Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-11-2021, 05:27 PM | #1 |
Drives: 2013 Subaru BRZ Premium
Shifter Malfunction After Clutch Install
Hey, so I just switched out my Factory Clutch for a Stage 2 Competition Clutch. After getting *almost* everything reassembled, I ran into a problem with the shifter… After setting it in place and putting the codder pin (don’t know if I spelled that right) it is successful in shifting to all gears EXCEPT 2nd… It sounds/feels as if it is just being blocked off, but anyway, it is ONLY 2nd gear that I am unable to shift into. Anyone have any thoughts or ideas? Thank you.
08-11-2021, 05:46 PM | #2 |
Drives: GR86 2022
Did you already adjusted the reverse lockout plate?
The Following 2 Users Say Thank You to dreamwonder For This Useful Post: | Ultramaroon (08-12-2021), x808drifter (08-12-2021) |
08-11-2021, 11:06 PM | #3 |
Señor Member
Is this with the engine running?
1974 TA22 Celica
2013 86 GT |
08-12-2021, 01:52 AM | #4 |
義理チョコ
If the top plate adjustment is suspected, try lifting the lockout and fish around for the second gear gate. If easily found, it's the adjustment. It should be carefully adjusted so first and second can be engaged without rubbing the sides of the gates. That wear is against delicate parts of the gear selection mechanism inside the transmission.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | jcw99 (08-12-2021), x808drifter (08-12-2021) |
08-14-2021, 06:48 PM | #5 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
I had this same thing happen the first time I reinstalled my trans and shifter. The problem for me was an ill-adjusted lock-out plate. It "felt" like I was shifting into first, but in reality I was shifting into reverse. So of course if you come straight back from being in reverse, it won't go into 2nd gear because you're not in the right position.
The Following User Says Thank You to vfrqqq For This Useful Post: | Ultramaroon (08-14-2021) |
08-18-2021, 09:58 AM | #6 |
Drives: 2016 Subaru BRZ
Gotta mark the shift plate before removing it so you can put it on exactly how it came off to avoid this issue.
08-18-2021, 05:58 PM | #7 |
義理チョコ
It's easy to align. Just takes a couple passes to make sure it centers the selector in both first and second gear gates.
08-19-2021, 05:07 PM | #8 |
Ultra Senior Member
Once I realized what was happening, I shifted into reverse and then slowly pulled it out while still lined up with the reverse gear position, moved it slightly to the right and then pushed it forward until it slotted into first gear. Once you're in first, set the position of the shifter plate until it is in contact with the lockout collar to get it approximately in the right position. After that, fine tune the position to ensure that you always have a smooth shift into first without going into reverse.
08-20-2021, 05:23 PM | #9 |
Just the tip
Drives: 2017 DGM BRZ
OP hasn't replied yet but if the reverse lockout gate is indeed your issue, here is the official procedure for setting the clearance.
The Following 2 Users Say Thank You to wolffbite For This Useful Post: | Ultramaroon (08-20-2021), vfrqqq (08-21-2021) |
Tags |
clutch, shifter, transmission |
Similar Threads | ||||
Shifter kinda stuck and extr play after clutch install | airrick | Engine, Exhaust, Transmission | 10 | 04-27-2020 09:26 PM |
CAE Ultra Shifter install... | Vracer111 | DIY (Do-It-Yourself) Guides | 96 | 02-18-2018 02:15 AM |
Stock shifter install | nomis | Engine, Exhaust, Transmission | 1 | 05-05-2016 01:13 AM |
kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
Shifter bushing install | Bullnettles | Engine, Exhaust, Transmission | 4 | 06-20-2013 04:36 PM |
