty and old.. Doing a compression test to check out the engine and ended up with 0 compression in all cylinders.. Weird but I thought it could've been the cheap Harbor Freight compression tester and ignored it. Idk why I started to disconnect the chassis harness but these are the heater lines that had to be cut to fit the engine in the way I wanted to.
Instagram: schen_86
3SGE FRS Build Thread: http://www.ft86club.com/forums/showthread.php?t=114039 Last edited by Toxicmilk45; 05-10-2023 at 01:10 PM. |
01-08-2017, 04:51 PM | #58 |
FEBRUARY 5 2016
Full Blown Motorsports FRS return system fuel line.. Complete waste of money working with the stock fuel system and Full Blown's kit.
Instagram: schen_86
3SGE FRS Build Thread: http://www.ft86club.com/forums/showthread.php?t=114039 |
01-08-2017, 04:55 PM | #59 |
FEBRUARY 17 2016
Got the engine setup on blocks and wood to start making the engine and transmission mounts. FEBRUARY 23 2016 OEM header fitment issue.
Instagram: schen_86
01-08-2017, 07:08 PM | #60 |
MARCH 17 2016
Now the engine is mounted on with engine and transmission mounts. For the radiator hoses, I used the original fa20 hose for the lower radiator and connected it to the original 3SGE lower radiator hose. The upper radiator hose is aftermarket from the engine then to oem frs upper radiator hose. Cheap and it works. Here it is before the body panels got put back on.
Instagram: schen_86
01-15-2017, 06:24 PM | #61 |
MARCH 21 2016
Instagram: schen_86
The Following User Says Thank You to Toxicmilk45 For This Useful Post: | RSKYBZ (01-16-2017) |
01-16-2017, 08:32 AM | #62 |
Drives: toyota 86
I think everyone knows that this is the motor it should have come with from factory.
Are you planning on converting to itb's?
01-24-2017, 04:07 AM | #63 |
Drives: Stock
Seriously there basically the same fucking engine compare the actual number witch one is the fa20 and witch one is the 3sge
02-01-2017, 01:44 PM | #64 |
Drives: RHD Gt86
hey bro, what issues u got since u switched to ecutek?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
02-01-2017, 06:41 PM | #65 |
I don't have ecutek
Instagram: schen_86
02-01-2017, 08:06 PM | #66 |
Drives: RHD Gt86
Yeah bro I know, I was asking Dustin. My bad for derailing your thread
02-03-2017, 01:23 AM | #67 |
Drives: 2013 Asphalt Fr-s,91 240sx missle
Did you keep the front sway bar with this swap?
02-05-2017, 04:33 PM | #68 |
Drives: toyota 86
Have you ever driven a beams? You can look at numbers all you want but driving it is a much better comparison. At the end of the day I would prefer an in line 4 rather than a flat 4. The ability to run long ITB's for good gains really appeals to me and I feel this chassis would benefit from a 3s type motor
The Following User Says Thank You to johl For This Useful Post: | hmong337 (02-06-2017) |
02-05-2017, 09:10 PM | #69 | |
Drives: Stock
02-21-2017, 12:06 AM | #70 |
Drives: 2014 Subaru Brz
what whee/tire size are those avids btw?
Similar Threads | ||||
Tire Sale - Achilles, Federal, Nankang, Sunny, Falken, Hankook, Nexen, Accelera, etc | Sonic Motor | Wheels and Tires | 394 | 07-29-2016 02:13 PM |
How many of you Swapped your 86 for 15 WRX ? | Xti | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 08-09-2014 09:09 AM |
Sunny day, so I had to take some pics | ichitaka05 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 07-01-2014 05:32 PM |
Sunny day snaps of my finished SWP Limited | Ouhei | BRZ Photos, Videos, Wallpapers, Gallery Forum | 24 | 04-10-2014 10:21 AM |
Ultramarine FR-S on a sunny day (Multiple Pix) | CoRi J | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 05-25-2012 06:58 PM |
