Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
07-20-2020, 10:16 AM | #15 |
TRACKBREAD
Awesome! I took my old knob apart yesterday. Do you know if you can separate the rubber ball from the metal threaded housing? I would like to do this but only if I can take the weight out of the knob. I don’t like how heavy the stock knob is.
07-20-2020, 10:21 AM | #16 | |
Drives: -
It doesnt appear so. Looks pretty solid. Your only option might be to cut it out and remove the pieces. |
07-21-2020, 10:31 PM | #18 |
Drives: 2014 Scion FR-S
Dude this is freaking cool! How’s the weight compared to stock? So you were able to separate the clear enamel number portion from the silver trim?
07-22-2020, 06:28 AM | #19 | |
Drives: -
The weight is about the same, +- a few grams but absolutely nothing you would notice, because its aluminum its super lightweight. Yes, the enamel disc can come off, but its not just a simple pop it out from the back, its properly stuck there, like... good and proper. So you will need to use some sort of a solvent to get at the glue at the back like I did. For this project, I ended up buying a 2nd hand spare gear shifter, so I didnt have to sacrifice my original, and got the 2nd hand one for dirt cheap as it was pretty worn, and just got the refurb done on that one,so if it did go wrong, I didnt lose anything. |
07-22-2020, 06:28 AM | #20 |
Drives: -
Final shots:
It was 99% press fit/ torque fit, so only a tiny dab of hot glue was used to hold the enamel in place. and make the bottom cap fit a bit more snug, so its all removable too if you wanted to try different finishes. Really happy with the way it came out, and the pictures dont do it enough justice. If anyone else is interested in getting the 2 parts, happy to get more made. Last edited by Sur_vey17; 07-22-2020 at 07:22 AM. |
The Following 5 Users Say Thank You to Sur_vey17 For This Useful Post: | Dzmitry (07-22-2020), Ohio Enthusiast (07-22-2020), Racecomp Engineering (07-22-2020), Tanstin (07-22-2020), Yoshoobaroo (07-22-2020) |
07-22-2020, 12:28 PM | #21 |
Is there a chance for any stainless steel or titanium options?
07-22-2020, 07:03 PM | #23 |
07-22-2020, 08:21 PM | #25 |
TRACKBREAD
GT86 Manual Shifter Knob Construction
07-22-2020, 08:35 PM | #26 | |
This should still be light enough not to increase wear. It would be nice to hear from someone that has had say a Raceseng shift knob for a long time and get a report on how their shifting feels now. |
07-22-2020, 09:43 PM | #27 |
TRACKBREAD
And here I am trying to remove the weight inside the stock knob!
My Tomei plastic knob weighs 70g and I love the extra feedback that provides. |
07-23-2020, 09:43 AM | #28 |
Drives: -
Tags |
custom, gear, knob, replacement, shifter |
Similar Threads | ||||
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
Manual shifter rattle? | Frs32907 | Issues | Warranty | Recalls / TSB | 15 | 05-11-2015 12:25 AM |
Manual Shifter Boot | rpope1127 | Interior Parts (Incl. Lighting) | 2 | 07-22-2014 12:44 PM |
WTB: OEM Manual Shift/Shifter Boot | FRS_Jack | Want-To-Buy Requests | 7 | 03-10-2014 01:10 PM |
