Old 01-13-2022, 04:56 PM   #99
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Right, if anything this change would be a potential negative since now the shock is further from the wheel and would have less control over the wheel.
Rules are what they are for a reason though, I'm not taking that protest bait.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
strat61caster (01-13-2022), timurrrr (01-20-2022)
Old 01-13-2022, 11:51 PM   #100
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Originally Posted by DocWalt View Post
That's not how the rule is worded. Moving the shock hole in relation to the fixed end is illegal, no matter which end is fixed.
The camber adjustment end does change the shock hole in relation to that end... but the rule specifically says that's legal as noted above.
I think you mis-understood what I meant, because what you just said is agreeing with my point.
Breezio is offline   Reply With Quote
Old 01-14-2022, 08:07 AM   #101
RRslip
Drives: Black BRZ - STX
FWIW, the charcoal filter thing will be put out for re-wording, who knows what is going to happen at the SEB level since emissions is involved.
The LCA had no support for a change. This is a really old battle going back to Civics/Del Sols/Integras. I couldn't agree more about it being in idgaf land. Personally, I wouldn't buy new arms. But remember, protest committee has already thrown someone out for the SPC ball joint arms, so not a lot of hope that they'd pass me if I was protested.
Maybe we should stop measuring these things and people would go back to not caring. I know I never measured the pitches on my gen1 aftermarket arms, I have no clue if they are legal.
Todd K. | Ohio | STX 16' BRZ | 330F/500R | Perrin 22mm front, Karcepts rear
RRslip is offline   Reply With Quote
Old 01-15-2022, 06:59 PM   #102
Brock H.
Drives: 2022 BRZ, Red
Originally Posted by timurrrr View Post
PSA for people who plan to run aftermarket RLCAs in the ST* class in the future
All gen.1 RLCAs are likely illegal on 2022's, because the distance from the subframe bushing to the strut attachment point are different by ~0.5".
This is making a little more sense now that I've thought about it some.
Assuming that the subframe is the source of the increased rear track width and that the arms where measured to be the same length from subframe bushing to knuckle hole (Thanks CSG Mike - https://www.ft86club.com/forums/show...7&postcount=57), then the strut attachment probably shifted to keep the rear motion ratio from getting to out of wack.
Nonetheless, I see the issue now. I was coming at it from an overall arm length perspective and was confused as to how that would be illegal. Sounds like if you want to run additional rear camber, then adjustable RUCA's would be the only solution early on since that part carried over from the last gen.
Brock H. is offline   Reply With Quote
The Following User Says Thank You to Brock H. For This Useful Post:
strat61caster (01-15-2022)
Old 01-15-2022, 08:38 PM   #103
strat61caster
strat61caster's Avatar
I forgot RUCA adjustable balljoints were available, that would be the way to go for legality in the short term.
ineedyourdiddly
Old 01-15-2022, 09:25 PM   #104
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
Wonder if upper ball joints being the answer will help with the tire rub on the fender then since it’ll suck the top of the tire in more.
MacSpeed is offline   Reply With Quote
The Following User Says Thank You to MacSpeed For This Useful Post:
Simmons (01-15-2022)
Old 01-16-2022, 01:33 PM   #105
strat61caster
I’ve never heard of rubbing in the rear from autox cars, stance cars maybe with some wide wheels and funny offsets, my upper control arms hit the chassis before the tire touches anything, and that’s not accounting for the damper bottoming first.
ineedyourdiddly
Old 01-16-2022, 02:20 PM   #106
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
2022's have bad rubbing issues in the rear because of the wider track
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
Aroundomaha (01-17-2022), strat61caster (01-16-2022), timurrrr (01-20-2022)
Old 01-16-2022, 07:02 PM   #107
strat61caster
Gotta trade in those +35s I guess? Plenty of +45s available.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Aroundomaha (01-17-2022), DocWalt (01-16-2022)
Old 01-17-2022, 04:00 PM   #108
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Got a link to the specific ones you're referring to please?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 01-17-2022, 06:27 PM   #109
strat61caster
I misspoke, it’s not a ball joint it’s a set of eccentric bushings in the a arm like a Miata.
https://www.whiteline.com.au/product..._number=KCA326
You could also do an aftermarket upper control arm like this one;
https://racerxfabrication.com/frs-br...r-control-arms
Given that the rear falls naturally close to them desired camber the whiteline kit should be plenty, if it is a pain in the ass to adjust.
ineedyourdiddly
Locust (01-19-2022)
Old 01-18-2022, 05:21 PM   #110
Brock H.
I used the Racer X upper arms on the last gen with good results. They can also be a right PITA to adjust since you have to separate it from the knuckle and rotate the threaded portion of the ball joint. Crap can get in the threads and make it real hard to adjust after a year or so. can only adjust .5deg or so at a time too
The Following 2 Users Say Thank You to Brock H. For This Useful Post:
DocWalt (01-18-2022), strat61caster (01-18-2022)
Old 01-19-2022, 02:00 PM   #111
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Can someone measure precisely (±1 mm) the distance between holes on gen.2 stock RLCAs?
My measurements of the Verus RLCAs:
Knuckle bolt/Strut bolt 104mm
Knuckle bolt/ARB end link bolt 189mm
I should be able to measure the same for a stock gen.1 RLCA in the next few weeks if needed.
Below are photos taken with the iPhone 13 Pro 3x zoom (to minimize perspective distortions) for the reference.
Note that the numbers above were checked visually, not just by looking at these photos (that still have some distortions of the perspective).
timurrrr is offline   Reply With Quote
Old 01-19-2022, 04:45 PM   #112
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I get ~94 for the first, and ~189 for the second.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
timurrrr (01-19-2022)
SCCA AutoX Classing... Roadcone Tracking / Autocross / HPDE / Drifting 13 10-21-2014 05:02 PM
Carbon fiber hood & SCCA classing TimR Tracking / Autocross / HPDE / Drifting 21 06-17-2014 12:27 PM
AutoX and classing chappys4life Tracking / Autocross / HPDE / Drifting 16 02-20-2013 03:38 PM
Autocross next wknd for me! Interesting response re: classing.. MarkRacerX Tracking / Autocross / HPDE / Drifting 42 06-18-2012 01:52 AM
