Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
02-28-2018, 09:01 PM | #1 |
The Gunshine State
Drives: '14 BRZ Limited
10k miles between oil change
I decided to sacrifice my car (for science) and see how a UOA looks at 10k m.
I’ve always been a fan of Mobil 1, my last Miata was at 265k m before I sold it and still had great compression numbers. I’m pleasantly surprised on how the FA20 with M1 did. Blackstone Labs even recommends stretching it out to 12k, which I probably won’t do and will go back to changing it every 8k again. It’s just nice to see that the oil is still healthy and doing it’s job beyond 10k m.
Current DD: M235i |
The Following 12 Users Say Thank You to 8RZ For This Useful Post: | e30kawi (03-04-2018), humfrz (03-01-2018), Kaotic Lazagna (03-02-2018), OfficeWorker (03-01-2018), reeves (03-15-2018), SkAsphalt (03-21-2018), Somerandom18 (02-28-2018), Spuds (03-01-2018), Tcoat (03-02-2018), Teseo (03-01-2018), Tristor (03-02-2018), wparsons (03-01-2018) |
02-28-2018, 09:12 PM | #2 |
Drives: 2014 86 GTS
Good to know, thanks for sharing
02-28-2018, 09:55 PM | #3 |
Wes
Wonder where all that magnesium is coming from
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Somerandom18 (02-28-2018) |
02-28-2018, 10:21 PM | #4 |
Drives: 2005 Toyota Camry
Oil additive in Mobil 1.
My ENEOS Sustina for comparison. http://www.ft86club.com/forums/showp...5&postcount=77 I wanted to stretch mine to over 10k as well, but I simply was not putting enough "normal" miles on the engine. |
The Following 6 Users Say Thank You to mav1178 For This Useful Post: | fika84 (03-13-2018), OfficeWorker (03-01-2018), Somerandom18 (02-28-2018), StraightOuttaCanadaEh (02-28-2018), Teseo (03-01-2018), Tristor (03-02-2018) |
02-28-2018, 10:23 PM | #5 |
Drives: 2017 manual BRZ
Impressed by the fuel percentage... Expected higher from a high compression engine. We have have some good rings.
Sent from my Pixel XL using Tapatalk |
The Following User Says Thank You to Somerandom18 For This Useful Post: | Tristor (03-02-2018) |
03-01-2018, 12:05 AM | #6 |
The Following 4 Users Say Thank You to humfrz For This Useful Post: |
03-01-2018, 08:02 AM | #7 | |
The Gunshine State
Challenge accepted!
Current DD: M235i |
The Following 4 Users Say Thank You to 8RZ For This Useful Post: |
03-01-2018, 09:41 AM | #8 |
Drives: 2013 GBS BRZ Limited
I stretched my last oil change out to 10k mi as well and got similar results. I'm planning on dialing it back to around 7.5-8k though since past that I saw a noticeable drop in fuel economy.
Here's the report with the numbers from my past few changes. All of these have been with Valvoline SynPower 0W-20, fwiw. |
The Following 6 Users Say Thank You to Mazikowski For This Useful Post: | 8RZ (03-01-2018), OfficeWorker (03-01-2018), Somerandom18 (03-01-2018), Tcoat (03-02-2018), Teseo (03-01-2018), Tristor (03-02-2018) |
03-01-2018, 02:50 PM | #9 | |
The Gunshine State
Current DD: M235i |
03-01-2018, 11:09 PM | #11 |
Drives: frs
Anyone have a report but with motul?
The Following User Says Thank You to Teseo For This Useful Post: | Tristor (03-02-2018) |
03-02-2018, 06:34 AM | #12 |
Drives: GR Corolla
I was changing mine every 15k with Amsoil and their oil filter. I'm dialing it back to 2k miles or less now since I don't daily it anymore.
03-02-2018, 02:12 PM | #13 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Tristor (03-02-2018) |
03-02-2018, 03:27 PM | #14 |
Drives: frs
Similar Threads | ||||
how many miles before first oil change | Anthony7515 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 72 | 10-25-2014 10:35 AM |
Just purchased my '13 BRZ with 1,800 miles. Should I change the oil? | torqueno | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 10-08-2014 10:55 PM |
Oil change at 4100 miles | djdrugga24 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 03-28-2014 02:00 PM |
Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 12:31 PM |
Oil change at 1000 miles. | Dorb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 03-08-2013 04:18 PM |
