Software Tuning Discuss all software tuning topics. |
05-27-2020, 05:35 PM | #1 |
Drives: brz
Google has failed me, need help with fuel cut ecutek
Car runs great everywhere except if I stab it from 50% to 100% throttle in the mid rpm range.
05-27-2020, 07:12 PM | #2 |
Drives: brz 2017 hksv2
that s vague description of a problem. does it knock or what? it bogs?
i dont even really remember the whole parts of your frankenbuild, which injectors commanded by PI do you have? |
The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (05-28-2020) |
05-27-2020, 07:29 PM | #3 |
Drives: brz
Goes lean and Flat on its face. Everwhere else it runs great. 1050 injectors. If i go slower with the throttle it does fine.
05-27-2020, 07:43 PM | #4 |
Drives: brz
I looked at the logs closer and its fuel cut?
6040rpm at 3.04 g/rev 90% throttle and 0 ms fuel Last edited by solidsnake11; 05-27-2020 at 08:36 PM. |
05-27-2020, 11:11 PM | #5 |
I have no idea
could you post the entire log? if you want link me your current tune, maybe I see something off looking at it |
05-28-2020, 12:04 AM | #6 |
Drives: brz
k24log
3rd hump is the cut k24-1050port-ls3direct-3barbosch.bin I think I'm ready to switch to A01G. I used a custom map to drop timing in launch, before it would not keep the timing down, when it reached the low threshold it would go back to the base timing of 29. https://datazap.me/u/turbotoy2791/lo...om=14897-15616 Last edited by solidsnake11; 05-28-2020 at 07:29 AM. |
05-28-2020, 02:27 AM | #7 |
yeah well that is just how launch control by ecutek works, it also fuel cuts intermittently so if you want something more extreme you have to custom set it anyway
I ll take a look at your things for next time please upload to datazap as I m on handy all day and it s stressing to upload with it |
05-28-2020, 07:32 AM | #8 | |
Drives: brz
With custom map 9lbs of boost at 4000rpms let me know if the links are not open to the public. Its first time I have used google drive. Last edited by solidsnake11; 05-28-2020 at 03:26 PM. |
05-28-2020, 07:39 AM | #9 |
ok,
tune is ok but there is a bug , probably because you patched it with Racerom 12 i had problems with rr12 too, not exactly this, anyway LFA state changed to a different value, and accelerator is over 85% (that s trigger for launch and flat as standard value) exactly when some sort of fuel hard cut entered, LFA means LaunchFlatfootAutoblip, it s a debug code for ecutek support It just seems a weird random bug Delete racerom12, put rr11.1 ,.... if it cuts again, try disabling launch control if it cuts again, switch to A01G or A02G with rr11.1 |
05-28-2020, 03:30 PM | #10 | |
Drives: brz
05-28-2020, 04:53 PM | #11 |
can you log again with a01g?
also, can you log your launch control just a couple seconds, no need to actually launch |
05-28-2020, 08:10 PM | #12 | |
Drives: brz
A01G RR11.1 |
05-28-2020, 08:13 PM | #13 |
weird
did you try disabling any extra features? also send the log to ecutek support attached with your tune They will help you figuring out more |
05-28-2020, 08:42 PM | #14 |
Drives: brz
Similar Threads | ||||
ABS C1288 - ECU Matching failed | MatGO | Issues | Warranty | Recalls / TSB | 21 | 05-30-2022 09:19 AM |
Rocker arm failed | displacedTexan | Issues | Warranty | Recalls / TSB | 77 | 08-22-2018 06:16 PM |
AC failed under 6 years. | wparsons | Issues | Warranty | Recalls / TSB | 5 | 05-16-2018 11:08 PM |
Hlep. I failed. | Shaisters | Northwest | 14 | 06-02-2016 10:56 PM |
Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 06:27 PM |
