Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-21-2016, 07:30 AM | #1 |
Drives: GT86 2013
How long are stock wheel studs?
Anyone know how long the stock front wheel studs stick out from the wheel hub?
Going to order some spacers, and since my wheels dont have holes in the back they need to be at least as thick as the length of the stud to not go against the rim.. |
09-22-2016, 12:34 PM | #2 | |
Country Boy 4 Life
Stock wheel studs can accept a 3mm slip spacer safely. Some guys run up to a 5mm slip spacer. You will need longer/aftermarket studs to go with a bigger spacer. |
09-22-2016, 01:19 PM | #3 | |
Drives: Track preped NA FRS
To OP, I dont have the exact measurements but with a 25mm spacer (the ones that bolt unto the hub) I can use my wheels that dont have space in the back either. So 25mm at the very least. |
The Following User Says Thank You to Icecreamtruk For This Useful Post: | Leonardo (09-22-2016) |
09-22-2016, 01:54 PM | #4 |
Senior Misanthrope
The series.blue wheels had that issue with bolt-on spacers. I believe you'll need a 20mm, but I'm not 100% sure.
09-22-2016, 02:04 PM | #5 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
OP - if i were you I'd take the 10 mins to jack the car up, pull the front wheel and measure the studs to be sure.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
09-22-2016, 04:29 PM | #6 | |
Country Boy 4 Life
The Following User Says Thank You to Leonardo For This Useful Post: | Icecreamtruk (09-22-2016) |
09-27-2016, 04:07 AM | #7 |
Drives: SWP BRZ
25mm for sure. the nut sits flush when tourque down on stock studs and fits wheels with no back pad holes.
09-27-2016, 03:39 PM | #8 |
Drives: FRS
yeap you'll need at least 25mm spacers to clear the stock studs
08-05-2021, 07:20 AM | #9 |
Drives: Subaru BRZ
Hey guys I'm having a similar problem as well, I went with the project kics 11mm bolt on spacers but with the set of wheels I got they don't have an indentation for the stock studs to stay in, I was thinking of getting a 10mm slip on spacer but I wasn't sure what length to get for extended studs without having to worry about the wheel not sitting flush to the hub. I appreciate any help I could get, Thank you!
Similar Threads | ||||
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes | Pat | Tracking / Autocross / HPDE / Drifting | 86 | 07-16-2021 10:50 AM |
ARP Wheel Studs | FR-S Matt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-09-2015 06:50 PM |
ARP Wheel studs and 10mm hubcentric wheel spacers | S1CNSTY_SUBIE | Wheels and Tires | 3 | 04-17-2015 08:31 AM |
WTB OEM Wheel Studs | Anthony | Want-To-Buy Requests | 8 | 08-27-2014 03:22 PM |
Spacers and stock wheel studs | solidONE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-31-2013 08:55 AM |
