08-03-2022, 09:34 PM | #421 | |
Drives: 2022 GR86
08-03-2022, 09:45 PM | #422 |
Drives: 2023 GR86
The Following 2 Users Say Thank You to pq86 For This Useful Post: | Blighty (08-03-2022), Sport-Tech (08-04-2022) |
08-03-2022, 10:51 PM | #423 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
I think you miss the point about the argument I make at the end, what if the specification is wrong, not the implementation. Like say when they designed the fuel pump incorrectly in the first gen. Specifications can be wrong when put into practice. |
08-03-2022, 11:22 PM | #424 | |
My point is that Toyota need to fix the issue. I think I stated the reasons why we might not be seeing it on a lot more engines - because its not checked as part of any standard servicing, and the issue can be something that works its way into something more significant over time, not necessarily every engine blowing immediately. The very clear reports and imagery comming out from lots of people, and the absolute radio silence about this issue even in teardown reports that had it, makes me feel very uneasy about what is going on. |
08-04-2022, 12:00 AM | #425 | |
Drives: zd8 brz
Toyota can fix it sure.. or attempt to, but until Subaru figures out exactly which machine is out of calibration or is programmed to be generous, it will never end the cycle of issues. you fix problems at their roots. redoing the timing chain covers and oil pans are a fix to a problem that shouldnt exist. The only thing toyota should be fixing is their FST's and how warranties are handled. As of right now, Subaru should be focused on finding what went wrong and where. they can replace engines once engines are assembled properly and correctly. |
The Following User Says Thank You to mycrors7 For This Useful Post: | DylanJZA (08-04-2022) |
08-04-2022, 12:41 AM | #426 |
Drives: 2016 Scion FR-S
The way I see it is, Toyota should make things right for their customers and cover failed engines that show RTV in the oil. Toyota did NOT design the FA24D, they contributed their D4S system (same as the FA20). BUT they sell the GR86 as a Toyota model, and they should stand behind their partnership with Subaru. Apparently Subaru is covering failed engines under their warranty. Toyota will do the same eventually, but I feel bad for the first Toyota owners fighting this battle.
I still want to buy one of the twins (if a GR Corolla is impossible to find), and I hope this RTV issue has an easy “fix”. It’s probably a tricky part of the assembly process. Too much and you can end up with chunks of sealant in the engine. Too little and the engine won’t be sealed properly. I remember from the first gen twins when recalls were being done for the valve springs. Some engines were failing later because of RTV being applied incorrectly. Sounds like Subaru needs to think about a different way to seal their engines. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to JesseG For This Useful Post: | Robertw (08-04-2022) |
08-04-2022, 01:13 AM | #427 |
Drives: 2022 Toyota GR86 Premium 6MT
Well that solves that mystery. Thanks for popping in on the little tornado you’ve created lol, I hope watching the entire GR86 community busting down toyota’s door is at least a small solace for your lost engine.
08-04-2022, 03:14 AM | #428 |
btr.life
Drives: 2022 GR86
Took my car apart tonight to check out my oil pickup and the RTV job. I autox and track a lot and just got back from a ~1500 mile road trip with 70 minutes of track time at UMC outer loop. So, wanted to make sure it was safe for the future, just in case.
Only 4k miles on the car to date 3 autox, 1 track day No oiling or temp issues at all, car has run perfectly fine. But, now oil pickup and RTV is cleaned up and redone, without using 8lbs of RTV.
The Following 9 Users Say Thank You to justinco For This Useful Post: | chickunfut (08-04-2022), DarkSunrise (08-04-2022), Dylans47 (08-04-2022), Kelse92 (08-04-2022), NoHaveMSG (08-04-2022), Pat (08-04-2022), Petah78 (08-04-2022), Robertw (08-04-2022), timurrrr (08-05-2022) |
08-04-2022, 04:17 AM | #429 | |
Drives: Scion FR-S
Wish I could do this when I get my GR86, but this would just be another reason for Toyota to deny a warranty claim... Stuck between a rock and a hard place. |
08-04-2022, 05:49 AM | #430 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
08-04-2022, 06:33 AM | #431 | |
It is possible that the amount of sealant is in spec but the oil pan is torqued down too tight and actually cutting it off. It would only take a couple of pounds over torque to cut into and damage the bead allowing it to break off. Here is a used pan from an Ascent (FA24F) posted on EBay. There is just as much sealant as the FA24G but it is fully intact and there are not even any indications of being cut, breaking or other damage at the contact points around the inner edge. The bead is even on all the contact surfaces and remains pristine even after removal from the block. This pan sealant is totally different. The contact points are irregular, the inner bead is obviously pinched off and torn.
08-04-2022, 06:41 AM | #432 | |
btr.life
Drives: 2022 GR86
MFG date is 12/21.
08-04-2022, 06:49 AM | #433 | |
btr.life
Drives: 2022 GR86
Below are some more before photos, prior to cleaning everything up and resealing. I also have a full video popping up on my channel in the morning.
08-04-2022, 07:04 AM | #434 | |
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 Last edited by Petah78; 08-04-2022 at 10:35 AM. |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
