BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
10-11-2020, 04:38 PM | #1 |
Drives: 2020 Subaru BRZ Sport-tech
Tires for BRZ for Track Use - Seeking advice
Hello everyone,
New track driver here. I have been to the track 4 times now with my stock michelin primacys and they are so shredded the hoes be gettin bedded. Im looking to get some track tires that I could keep on for occasional street use. Can anyone give any suggestions or comments on the following options? I am looking for -> 215/45 R17 Firestone Firehawk Indy 500’s Bridgestone Potenza RE-71R Michelin Pilot Sport 4 S Hankook Ventus RS4 |
10-11-2020, 04:48 PM | #2 |
Rust bucket enthusiast
I would stick with a 3 or 400tw tire class for several more track sessions honestly before moving onto a competitive tire. Upgrading to the 200tw category is going to also necessitate balance in your suspension, braking system, as well as your approach.
Just give yourself a little more time to get the fundamentals down |
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
10-11-2020, 05:50 PM | #3 | |
Drives: '13 Whiteout
Going to sticky tires too soon will hamper your progression as a driver. A more racing oriented tire will improve lap times but will mask a lot of mistakes. If your goal is to get better in the long run then stay with something on the less grippy end. |
10-11-2020, 08:00 PM | #4 | |
Drives: '23 BRZ
Michelin PS4S would be a fine choice but quite pricey... In the same Max Perf category, the Continental ExtremeContact Sport is a really good tire and trackable, I just got back from the track with mine I turned quicker laps on them than on my friend's RS4s I borrowed for a session yesterday fwiw... |
10-11-2020, 08:07 PM | #5 |
You go to Skippy School and they use hard tires for a reason.
10-11-2020, 08:18 PM | #6 |
Drives: '23 BRZ
10-11-2020, 08:31 PM | #7 |
10-11-2020, 09:24 PM | #8 |
Drives: 17 Asphalt 86
RS4s last forever for a 200tw. I'd probably go that route over RE71 unless you were doing time attack.
The new RT660 is getting some praise as a good middle ground between RS4 and RE71. Definitely suggest adding some Camber. Should help wear on the outter edges. |
10-11-2020, 10:28 PM | #9 |
Drives: 2013 Scion FRS
I've heard good things about the indy 500s for a higher tw tire, but never tried them myself. Champiro sx2 are really nice for track driving and easily controllable at the limit, but need a bit of temp for max grip (being controllable the whole time)
For more grip I liked my continental extreme contact sports. |
10-12-2020, 11:43 AM | #10 |
Drives: Crapcan
I have always found the Hankooks as meh in the 200TW catagory. They seem like they give up at the limit, where other tires seem to let you play with a bit of slip angle without much effort.
10-12-2020, 11:50 AM | #11 |
Drives: '23 BRZ
Hm, I liked them fine the couple of times I tried them at the track, and I like to hang it out a bit... I thought they were pretty solid/fun. But they are more than a second slower than RE71R and not much if any faster than Conti ECS at half tread-depth... Contis are quite squirmy when new tho and start to give up a bit after a few laps.
The Following User Says Thank You to ZDan For This Useful Post: | Hades (10-12-2020) |
10-12-2020, 11:56 AM | #12 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | ZDan (10-12-2020) |
10-12-2020, 12:55 PM | #13 | |
Drives: '23 BRZ
Continental ExtremeContact Sport |
10-12-2020, 01:14 PM | #14 |
For a good 200 tire I've heard a lot of good things about the GT Radial SX2, pricing seems good also.
Similar Threads | ||||
New Owner Seeking Track Advice! | Jamestl | Tracking / Autocross / HPDE / Drifting | 26 | 07-31-2017 12:59 PM |
First mod but seeking advice | ReaperBRZ | Engine, Exhaust, Transmission | 29 | 02-26-2016 11:02 PM |
Long time Lurker seeking advice on a budget suspension setup | sunset_blvd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 12-28-2014 05:48 PM |
Seeking Advice! Swift BRZ, Alignment! | leicaboss | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-27-2014 03:23 PM |
First time to the track. Need advice. Thanks. | siuhen | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-04-2013 12:14 PM |
