#1023 | |
Drives: None
Trip replied to my post about the terminal thing and suggested changing the stack order, which worked quite a bit better. It still isn't perfect but I'll deal with that later. For what it is worth, this chunk of wires can be unwrapped and be summarized as: ![]() 1. Bottom white plug to top black plug comes completely unwrapped and is a single wire that plugs into the main engine harness. White plug to harness, black plug gets the cover removed and goes to the alternator. 2. Bare ring gets unwrapped from this and is the ground that goes to the transmission 3. Remaining single wire is the main positive terminal wire, follows the main harness and connects to the alternator Anyway, motor is ready to go in, I'm just being lazy at this point.
2016 Subaru BRZ - Hyperblue #064
2015 Subaru BRZ - Crystal White - ST/TT / K24 in progress Last edited by RedReplicant; 05-19-2022 at 09:45 PM. |
#1024 | |
K Swap Everything
Drives: Q5 + BRZ + M796
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | RedReplicant (Yesterday) |
#1025 |
Drives: None
Before I toss this thing in tomorrow... couple of questions.
![]() Obviously difficult to tell from a picture, but is this hammered enough? ![]() Anyone have the top motor to plate on the exhaust side M12 not want to thread in? 5 other bolts and the two dowels are there so I know nothing is misaligned. On the Captain Awesome coolant route front, I got the Miata right exit KPower water outlet with the barb. Connects to the TracTuff port on the thermostat housing with two Dayco 80401 and a 5/8 union, other thermostat port goes to the intake manifold outlet. Little worried about the right exit on the water outlet being what I estimate to be an inch shorter, but I'll cross that bridge when the time comes. (let me confirm this all works before anyone follows) ![]()
2015 Subaru BRZ - Crystal White - ST/TT / K24 in progress |
The Following User Says Thank You to RedReplicant For This Useful Post: | Irace86.2.0 (Yesterday) |
#1026 | |
K Swap Everything
On the driver’s side, I cut the bracket to the edge of the bolt ring/bracket inside the outer bracket. I cut a horizontal line just high enough on the vertical margin to be able to hammer it back. Same on the passenger side, but also cut per the instructions and hammered it back with 1-2 cm of thickness of the bracket. This can be done after, but it is easier beforehand.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | RedReplicant (Today) |
#1027 |
Drives: None
Thank you
Yeah, I used a jack as a portapower with the trans bracket and stock bolts in it. Everything still goes in. I was worried about hacking the mounts up since I don't really want to weaken them significantly. I do have a welder but I wouldn't consider myself good enough to attempt this properly. Sounds like it is something I'll take the car to the local fab shop for after I get it together.
#1028 | |
K Swap Everything
Your concern about movement with cutting it up a little is logical, but likely unwarranted. Try bolting up the trans mount and pull and yank as hard as you can to get movement. I'll wager there won't be any movement. The transmission itself is mostly held in position by the engine. There is very little weight on the transmission mount. The first picture is the driver's side with the Kpower instructions to hammer and my cut instructions. The second is the driver's side. The red is cut and the grey is the bolt bracket that is welded inside the main bracket.
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
