Old 07-28-2020, 11:56 AM   #1
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
OEM plugs or wire harnesses... where can we search for and buy them?
I'm really looking for a specific wiring plug that is used in our car but I was wondering if there wasn't a resource that had the plugs or harnesses for sale somewhere.
(I'm looking for the horn ones so I don't have to cut into oem wiring but can't find them for the life of me.)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-28-2020, 12:30 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Perhaps here:
https://www.corsa-technic.com/catego...category_id=47
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
Wally86 (07-28-2020)
Old 07-28-2020, 01:33 PM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by LimitedSlip View Post
That gets me halfway there but apparently there's no male counterpart to the female plug that i found. Oy.
Old 07-28-2020, 01:38 PM   #4
e1_griego
e1_griego's Avatar
Drives: Many
Wiring Specialties is usually good about having random connectors/pigtails.
https://www.wiringspecialties.com/connectors/
e1_griego is offline   Reply With Quote
Old 08-03-2020, 07:22 AM   #5
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Another DC area IT dude (a good friend of mine) recommended this harness;
Metra 70-1761 harness plug on Amazon
Over this this forum thread;
https://www.ft86club.com/forums/show...7&postcount=21
I believe it is what you are looking for.
Bobharp is offline   Reply With Quote
Old 08-07-2020, 07:45 PM   #6
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I actually bought that harness preemptively thinking I'd need it if toyota forgot to put one in my car but they did lol.
I'm looking for the horn connector though.
Old 08-07-2020, 08:26 PM   #7
WildCard600
WildCard600's Avatar
Drives: 2020 86
Do we know who makes the connectors in these cars ? (I haven't looked)
Mouser carries a lot of stuff - https://www.mouser.com/Connectors/Au...tors/_/N-1ehb5
WildCard600 is offline   Reply With Quote
Old 08-10-2020, 03:30 PM   #8
reh8388
Drives: 2016 Scion FR-S Release Series 2.0
You need to use the factory wiring diagrams to find the image of the connector. From there you can use this manual to identify the Toyota part number for your connector: https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
The manual will also identify the type of connector. If you are familiar with the naming of the terminals you can occasionally track down the actual OEM of the connector. A lot of the connectors in our car are made by Sumitomo or Yazaki which do not have any distribution in the US at small quantities that I have ever been able to find. If the connector is common enough you can find knockoffs. Typically these are found just by using the Toyota part number in the manual I linked to above.
For most connections I have found it is typically easier to purchase terminals from a few sites (www.cycleterminal.com or www.easternbeaver.com are 2 I use often) and then purchase the actual connector housing from Toyota. This makes a connector housing go from $1-$2 to $10 typically but it doesn't take much of my time trying to track down a source for the connector housing before I can justify just spending the extra to get it from a Toyota dealership.
reh8388 is offline   Reply With Quote
The Following 2 Users Say Thank You to reh8388 For This Useful Post:
bcj (08-14-2020), Wally86 (08-14-2020)
Old 08-14-2020, 10:00 AM   #9
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Dang. This made for a quick and easy find. Thanks!!
handbrake wire and reverse wire location Australia gt86 rsingh Electronics | Audio | NAV | Infotainment 0 01-16-2017 09:12 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
WTB: Brz harnesses/cables Gazooks113 Want-To-Buy Requests 0 06-22-2015 09:18 AM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
