Member's Car Journals Car journals by our members. |
03-07-2018, 12:53 AM | #1 |
Drives: Frs
2015 RS1.0 to 2017 retrofit
Thought it would be to share my project with you guys, still a few more components missing but I think it’s coming together nicely
Most of these parts were plug and play, with the exception of the gauge cluster which had to be reprogrammed prior to actual installation But here are some pics These are the oem headlights from a 2017 BRZ which I had the housing blacked out Had to get the oem 2017 tail lights of course with the center clear portion tinted 2017 oem Brz radio with faux carbon ac controls Same faux carbon on door switches from 2017 brz 2017 upgraded oem leather trims, side by side shot for comparison, swapped out all pieces Standard oem 2013-2016 brz leather/Alcántara seats, which I hope to swap out for the yellow stitching seats from the 2017 Subaru BRZ series.Yellow Will also need to swap all the other leather trims 2017 860 steering wheel and air bag Which I hope to have the steering wheel restitched in red, or yellow if I manage to find the seats I want for sale, but here you can also see the gauge cluster as well Now that 2018 brz came out and seem to have an upgraded headunit I’m going to try to get my hands one on for my car in the near future I’m actually working on getting the 2017+ performance pack oem brembo kit so I’ll keep this thread posted with a more of those parts I will be adding I also have a few other misc items installed as well, such as subaru homelink Auto dimming compass mirror, and the vanity mirror lights from a brz but these weren’t even worth a picture Feel free to send any questions my way if you guys are curious on any of these parts and how installation came about |
03-07-2018, 12:28 PM | #2 |
Drives: 1949 UFO
Nice work!!. I’m interested in the gauge cluster swap. I have a 17 86. Where did you get it, what’s the part number? How much?. How did you go about getting it programmed?. Same with the steering wheel buttons. Part number? Did you have to buy a harness?.. Do share!
03-07-2018, 01:50 PM | #3 |
Drives: 2014 Limited WR Blue Brz
Looks dope so far! Did you have any trouble fitting the new headlights in? I have a ‘14 brz and I want to get the new headlights too
03-07-2018, 02:30 PM | #4 |
Drives: 2013 Ultramarine FR-S
I among a ton of other people are going to be interested in the Gauge swap. I know clock spring needs to be changed for the steering wheel. What exactly needs done for programming the cluster? Does the car need to be available (Mine is currently apart for engine rebuild and upgrades), also are the steering wheel controls working?
03-08-2018, 01:09 AM | #5 |
Drives: Frs
Yea steering g wheel controls all work and yes that did require the 2017 dash harness and 2017 oem clockspring
Ask far as the cluster swapping goes, it’s only able to be one on push to start veihicles due to an immobilizing mechanism that key start cars have For the programming the dealership did it for me and also sourced the parts, the wheel set up and cluster you’re looking roughly at mid $2,000 USD after all said and done |
The Following User Says Thank You to jorgerendonjr For This Useful Post: | Chriswongbrz (09-15-2020) |
03-08-2018, 09:19 AM | #6 | |
Is this something that was tried and failed, or something the dealer told you? Thank You for the info!
03-08-2018, 10:13 AM | #7 |
Drives: Frs
Other members have tried and told me on the Facebook group, if I may ask did you buy a brz or 860 cluster?
The Following User Says Thank You to jorgerendonjr For This Useful Post: | DustinS (03-08-2018) |
03-08-2018, 10:54 AM | #8 | |
I am trying to find a good wiring diagram or dealer service manual for 2017 BRZ or Toyota 86 with digital display to check out the wiring. I am having a hard time though. Edit: Paid for Toyota TIS access to see the updated wiring diagrams and such. Nothing I see points to internal changes that wouldn't allow it to work, as well as the steps to program a new Gauge Cluster have not changed. Still kind of holding hope. I also found the FB post, seems they were all saying that it wouldn't work without a reprogram. So I think it might still work. I will keep my hopes up.
03-08-2018, 03:06 PM | #9 |
Drives: 1949 UFO
03-08-2018, 05:31 PM | #10 |
Awesome
Drives: World Rally Blue Subaru BRZ
This build looks great! I am interested to know how to managed to wire in the headlights. I was thinking of swapping in 2017 BRZ headlights on my 2013 BRZ.
04-06-2018, 11:10 AM | #11 |
Drives: 1949 UFO
Local dealer told me that when they order the cluster, the right mileage and VIN is needed as the cluster gets “burned” with that info before is shipped. This is the primary reason why this is a non-returnable item. When received is just a matter of swapping it out. Can anyone confirm this?
08-09-2018, 03:14 PM | #12 |
Drives: 1949 UFO
Any more info on this?..
10-06-2018, 12:41 PM | #13 |
Drives: black frs 2013
Pmd
Similar Threads | ||||
DIY - 2015 OEM Sharkfin antenna retrofit | kbye | DIY (Do-It-Yourself) Guides | 93 | 05-13-2020 02:30 PM |
2017 BRZ suspension retrofit | kgc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 10-30-2016 12:27 PM |
2017 BRZ vs 2015 BRZ calibration | thambu19 | Software Tuning | 2 | 08-10-2016 01:36 AM |
2015 key retrofit | brzsubarusti13 | BRZ First-Gen (2012+) -- General Topics | 0 | 04-16-2015 10:07 PM |
2015 BRZ Limited key retrofit | Turbowned | BRZ First-Gen (2012+) -- General Topics | 6 | 09-17-2014 10:52 AM |
